1 板载25N01G 128MB spi flash
分三个区 8M系统、56M保留、64M用于uffs文件系统(挂载到/mnt/filesystem)
//boad_dev.c
struct rt_mtd_nand_device mtd_partitions[MTD_SPINAND_PARTITION_NUM] =
[0] =
{//128k * 64 = 8388608(0x800000=8M) rt-thread,uboot,...
.block_start = 0,
.block_end = 63,
.block_total = 64,
[1] =
{//56M, reserved
.block_start = 64,
.block_end = 511,
.block_total = 448,
[2] =
{//64M, uffs
.block_start = 512,
.block_end = 1023,
.block_total = 512,
//fal_cfg.h
/* partition table------------------------------------------------------------ /
#define FAL_PART_TABLE
{FAL_PART_MAGIC_WORD, "rtthread", FAL_USING_NOR_FLASH_DEV_NAME, 0, 810241024, 0},
{FAL_PART_MAGIC_WORD, "filesystem", FAL_USING_NOR_FLASH_DEV_NAME, 6410241024, 281024*1024, 0},
//mnt.c
const struct dfs_mount_tbl mount_table[] =
{ RAMDISK_UDC, "/mnt/ram_usbd", "elm", 0, RT_NULL },
#if defined(RT_USING_DFS_UFFS)
{ "nand2", "/mnt/filesystem", "uffs", 0, RT_NULL },
#endif
{0},
#endif
原厂例子是分为4M和12M,可能是考虑有些板载W25Q128(16MB spi nor flash).
2 烧录FLASH
参照官方文档 (NuMaker NUC980 IIoT User Manual.pdf), 除rt-thread.bin文件外,其它位于BSP/uboot目录中。
首先选择USB启动,启动nuwriter。
2.0 擦除整片FLASH
2.1 u-boot-spl.bin
2.2 u-boot.bin
2.3 rt-thread.bin
注意图中的980uimage.bin是linux镜像,改为编译好的rt-thread.bin
2.4 env.txt 启动脚本
baudrate=115200
bootdelay=1
stderr=serial
stdin=serial
stdout=serial
loadrtt=nand read 0x80000000 0x200000 0x600000
bootcmd=run loadrtt;go 0x0
3 SPI nand启动rt-thread
切换到SPI启动模式,reset或重新上电。以后烧录只要把rt-thread占用的空间擦除,见下图
然后重新烧录rt-thread.bin即可,其它不需要重新烧录。
4 SPI Flash 25N01G分区说明
block 0-3(512kB) u-boot-spl
block 4(128kB) env.txt
block 8-15(1MB) u-boot
block 16-63(6MB) rt-thread, 这部分看情况扩展
block 64-511(56MB) reserved
block 512-1024(64MB) uffs文件系统
原作者:lg28870983
更多回帖
