我被要求查看我们从
STM32F7 迁移到 STM32H7 时遇到的问题。我们在与 QUAD SPI 芯片 (Micron MT25QL256ABA)
通信时遇到问题。
(我对 SPI 通信和微控制器非常熟悉,但对 STM32 还是陌生的。)
但是老实说,我仍然在学习这个芯片的曲线。
我们有一个示例程序,可以将数据写入 QSPI,然后在 MemoryMappedMode 中将其读回。奇怪的是,该程序运行了 5 次测试,然后未能读回数据进行比较。这是始终失败的代码部分:
- // +++++++ START MULti-SECTOR TEST ++++++++++
- // Erase a sector then write a sector
- // Notes: EraseSector command may be size dependent.
- // EndAddress parameter is ignored.
- // Need to re-init to exit Memory Mapped Mode from previous test
- CSP_QUADSPI_Init();
- for (var = 0; var < SECTOR_COUNT; var++)
- if (CSP_QSPI_EraseSector(var * MEMORY_SECTOR_SIZE,
- (var + 1) * MEMORY_SECTOR_SIZE - 1) != HAL_OK)
- while (1); //breakpoint - error detected
- Wait_For_QUADSPI();
- if (CSP_QSPI_WriteMemory(upCountBuffer, var * MEMORY_SECTOR_SIZE,
- sizeof(upCountBuffer)) != HAL_OK)
- if (CSP_QSPI_EraseSector(0x1000000 + (var * MEMORY_SECTOR_SIZE),
- 0x1000000 + (var * MEMORY_SECTOR_SIZE) + (MEMORY_SECTOR_SIZE - 1)) != HAL_OK)
- if (CSP_QSPI_WriteMemory(downCountBuffer, 0x1000000 + (var * MEMORY_SECTOR_SIZE),
- sizeof(downCountBuffer)) != HAL_OK)
- if (CSP_QSPI_EnableMemoryMappedMode() != HAL_OK)
- HAL_Delay(10);
- //Wait_For_QUADSPI();
- // xxCountBuffer[] (size of one sector) is bulk compared against a written sector.
- // This comparison occurs, sector by sector for SECTOR_COUNT number of times.
- memcpy( upCountBuffer_read,
- (uint8_t*) (0x90000000 + (var * MEMORY_SECTOR_SIZE)), MEMORY_SECTOR_SIZE);
- if (memcmp(upCountBuffer, upCountBuffer_read, MEMORY_SECTOR_SIZE) != HAL_OK)
- while (1); //breakpoint - error detected - otherwise QSPI works properly
- MEMORY_SECTOR_SIZE) != HAL_OK)
- memcpy( downCountBuffer_read,
- (uint8_t*) (0x90000000 + 0x1000000 + (var * MEMORY_SECTOR_SIZE)),
- MEMORY_SECTOR_SIZE);
- if (memcmp(downCountBuffer, downCountBuffer_read, MEMORY_SECTOR_SIZE) != HAL_OK)
注意 Wait_For_QUADSPI() 如下:
- void Wait_For_QUADSPI(void)
- HAL_Delay(10);
- int count = 0;
- HAL_QSPI_StateTypeDef iState;
- //return;
- while (1)
- iState = HAL_QSPI_GetState(&hqspi);
- switch (iState)
- case HAL_QSPI_STATE_RESET:
- break;
- case HAL_QSPI_STATE_READY:
- return;
- case HAL_QSPI_STATE_BUSY:
- break;
- case HAL_QSPI_STATE_BUSY_INDIRECT_TX:
- break;
- case HAL_QSPI_STATE_BUSY_INDIRECT_RX:
- break;
- case HAL_QSPI_STATE_BUSY_AUTO_POLLING:
- break;
- case HAL_QSPI_STATE_BUSY_MEM_MAPPED:
- count++;
- if (count>10)
- //HAL_QSPI_Abort(&hqspi);/// do I need to reinit?
- return;
- break;
- case HAL_QSPI_STATE_ABORT:
- break;
- case HAL_QSPI_STATE_ERROR:
- break;
- default:
- break;
- HAL_Delay(10);
在以前的测试中,如果我在 EnableMemoryMappedMode 之后调用上述函数,它会挂起,所以我尝试中止,但这没有帮助。所以我注释掉了那部分,现在在启用内存映射模式后使用 10 毫秒的硬编码延迟。
这是 EnableMemoryMappedMode 代码。注意我尝试启用和不启用超时。
- uint8_t CSP_QSPI_EnableMemoryMappedMode(void) {
- QSPI_CommandTypeDef sCommand;
- QSPI_MemoryMappedTypeDef sMemMappedCfg;
- /* Enable Memory-Mapped mode-------------------------------------------------- */
- /***** Assuming QUAD MODE is enabled *****/
- /***** Assuming 4-byte address mode ******/
- sCommand.InstructionMode = QSPI_INSTRUCTION_4_LINES;
- //sCommand.AddressSize = QSPI_ADDRESS_24_BITS;
- sCommand.AddressSize = QSPI_ADDRESS_32_BITS;
- sCommand.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
- sCommand.DdrMode = QSPI_DDR_MODE_DISABLE;
- sCommand.DdrHoldHalfCycle = QSPI_DDR_HHC_ANALOG_DELAY;
- sCommand.SIOOMode = QSPI_SIOO_INST_EVERY_CMD;
- sCommand.AddressMode = QSPI_ADDRESS_4_LINES;
- sCommand.DataMode = QSPI_DATA_4_LINES;
- sCommand.NbData = 1;
- sCommand.Address = 0;
- //sCommand.Instruction = QUAD_OUT_FAST_READ_CMD;
- sCommand.Instruction = QUAD_4BYTE_OUT_FAST_READ_CMD;
- sCommand.DummyCycles = DUMMY_CLOCK_CYCLES_READ_QUAD;
- sMemMappedCfg.TimeOutActivation = QSPI_TIMEOUT_COUNTER_ENABLE; ///QSPI_TIMEOUT_COUNTER_DISABLE; RRS
- if (HAL_QSPI_MemoryMapped(&hqspi, &sCommand, &sMemMappedCfg) != HAL_OK) {
- return HAL_ERROR;
- return HAL_OK;
不管怎样,我想联系一下,看看是否有其他人遇到类似的问题,并且可以分享一些代码来说明你是如何解决这个问题的(即你是如何实施 Errata pdf 中的建议的。)
