嵌入式学习小组
直播中
张莉
8年用户 1339经验值
私信 关注
OKMX6Q-C工业级套件烧入资料时屏幕无显示是什么问题导致的?
请问屏幕无显示是什么问题导致的?系统镜像里没有这个7.0mipi液晶模块的驱动?
 用的开发板是OKMX6Q-C工业级套餐+FIT-LCD7.0MIPI液晶模块。拿到的板子默认是QT系统  用资料下载里Andorid 6.0资料里的下载工具烧入Android 6.0镜像下的文件。启动后始终黑屏,屏幕没有任何显示。
  用串口打出的LOG如下:
  NFS: Registering the id_resolver key type
  Key type id_resolver registered
  Key type id_legacy registered
  ntfs: driver 2.1.32 [Flags: R/W DEBUG]。
  jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
  fuse init (API version 7.23)
  bounce: pool size: 64 pages
  io scheduler noop registered
  io scheduler deadline registered
  io scheduler cfq registered (default)
  imx-weim 21b8000.weim: Driver registered.
  mxc_mipi_dsi 21e0000.mipi: i.MX MIPI DSI driver probed
  MIPI DSI driver module loaded
  mxc_sdc_fb fb@0: registered mxc display driver lcd
  Console: switching to colour frame buffer device 100x30
  mxc_sdc_fb fb@3: err inte**ce_pix_fmt!
  mxc_sdc_fb fb@3: get mxcfb of property fail
  mxc_sdc_fb: probe of fb@3 failed with error -2
  imx-sdma 20ec000.sdma: no iram assigned, using external mem
  imx-sdma 20ec000.sdma: no event needs to be remapped
  imx-sdma 20ec000.sdma: loaded firmware 3.3
  imx-sdma 20ec000.sdma: initialized
  pfuze100-regulator 1-0008: Full layer: 2, Metal layer: 1
  pfuze100-regulator 1-0008: FAB: 0, FIN: 0
  pfuze100-regulator 1-0008: pfuze100 found.
  2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 24, base_baud = 5000000) is a IMX
  console [ttymxc0] enabled
  21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 301, base_baud = 5000000) is a IMX
  21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 302, base_baud = 5000000) is a IMX
  21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 303, base_baud = 5000000) is a IMX
  21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 304, base_baud = 5000000) is a IMX
  imx sema4 driver is registered.
  [drm] Initialized drm 1.1.0 20060810
  [drm] Initialized vivante 1.0.0 20120216 on minor 0
  brd: module loaded
  loop: module loaded
  zram: Created 1 device(s)
  ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
  ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
  ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
  ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
  ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
  ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
  ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
  scsi host0: ahci-imx
  ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 314
  tun: Universal TUN/TAP device driver, 1.6
  tun: (C) 1999-2004 Max Krasnyansky 《maxk@qualcomm.com
  CAN device driver inte**ce
  flexcan 2090000.flexcan: device registered (reg_base=efc18000, irq=31)
  2188000.ethernet supply phy not found, using dummy regulator
  pps pps0: new PPS source ptp0
  fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
  fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 4e:a3:ec:71:f5:d2
  libphy: fec_enet_mii_bus: probed
  fec 2188000.ethernet eth0: registered PHC device 0
  PPP generic driver version 2.4.2
  PPP BSD Compression module registered
  PPP Deflate Compression module registered
  PPP MPPE Compression module registered
  NET: Registered protocol family 24
  pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
  usbcore: registered new inte**ce driver pegasus
  usbcore: registered new inte**ce driver rtl8150
  usbcore: registered new inte**ce driver r8152
  usbcore: registered new inte**ce driver asix
  usbcore: registered new inte**ce driver ax88179_178a
  usbcore: registered new inte**ce driver cdc_ether
  usbcore: registered new inte**ce driver cdc_eem
  usbcore: registered new inte**ce driver net1080
  usbcore: registered new inte**ce driver cdc_subset
  usbcore: registered new inte**ce driver zaurus
  usbcore: registered new inte**ce driver cdc_ncm
  ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
