void Th10sUart::buildSensorStatus(diagnostic_updater::DiagnosticStatusWrapper &stat)
if (!serial_->isOpen())
stat.summary(diagnostic_msgs::DiagnosticStatus::ERROR, "IO error");
else
stat.summary(diagnostic_msgs::DiagnosticStatus::OK, "formaldehyde is ok");
void Th10sUart::updateDiagnostics()
int max_count = output_hz_;
diag_count_++;
if (diag_count_ >= max_count)
diag_count_ = 0;
diagnostic_updater_.update();
uint16_t Th10sUart::check_crc(const uint8_t *data, uint8_t len)
int i,j;
uint16_t crc = 0xffff;
for(i = 0; i < len - 2; i++)
crc ^= data[i];
for(j = 0; j < 8; j++)
if(crc & 0x01)
crc = crc >> 1;
crc = crc ^ 0xa001;
else
crc = crc >> 1;
return crc;
bool Th10sUart::is_check_crc(uint8_t *data, uint8_t len)
uint16_t crc_data = (uint16_t)data[len - 1] << 8| data[len -2];
if(check_crc(data, len) == crc_data)
return true;
return false;
void Th10sUart::update(const ros::TimerEvent& e)
if (serial_->isOpen())
uint8_t write_buffer[write_buffer_size] =
{0x10, 0x03, 0x00, 0x00, 0x00, 0x02, 0xc7, 0x4a};
uint8_t read_buffer[read_buffer_size];
serial_->write(write_buffer, write_buffer_size);
ros::Duration(0.25).sleep();
size_t n = serial_->available();
if ( n != 0)
serial_->read(read_buffer, read_buffer_size);
int16_t humid,thermo;
for(int i = 0; i< read_buffer_size; i++)
ROS_INFO("DATA[%d]: %02x", i, read_buffer[i]);
if (!is_check_crc(read_buffer, read_buffer_size))
return;
thermo = (int16_t)(((uint16_t)read_buffer[3] << 8)| read_buffer[4]);
humid = (int16_t)(((uint16_t)read_buffer[5] << 8) | read_buffer[6]);
std_msgs::Float64 msg;
msg.data = (double)thermo/10.0;//*1.25;
thermo_pub_.publish(msg);
msg.data = (double)humid/10.0;//*1.25;
humid_pub_.publish(msg);
else
int max_count = output_hz_ * 5;
open_count_++;
if (open_count_ >= max_count)
open_count_ = 0;
try
serial_->open();
catch (std::exception &e)
ROS_WARN("open serial port failed");
updateDiagnostics();
更多回帖
