ST意法半导体
直播中
贾埃罗
8年用户 1799经验值
私信 关注
[问答]
STM32MP157 mmc1为什么没有切换到高速模式?
嗨,支持者,我有两块板,一块是我的定制板,另一块是 dk2。这些板子不支持 mmc1 的高速。mmc2 进入高速并具有 50Mhz 时钟。
以下是有关 dk2 板上的 mmc1 和 mmc2 的一些信息。
  • root@STM32mp1:~# cat /sys/kernel/debug/mmc0/ios
  • clock:                25000000 Hz
  • actual clock:        24750000 Hz
  • vdd:                21 (3.3 ~ 3.4 V)
  • bus mode:        2 (push-pull)
  • chip select:        0 (don't care)
  • power mode:        2 (on)
  • bus width:        2 (4 bits)
  • timing spec:        0 (legacy)
  • signal voltage:        0 (3.30 V)
  • driver type:        0 (driver type B)
  • root@stm32mp1:~# cat /sys/kernel/debug/mmc1/ios
  • clock:                50000000 Hz
  • actual clock:        49500000 Hz
  • timing spec:        2 (sd high-speed)
  • root@stm32mp1:~# mount -t debugfs debugfs /mnt/
  • root@stm32mp1:~# cat /mnt/^C
  • root@stm32mp1:~# dmesg| grep mmc
  • [    0.000000] Kernel command line: root=/dev/mmcblk0p6 rootwait rw console=ttySTM0,115200
  • [    1.948032] mmci-pl18x 58005000.sdmmc: Linked as a consumer to regulator.8
  • [    1.953617] mmci-pl18x 58005000.sdmmc: mmc0: PL180 manf 53 rev2 at 0x58005000 irq 58,0 (pio)
  • [    1.991010] mmci-pl18x 58007000.sdmmc: allocated mmc-pwrseq
  • [    1.995496] mmci-pl18x 58007000.sdmmc: Linked as a consumer to regulator.8
  • [    2.003329] mmci-pl18x 58007000.sdmmc: mmc1: PL180 manf 53 rev1 at 0x58007000 irq 59,0 (pio)
  • [    2.042312] mmc0: host does not support reading read-only switch, assuming write-enable
  • [    2.060730] mmc0: Problem switching card into high-speed mode!
  • [    2.069832] mmc0: new SDHC card at address 0001
  • [    2.079128] mmcblk0: mmc0:0001 SD 14.6 GiB
  • [    2.094173] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
  • [    2.104142] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
  • [    2.116461] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
  • [    2.127848] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
  • [    2.136986] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
  • [    2.183527] mmc1: queuing unknown CIS tuple 0x80 (6 bytes)
  • [    2.189127]  mmcblk0: p1 p2 p3 p4 p5 p6 p7
  • [    2.277342] mmc1: new high speed SDIO card at address 0001
我发现一条错误消息“mmc0:将卡切换到高速模式时出现问题!”。是什么原因导致 mmc1 没有进入速度模式?在我的应用程序中,我们需要 50Mhz 的 mmc1 以更高的 io 速度来读/写 sdcard 上的文件。
回帖(1)
宁升椿
2022-12-12 11:00:27
您是否尝试过使用另一张 SD 卡?
在我的 DK2-F 上,我得到了正确的卡速度。
  • root@stm32mp1:~# cat /sys/kernel/debug/mmc0/ios
  • [    3.249286] mmci-pl18x 58005000.sdmmc: Got CD GPIO
  • [    3.254048] mmci-pl18x 58005000.sdmmc: mmc0: PL180 manf 53 rev2 at 0x58005000 irq 54,0 (pio)
  • [    3.291261] mmci-pl18x 58007000.sdmmc: allocated mmc-pwrseq
  • [    3.297290] mmci-pl18x 58007000.sdmmc: mmc1: PL180 manf 53 rev1 at 0x58007000 irq 55,0 (pio)
  • [    3.354453] mmc0: new high speed SDHC card at address 0007
  • [    3.365910] mmcblk0: mmc0:0007 SD16G 14.5 GiB
举报
更多回帖