  ehci-mxc: Freescale On-Chip EHCI Host driver
  usbcore: registered new inte**ce driver cdc_acm
  cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
  usbcore: registered new inte**ce driver usb-storage
  usbcore: registered new inte**ce driver usbserial
  usbcore: registered new inte**ce driver usbserial_generic
  usbserial: USB Serial support registered for generic
  usbcore: registered new inte**ce driver ftdi_sio
  usbserial: USB Serial support registered for FTDI USB Serial Device
  usbcore: registered new inte**ce driver option
  usbserial: USB Serial support registered for GSM modem (1-port)
  usbcore: registered new inte**ce driver pl2303
  usbserial: USB Serial support registered for pl2303
  usbcore: registered new inte**ce driver usb_ehset_test
  2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
  usb_otg_vbus: supplied by SWBST
  usb_h1_vbus: supplied by SWBST
  ci_hdrc ci_hdrc.1: EHCI Host Controller
  ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
  ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
  usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
  usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  usb usb1: Product: EHCI Host Controller
  usb usb1: Manufacturer: Linux 4.1.15 ehci_hcd
  usb usb1: SerialNumber: ci_hdrc.1
  hub 1-0:1.0: USB hub found
  hub 1-0:1.0: 1 port detected
  mousedev: PS/2 mouse device common for all mice
  usbcore: registered new inte**ce driver xpad
  usbcore: registered new inte**ce driver usb_acecad
  usbcore: registered new inte**ce driver aiptek
  usbcore: registered new inte**ce driver gtco
  usbcore: registered new inte**ce driver hanwang
  usbcore: registered new inte**ce driver kbtab
  edt_ft5x06 2-0038: touchscreen probe failed
  edt_ft5x06: probe of 2-0038 failed with error -5
  ata1: SATA link down (SStatus 0 SControl 300)
  ahci-imx 2200000.sata: no device found, disabling link.
  ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
  -------EDT FT5x06 initialized: WAKE pin -2, Reset pin -2.
  input: EP0790M09 as /devices/soc0/i2c-ft5326/i2c-3/3-0038/input/input1
  《《-GTP-INFO-》》 GTP driver installing.。.
  《《-GTP-INFO-》》 GTP Driver Version: V2.4《2014/11/28》
  《《-GTP-INFO-》》 GTP I2C Address: 0x14
  《《-GTP-ERROR-》》 I2C Read: 0x8047, 1 bytes failed, errcode: -5!
  《《-GTP-ERROR-》》 GTP i2c test failed time 1.
  《《-GTP-ERROR-》》 GTP i2c test failed time 2.
  《《-GTP-ERROR-》》 GTP i2c test failed time 3.
  《《-GTP-ERROR-》》 GTP i2c test failed time 4.
  《《-GTP-ERROR-》》 GTP i2c test failed time 5.
  《《-GTP-ERROR-》》 I2C read failed.
  《《-GTP-INFO-》》 GTP I2C Address: 0x5d
  usb 1-1: new high-speed USB device number 2 using ci_hdrc
  rtc-rx8010 2-0032: rtc core: registered rx8010 as rtc0
  rtc-rx8010 2-0032: IRQ 73 supplied
  snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
  i2c /dev entries driver
  IR NEC protocol handler initialized
  IR RC5(x/sz) protocol handler initialized
  IR RC6 protocol handler initialized
  IR JVC protocol handler initialized
  IR Sony protocol handler initialized
  IR SANYO protocol handler initialized
  IR Sharp protocol handler initialized
  IR MCE Keyboard/mouse protocol handler initialized
  IR XMP protocol handler initialized
  usb 1-1: New USB device found, idVendor=0424, idProduct=2514
  usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
  hub 1-1:1.0: USB hub found
  hub 1-1:1.0: 4 ports detected
  ov5640_read_reg:write reg error:reg=300a
  camera ov5640 is not found
  ov5642_read_reg:write reg error:reg=300a
  camera ov5642 is not found
  usb 1-1.3: new high-speed USB device number 3 using ci_hdrc
  camera ov5640_mipi is not found
  mxc_v4l2_output v4l2_out: V4L2 device registered as video16
  mxc_v4l2_output v4l2_out: V4L2 device registered as video17
  usbcore: registered new inte**ce driver uvcvideo
  USB Video Class driver (1.1.1)
  imx2-wdt 20c0000.wdog: use WDOG_B to reboot.
