SDK切换存储介质需要修改board.dts、sys_config.fex、内核配置、TINA系统配置。另外,在spinor 存储介质下,通过 u-boot-sun8iw21p1.bin 进行烧录,u-boot-spinor-sun8iw21p1.bin 启动,使用sys_partition_nor.fex作为分区表。在非spinor介质(spinand、emmc、sdnand),通过u-boot-sun8iw21p1.bin进行烧录和启动,使用sys_partition.fex作为分区表。下文将介绍spinor切换spinand、spinand切换spinor、spinor切换emmc、spinor切换sdnand四种切换方式。
[target]
storage_type = xxx
其中storage_type | 0:nand | 1:sd | 2:emmc | 3:spinor | 4:emmc3 | 5:spinand | 6:sd1 |
[target]
- storage_type = 3
+ storage_type = 5
&spi0 {
- status = "disabled";
+ status = "okay";
spi-nand@0 {
- status="disabled";
+ status="okay";
编译u-boot-sun8iw21p1.bin,spinand使用u-boot-sun8iw21p1.bin进行烧录、启动。
cboot切换到uboot目录,编辑configs/sun8iw21p1_defconfig
CONFIG_SUNXI_UBIFS=y //SDK发布默认已选上
执行mboot //编译
确保device/config/chips/vxxx/bin/u-boot-sun8iw21p1.bin已更新
make kernel_menuconfig 层层选中
内核驱动配置
Device Driver --->
Memory Technology Device (MTD) support --->
sunxi-nand --->
<*> AWNAND CHOICE (Allwinner MTD SPINAND Device Support) --->
-*- Enable UBI - Unsorted block images --->
[*] Read-only block devices on top of UBI volumes
内核文件系统配置
File systems --->
[*] Miscellaneous filesystems --->
<*> UBIFS file system support
make menuconfig 层层选中
Target Images --->
Boot (SD Card) Kernel format (boot.img) ---> //默认选中
[ ] For storage less than 32M, enable this when using ota //取消勾选
Global build settings --->
[*] Strip unnecessary functions from libraries //取消勾选
Utilities --->
<*> mtd-utils --->
<*> mtd-utils-mkfs.ubifs
切换部分原文链接:https://bbs.aw-ol.com/topic/1701/
[target]
- storage_type = 5
+ storage_type = 3
&spi0 {
- status = "okay";
+ status = "disabled";
spi-nand@0 {
- status="okay";
+ status="disabled";
内核驱动配置
Device Driver --->
sunxi-nand ---> //取消勾选
Self-contained MTD device drivers --->
<*> Support most SPI Flash chips (AT26DF, M25P, W25X, ...) //确认已选中
<*> SPI-NOR device support --->
内核文件系统配置
File systems --->
<*> Journalling Flash File System v2 (JFFS2) support
Target Images --->
[*] For storage less than 32M, enable this when using ota //选中
[*] Strip unnecessary functions from libraries //选中
Utilities --->
<*> mtd-utils
<*> mtd-utils-mkfs.jffs2 //选中
[target]
- storage_type = 3
+ storage_type = 2
[*] Enable the block layer --->
[*] Support for large (2TB+) block devices and files
[*] Block layer SG support v4
Device Drivers --->
< > Memory Technology Device (MTD) support ---> //取消勾选
[*] Block devices ---> //确认勾选
File systems --->
<*> The Extended 4 (ext4) filesystem
Target Images --->
[ ] Strip unnecessary functions from libraries //取消勾选
Utilities --->
Filesystem --->
<*> e2fsprogs //选中
[target]
- storage_type = 3
+ storage_type = 1
&sdc2 {
non-removable;
bus-width = <8>;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
mmc-hs400-1_8v;
no-sdio;
- no-sd;
+ //no-sd;
ctl-spec-caps = <0x308>;
cap-mmc-highspeed;
sunxi-power-save-mode;
sunxi-dis-signal-vol-sw;
max-frequency = <100000000>;
vmmc-supply = <®_dcdc1>;
/*emmc io vol 3.3v*/
vqmmc-supply = <®_bldo1>;
/*emmc io vol 1.8v*/
/*vqmmc-supply = <®_eldo1>;*/
Device Drivers --->
File systems --->
Target Images --->
Utilities --->
Filesystem --->
<*> e2fsprogs //选中
Tina 一般支持nor, nand, mmc 三种介质。
更具体的,nand分为并口nand和spinand,mmc分emmc和sd卡
主要需要区分的是nor和其他介质,因为需要打包的部分有所不同。
即,emmc和nand,sd卡一般可共用一份固件,而nor则需使用另一份固件
在sys_config中有一个配置项,storage_type,取值及含义如下
; storage_type 0:nand 1:sd 2:emmc 3:spinor 4:emmc3 5:spinand 6:sd1
[target]
storage_type = xxx
对于nor的方案,必须配置为
storage_type = 3
对于其他介质,storage_type则不能配置为3
sys_config 设置介质为nor
[target]
storage_type = 3
配置所用nor的大小
[norflash]
size = 16
内核配置
make kernel_menuconfig --->
Device Drivers --->
< >Block devices (取消选中)
Device Drivers --->
<*>Memory Technology Device (MTD) support
<*>OpenFirmware partitioning information support
<*>SUNXI partitioning support
<*> Caching block device access to MTD devices
<*> SPI-NOR device support (对于linux4.9,先选这个,下面的选项才出现)
File systems --->
< > The Extended 4 (ext4) filesystem(取消选中)
File systems --->
<*> Journalling Flash File System v2 (JFFS2) support(选中)
[ ] Support for large (2TB+) block devices and files(取消选中)
menuconfig配置
make menuconfig --->
Utilities --->
<*> mtd-utils (选择) --->
Utilities --->
Filesystem --->
< > e2fsprogs(取消选择)
sys_config 设置介质为spinand
[target]
storage_type = 5
内核配置
Device Drivers --->
[*]Block devices --->
<*> sunxi nand flash driver
Device Drivers --->
< >Memory Technology Device (MTD) support(取消选择)
File systems --->
menuconfig 配置
Utilities --->
< > mtd-utils (取消选择)
Filesystem --->
<*> e2fsprogs
分区表配置
注意点
对于nand,rootfs_data分区,使用ext4格式。分配太小的话可能会创建失败。
使用mkfs.ext4等工具的时候出现
/usr/sbin/fsck.ext4 -y /dev/by-name/rootfs_data
Error loading shared library /home/wuguanling/workspace/project/v316-sdv-tina/out/v316-sdv/staging_dir/target/rootfs/lib/libc.so: No such file or directory (needed by /usr/lib/libext2fs.so.2)
关闭以下选项:
make menuconfig
| --- Global build settings
| --- []strip unnecessary functions for libraries
作者@YterAA
更多回帖
