RK系列开发板音频驱动DAI、DMA、Codec、HCS适配完成之后,需要进行编译,验证驱动是否可用。而操作步骤,主要是指导开发者,如何正确使用音频驱动,通过命令来控制音频文件的播放等。
步骤:
CONFIG_DRIVERS_HDF_AUDIO_RK系列开发板=y
config DRIVERS_HDF_AUDIO_RK系列开发板
bool "Enable HDF Audio Codec driver"
default y
depends on DRIVERS\_HDF\_AUDIO
help
Answer Y to choice HDF Audio Codec driver\.
KHDF_AUDIO_BASE_ROOT_DIR = ../../../../../../../..
KHDF_AUDIO_RK系列开发板_DIR = $(KHDF_AUDIO_BASE_ROOT_DIR)/device/rockchip/RK系列开发板/audio
KHDF_AUDIO_KHDF_ROOT_DIR = drivers/hdf/khdf
KHDF_FRAMEWORK_ROOT_DIR = drivers/hdf/framework
KHDF_AUDIO_RK系列开发板_INC_DIR = $(KHDF_FRAMEWORK_ROOT_DIR)/../../device/rockchip/RK系列开发板/audio
obj-$(CONFIG_DRIVERS_HDF_AUDIO_RK系列开发板) += \
$\(KHDF\_AUDIO\_RK系列开发板\_DIR\)/soc/src/RK系列开发板\_dma\_ops\.o \
$\(KHDF\_AUDIO\_RK系列开发板\_DIR\)/soc/src/RK系列开发板\_dma\_adapter\.o \
$\(KHDF\_AUDIO\_RK系列开发板\_DIR\)/dai/src/RK系列开发板\_dai\_adapter\.o \
$\(KHDF\_AUDIO\_RK系列开发板\_DIR\)/dai/src/RK系列开发板\_dai\_ops\.o \
$\(KHDF\_AUDIO\_RK系列开发板\_DIR\)/codec/src/es8388\_codec\_adapter\.o \
$\(KHDF\_AUDIO\_RK系列开发板\_DIR\)/codec/src/es8388\_codec\_ops\.o
ccflags-$(CONFIG_DRIVERS_HDF_AUDIO_RK系列开发板) += -lm -lc -lgcc -std=gnu99 -Werror \
\-I$\(srctree\)/$\(KHDF\_AUDIO\_KHDF\_ROOT\_DIR\)/osal/include \
\-I$\(srctree\)/$\(KHDF\_FRAMEWORK\_ROOT\_DIR\)/include/core \
\-I$\(srctree\)/$\(KHDF\_FRAMEWORK\_ROOT\_DIR\)/include/utils \
\-I$\(srctree\)/$\(KHDF\_FRAMEWORK\_ROOT\_DIR\)/include/osal \
\-I$\(srctree\)/$\(KHDF\_FRAMEWORK\_ROOT\_DIR\)/include/platform \
\-I$\(srctree\)/$\(KHDF\_FRAMEWORK\_ROOT\_DIR\)/include/audio \
\-I$\(srctree\)/$\(KHDF\_FRAMEWORK\_ROOT\_DIR\)/ability/sbuf/include \
\-I$\(srctree\)/$\(KHDF\_FRAMEWORK\_ROOT\_DIR\)/core/common/include/host \
\-I$\(srctree\)/$\(KHDF\_FRAMEWORK\_ROOT\_DIR\)/model/audio/core/include \
\-I$\(srctree\)/$\(KHDF\_FRAMEWORK\_ROOT\_DIR\)/model/audio/sapm/include \
\-I$\(srctree\)/$\(KHDF\_FRAMEWORK\_ROOT\_DIR\)/model/audio/dispatch/include \
\-I$\(srctree\)/$\(KHDF\_FRAMEWORK\_ROOT\_DIR\)/model/audio/common/include \
\-I$\(srctree\)/bounds\_checking\_function/include \
\-I$\(srctree\)/$\(KHDF\_AUDIO\_RK系列开发板\_INC\_DIR\)/soc/include \
\-I$\(srctree\)/$\(KHDF\_AUDIO\_RK系列开发板\_INC\_DIR\)/dai/include \
\-I$\(srctree\)/$\(KHDF\_AUDIO\_RK系列开发板\_INC\_DIR\)/codec/include
步骤:
录音Demo当前默认使用的是外置Codec。
总结:
通过编译配置、并执行make_kernel.sh命令,最后生成镜像文件 boot.img,通过烧录工具烧录,即可验证驱动。RK系列开发板音频驱动适配指南,从DAI驱动适配、DMA的驱动适配到到编译内核以及本文的操作步骤指导,掌握了核心代码和步骤,更深入了解了驱动适配的整个过程。一整套流程下来,就可以适配RK系列开发板音频驱动了。也希望在今后,能有更多的精彩内容分享给大家,谢谢!
更多回帖