  imx2-wdt 20c0000.wdog: timeout 60 sec (nowayout=0)
  device-mapper: uevent: version 1.0.3
  device-mapper: ioctl: 4.31.0-ioctl (2015-3-12) initialised: dm-devel@redhat.com
  usb 1-1.3: New USB device found, idVendor=0bda, idProduct=b720
  usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  usb 1-1.3: Product: 802.11n WLAN Adapter
  Bluetooth: HCI UART driver ver 2.3
  Bluetooth: HCI UART protocol H4 registered
  Bluetooth: HCI UART protocol BCSP registered
  Bluetooth: HCI UART protocol ATH3K registered
  usbcore: registered new inte**ce driver btusb
  sdhci: Secure Digital Host Controller Inte**ce driver
  sdhci: Copyright(c) Pierre Ossman
  sdhci-pltfm: SDHCI platform and OF driver helper
  /soc/aips-bus@02100000/usdhc@02194000: voltage-ranges unspecified
  sdhci-esdhc-imx 2194000.usdhc: Got CD GPIO
  sdhci-esdhc-imx 2194000.usdhc: No vmmc regulator found
  sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found
  usb 1-1.3: Manufacturer: Realtek
  mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
  /soc/aips-bus@02100000/usdhc@02198000: voltage-ranges unspecified
  sdhci-esdhc-imx 2198000.usdhc: Got CD GPIO
  sdhci-esdhc-imx 2198000.usdhc: Got WP GPIO
  sdhci-esdhc-imx 2198000.usdhc: No vmmc regulator found
  sdhci-esdhc-imx 2198000.usdhc: No vqmmc regulator found
  usb 1-1.3: SerialNumber: 00e04c000001
  mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
  /soc/aips-bus@02100000/usdhc@0219c000: voltage-ranges unspecified
  sdhci-esdhc-imx 219c000.usdhc: No vmmc regulator found
  sdhci-esdhc-imx 219c000.usdhc: No vqmmc regulator found
  mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
  mxc_vpu 2040000.vpu_fsl: VPU initialized
  mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
  mxc_hdmi_cec soc:hdmi_cec@00120000: HDMI CEC initialized
  Galcore version 5.0.11.41671
  mmc3: MAN_BKOPS_EN bit is not set
  mmc3: new DDR MMC card at address 0001
  mmcblk3: mmc3:0001 Q2J55L 7.09 GiB
  mmcblk3boot0: mmc3:0001 Q2J55L partition 1 16.0 MiB
  mmcblk3boot1: mmc3:0001 Q2J55L partition 2 16.0 MiB
  mmcblk3rpmb: mmc3:0001 Q2J55L partition 3 4.00 MiB
  mmcblk3: p1 p2 p3 《 p5 p6 p7 p8 p9 p10 》 p4
  caam 2100000.caam: Entropy delay = 3200
  caam 2100000.caam: Instantiated RNG4 SH0
  caam 2100000.caam: Instantiated RNG4 SH1
  caam 2100000.caam: device ID = 0x0a16010000000000 (Era -524)
  caam 2100000.caam: job rings = 2, qi = 0
  caam algorithms registered in /proc/crypto
  caam_jr 2101000.jr0: registering rng-caam
  platform caam_sm: blkkey_ex: 4 keystore units available
