ARM技术论坛
直播中
h1654155275.5916
8年用户 994经验值
私信 关注
[经验]
聆思6011a开发板运行手写体识别并驱动SPI LCD显示
官方暂时未开放模型编译器,先移植下TinyMAXI,跑下手写题识别并用LCD显示。
1.移植下TinyMAXI
将TinyMAXI的文件放入src目录下,并添加修改到cmaklists.txt文件中,6011a支持smid指令,可加速运行神经网络。
测试代码如下
TM_DBGT_INIT();
    TM_PRINTF("mnist demo\n");
    tm_mdl_t mdl;
    for(int i=0; i<28*28; i++){
        TM_PRINTF("%3d,", mnist_pic[i]);
        if(i%28==27)TM_PRINTF("\n");
    tm_mat_t in_uint8 = {3,28,28,1, {(mtype_t*)mnist_pic}};
    tm_mat_t in = {3,28,28,1, {NULL}};
    tm_mat_t outs[1];
    tm_err_t res;
    tm_stat((tm_mdlbin_t*)mdl_data);
    res = tm_load(&mdl, mdl_data, NULL, layer_cb, &in);
    if(res != TM_OK) {
        TM_PRINTF("tm model load err %d\n", res);
        return ;
#if (TM_MDL_TYPE == TM_MDL_INT8) || (TM_MDL_TYPE == TM_MDL_INT16)
    res = tm_preprocess(&mdl, TMPP_UINT2INT, &in_uint8, &in);
#else
    res = tm_preprocess(&mdl, TMPP_UINT2FP01, &in_uint8, &in);
#endif
    //TM_DBGT_START();
    res = tm_run(&mdl, &in, outs);
    //TM_DBGT("tm_run");
    if(res==TM_OK) parse_output(outs);
    else TM_PRINTF("tm run error: %d\n", res);
    tm_unload(&mdl);
串口输出结果如图
2.SPI LCD
首先prj.conf文件开启spi功能,设置CONFIG_SPI=y,然后,修改配置I/O口,6011a SPI1默认关闭,这里使用SPI0,如图管脚配置:
设备驱动代码如下:
spi速率可达到100M,非常快。
const struct device *dev0;
const struct device* dev1 ;
static struct spi_config spi_cfg = {
    .operation = SPI_WORD_SET(8)| SPI_OP_MODE_MASTER|SPI_TRANSFER_MSB|SPI_LINES_SINGLE,        //设置一次传输8BIT,以及当前SPI为主设备
    .slave = 0,                                                //选择第0个设备
    .frequency = 100000000U,                                    //设置通讯频率
void LCD_GPIO_Init(void)
   dev0=device_get_binding("GPIO_A");
   dev1= device_get_binding("SPI_0");
   if(dev1 == NULL){
        printk("ERR: No Device Drivers!\n");
        return;
    //check device
    if(!device_is_ready(dev1)){
        printk("ERR: Device Was Not Ready - %s\n",dev1->name);
        return;
  (void)gpio_pin_configure(dev0,14,(GPIO_OUTPUT|GPIO_PULL_UP));
  (void)gpio_pin_configure(dev0,15,(GPIO_OUTPUT|GPIO_PULL_UP));
  (void)gpio_pin_configure(dev0,16,(GPIO_OUTPUT|GPIO_PULL_UP));
  (void)gpio_pin_configure(dev0,13,(GPIO_OUTPUT|GPIO_PULL_UP));
原作者:zhai
更多回帖