  platform caam_sm: 64-bit clear key:
  platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
  platform caam_sm: 64-bit black key:
  platform caam_sm: [0000] e1 a2 22 7c 83 af 4e 10
  platform caam_sm: [0008] 62 98 d0 d7 af 69 96 b1
  platform caam_sm: 128-bit clear key:
  platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
  platform caam_sm: 128-bit black key:
  platform caam_sm: [0000] 6c fb b8 86 bd 58 50 e7
  platform caam_sm: [0008] 2d 8c c2 65 6e ed 65 33
  platform caam_sm: 192-bit clear key:
  platform caam_sm: [0016] 10 11 12 13 14 15 16 17
  platform caam_sm: 192-bit black key:
  platform caam_sm: [0000] 03 5e 23 35 79 36 5c ef
  platform caam_sm: [0008] 6f d0 5e d5 fe fd 54 2d
  platform caam_sm: [0016] df ac c0 68 99 e1 96 de
  platform caam_sm: [0024] db 5f 1c 1f e8 5e 67 3f
  platform caam_sm: 256-bit clear key:
  platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
  platform caam_sm: 256-bit black key:
  platform caam_sm: [0000] e6 4b 5f 86 50 f4 d1 e7
  platform caam_sm: [0008] ec 97 07 58 7d 80 6a 7f
  platform caam_sm: [0016] 45 b8 d6 1b 3b 6e 15 b3
  platform caam_sm: [0024] 6f a4 62 3a 94 3b f9 0e
  platform caam_sm: 64-bit unwritten blob:
  platform caam_sm: [0000] 00 00 00 00 00 00 00 00
  platform caam_sm: [0008] 00 00 00 00 00 00 00 00
  platform caam_sm: [0016] 00 00 00 00 00 00 00 00
  platform caam_sm: [0024] 00 00 00 00 00 00 00 00
  platform caam_sm: [0032] 00 00 00 00 00 00 00 00
  platform caam_sm: [0040] 00 00 00 00 00 00 00 00
  platform caam_sm: [0048] 00 00 00 00 00 00 00 00
  platform caam_sm: [0056] 00 00 00 00 00 00 00 00
  platform caam_sm: [0064] 00 00 00 00 00 00 00 00
  platform caam_sm: [0072] 00 00 00 00 00 00 00 00
  platform caam_sm: [0080] 00 00 00 00 00 00 00 00
  platform caam_sm: [0088] 00 00 00 00 00 00 00 00
  platform caam_sm: 128-bit unwritten blob:
  platform caam_sm: 196-bit unwritten blob:
  platform caam_sm: 256-bit unwritten blob:
  platform caam_sm: 64-bit black key in blob:
  platform caam_sm: [0000] eb 12 81 7c 06 e4 56 c2
  platform caam_sm: [0008] 1f 3f 4b 61 f6 87 48 fc
  platform caam_sm: [0016] 7f 73 6f 38 7f df ba 35
  platform caam_sm: [0024] b7 f9 ad e3 27 9d 45 1b
  platform caam_sm: [0032] a4 8e 6f ad 91 63 26 7e
  platform caam_sm: [0040] 44 d0 d2 87 75 04 43 10
  platform caam_sm: [0048] bc 4d f2 c4 02 b7 56 dd
  platform caam_sm: 128-bit black key in blob:
  platform caam_sm: [0000] d0 5e 40 96 65 d8 2e 6d
  platform caam_sm: [0008] 91 e9 e8 2e 62 e6 0a da
  platform caam_sm: [0016] 90 7a 30 5f 7e 68 09 93
  platform caam_sm: [0024] 10 7b 6f d1 72 97 55 bc
  platform caam_sm: [0032] 76 f0 f0 65 75 d1 71 1c
  platform caam_sm: [0040] e4 a3 bd 2d ae ce ff 08
  platform caam_sm: [0048] bc 97 c2 35 dd 64 d9 ea
  platform caam_sm: [0056] a1 b3 6e fb b7 eb 9d 51
  platform caam_sm: 192-bit black key in blob:
  platform caam_sm: [0000] b2 c4 00 a7 0a 07 e5 72
  platform caam_sm: [0008] d1 f1 eb 41 d4 e0 ec b3
  platform caam_sm: [0016] 8e ea d7 81 e7 cf 07 2f
  platform caam_sm: [0024] b9 67 a0 9b 43 d9 ae 3a
  platform caam_sm: [0032] af cf 4e c8 10 af 99 fd
  platform caam_sm: [0040] eb 41 b4 3e d5 77 99 2d
  platform caam_sm: [0048] e9 8d f6 94 53 5e 4f a8
  platform caam_sm: [0056] e9 ca b6 f0 a8 7e 47 1f
  platform caam_sm: [0064] 6d d5 de 67 c8 b5 01 6c
  platform caam_sm: 256-bit black key in blob:
  platform caam_sm: [0000] e2 f1 8c fc 55 be 90 11
  platform caam_sm: [0008] 2d a8 3f bd a9 ba 32 64
  platform caam_sm: [0016] df 34 d1 c7 bf 6c 7e 25
  platform caam_sm: [0024] 6e a0 9e b2 34 5d a5 46
  platform caam_sm: [0032] 9d 73 20 ad e2 58 b0 b8
  platform caam_sm: [0040] 92 e5 a7 71 a4 d0 82 06
  platform caam_sm: [0048] 74 cc 84 53 b7 84 0c 55
  platform caam_sm: [0056] ab 33 8b 7c 1e ca b5 19
  platform caam_sm: [0064] 86 5e 22 ce b9 fb 9b 65
  platform caam_sm: [0072] 43 25 5c 78 c7 bf da 9c
  platform caam_sm: restored 64-bit black key:
  platform caam_sm: [0000] 0a b4 e4 fe b7 0e 30 c3
  platform caam_sm: [0008] 93 e4 ae 97 c5 43 0e 57
  platform caam_sm: restored 128-bit black key:
  platform caam_sm: restored 192-bit black key:
  platform caam_sm: [0016] c5 71 24 9b 07 b1 b1 0f
  platform caam_sm: [0024] c3 2c 00 df 8c a5 69 ba
  platform caam_sm: restored 256-bit black key:
  snvs-secvio 20cc000.caam-snvs: can‘t get snvs clock
  snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
  caam_keyblob caam_keyblob: caam keyblob initialized
  hidraw: raw HID events driver (C) Jiri Kosina
  usbcore: registered new inte**ce driver usbhid
  usbhid: USB HID core driver
  ashmem: initialized
  usbcore: registered new inte**ce driver snd-usb-audio
  fsl-asrc 2034000.asrc: driver registered
  fsl-hdmi-dai soc:hdmi_audio@00120000: failed to probe. Load HDMI-video first.
  fsl-hdmi-dai: probe of soc:hdmi_audio@00120000 failed with error -12
  imx-wm8960 sound: wm8960-hifi 《-》 202c000.ssi mapping ok
  imx-wm8960 sound: snd-soc-dummy-dai 《-》 2034000.asrc mapping ok
  imx-audio-hdmi sound-hdmi: initialize HDMI-audio failed. load HDMI-video first!
  NET: Registered protocol family 26
  u32 classifier
  Actions configured
  Netfilter messages via NETLINK v0.30.
  nf_conntrack version 0.5.0 (15927 buckets, 63708 max)
  ctnetlink v0.93: registering with nfnetlink.
  xt_time: kernel timezone is -0000
  ip_tables: (C) 2000-2006 Netfilter Core Team
  arp_tables: (C) 2002 David S. Miller
  Initializing XFRM netlink socket
  NET: Registered protocol family 10
  mip6: Mobile IPv6
  ip6_tables: (C) 2000-2006 Netfilter Core Team
  sit: IPv6 over IPv4 tunneling driver
  NET: Registered protocol family 17
  NET: Registered protocol family 15
  can: controller area network core (rev 20120528 abi 9)
  NET: Registered protocol family 29
  can: raw protocol (rev 20120528)
  can: broadcast manager protocol (rev 20120528 t)
  can: netlink gateway (rev 20130117) max_hops=1
  Bluetooth: RFCOMM TTY layer initialized
  Bluetooth: RFCOMM socket layer initialized
  Bluetooth: RFCOMM ver 1.11
  Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  Bluetooth: BNEP filters: protocol multicast
  Bluetooth: BNEP socket layer initialized
  Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
  Bluetooth: HIDP socket layer initialized
  8021q: 802.1Q VLAN Support v1.8
  Key type dns_resolver registered
  pwm-backlight supply power not found, using dummy regulator
  input: gpio-keys as /devices/soc0/gpio-keys/input/input3
  rtc-rx8010 2-0032: setting system clock to 2018-12-03 06:37:51 UTC (1543819071)
  SW4: disabling
  wlreg_on: disabling
  CAN XCVR: disabling
  hdmi-5v-supply: disabling
  sensor-supply: disabling
  usb_otg_vbus: disabling
  ALSA device list:
  #0: wm8960-audio
  Freeing unused kernel memory: 1024K (c1000000 - c1100000)
  init: init started!
  SELinux: Android master kernel running Android M policy in compatibility mode.
  SELinux: Permission audit_read in class capability2 not defined in policy.
  SELinux: the above unknown classes and permissions will be denied
  audit: type=1403 audit(1543819071.630:2): policy loaded auid=4294967295 ses=4294967295
  audit: type=1404 audit(1543819071.650:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
  init: (Initializing SELinux enforcing took 0.14s.)
  init: init second stage started!
  init: waitpid failed: No child processes
  init: property_set(“ro.zygote”, “zygote32”) failed
  init: (Loading properties from /default.prop took 0.01s.)
  init: (Parsing /init.environ.rc took 0.00s.)
  init: (Parsing /init.usb.rc took 0.00s.)
  init: (Parsing init.freescale.usb.rc took 0.00s.)
  init: (Parsing init.freescale.i.MX6Q.rc took 0.00s.)
  init: (Parsing /init.freescale.rc took 0.01s.)
  init: (Parsing /init.usb.configfs.rc took 0.00s.)
  init: (Parsing /init.zygote32.rc took 0.00s.)
  init: (Parsing /init.trace.rc took 0.00s.)
  init: (Parsing /init.rc took 0.04s.)
  init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
  init: Starting service ’ueventd‘。..
  init: Waiting for /dev/.coldboot_done.。.
  ueventd: ueventd started!
  ueventd: Coldboot took 0.35s.
  init: Waiting for /dev/.coldboot_done took 0.37s.
  init: write_file: Unable to open ’/proc/sys/kernel/sched_compat_yield‘: No such file or directory
  init: write_file: Unable to write to ’/dev/cpuctl/cpu.shares‘: Invalid argument
  init: write_file: Unable to open ’/proc/sys/abi/swp‘: No such file or directory
  init: Starting service ’watchdogd‘。..
  Console: switching to colour dummy device 80x30
  watchdogd: watchdogd started (interval 10, margin 20)!
  fs_mgr: Enabling dm-verity for system (mode 0)
  EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: barrier=1
回帖(2)
王静
2022-11-28 16:48:26
  • 您这边烧写的是我们的标准镜像吗,是否按照我们手册上流程来烧写的
举报
陈小红
2022-11-28 16:48:31
  • 是用mfgtools烧写的标准镜像,手册参考的是:OKMX6X-C-Android_6.0用户手册-V1.0-2018-08-20
举报
更多回帖
