ARM技术论坛
直播中
HonestQiao
9年用户 577经验值
擅长:嵌入式技术
私信 关注
[经验]
【触觉智能 Purple Pi开发板试用】用简单实用的LCD1602显示IP
LCD1602
在另外一个项目中,无头联网设备需要显示当前的设备的IP地址,方便操作,所以用了一块LCD1602来显示。
因为LCD1602的使用非常简单,所以很方便的就能在Purple Pi开发板上使用。
LCD1602就是两行字符,每行16个,控制指令非常简单明了。
我手头的这块LCD1602已经添加了I2C模块:
所以,可以直接I2C接口来发送数据进行控制。
I2C接口的具体位置,可以查看背面丝印:
最下面,就有I2C0的接口,把LCD1602-IIC直接接上开干。
从这块板子的I2C模块上,可以看到A0、A1、A2都没有连接:
那么根据datasheet,可以得到其地址:
三开,所以地址就是0x0f了
我买的这个LCD1602,店家直接提供了标准的Linux下的驱动库程序:
  • lcd1602.h:
#ifndef LCD1602_H
#define LCD1602_H
// LCD1602 2 line by 16 character LCD library
// Written by Larry Bank - 12/6/2017
// Copyright (c) 2017 BitBank Software, Inc.
// bitbank@pobox.com
// This program is free software: you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation, either version 3 of the License, or
// (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program.  If not, see <http://www.gnu.org/licenses/>.
// Opens a file system handle to the I2C device
// Turns on the LCD, sets the 4-bit mode and clears the memory
// Returns 0 for success, 1 for failure
int lcd1602Init(int iChannel, int iAddr);
// Set the LCD Pulse Period
void lcd1602SetPulsePeriod(int val);
// Set the cursor position on the LCD
int lcd1602SetCursor(int x, int y);
// Control the backlight, cursor, and blink
int lcd1602Control(int bBacklight, int bCursor, int bBlink);
// Print a zero-terminated character string
// Only 1 line at a time can be accessed
int lcd1602WriteString(char *szText);
// Clear the characters from the LCD
int lcd1602Clear(void);
// Turn off the LCD and backlight
// close the I2C file handle
void lcd1602Shutdown(void);
#endif // LCD1602_H
  • lcd1602.c
// 2x16 LCD display (HD44780 controller + I2C chip)
// Copyright (c) BitBank Software, Inc.
// Project started 12/6/2017
#include <unistd.h>
#include <stdio.h>
#include <string.h>
#include <stdint.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/types.h>
#include <linux/i2c-dev.h>
// The LCD controller is wired to the I2C port expander with the upper 4 bits
// (D4-D7) connected to the data lines and the lower 4 bits (D0-D3) used as
// control lines. Here are the control line definitions:
// Command (0) / Data (1) (aka RS) (D0)
// R/W                             (D1)
// Enable/CLK                      (D2)
// Backlight control               (D3)
// The data must be manually clocked into the LCD controller by toggling
// the CLK line after the data has been placed on D4-D7
#define PULSE_PERIOD 500
#define CMD_PERIOD 4100
#define BACKLIGHT 8
#define DATA 1
static int iBackLight = BACKLIGHT;
static int file_i2c = -1;
static int iPulsePeriod = PULSE_PERIOD;
static int lcd1602_write(int file_i2c_hd, const void *buf, size_t len)
	// int j;
	// for(j = 0; j < len; ++j)
	// 	printf("HEX: %02x\n", ((uint8_t*) buf)[j]);
	int ret = write(file_i2c_hd, buf, len);
	return ret;
static void lcd1602_writeCommand(unsigned char ucCMD)
	unsigned char uc;
	uc = (ucCMD & 0xf0) | iBackLight; // most significant nibble sent first
	lcd1602_write(file_i2c, &uc, 1);
	usleep(iPulsePeriod); // manually pulse the clock line
	uc |= 4;			  // enable pulse
	uc &= ~4; // toggle pulse
	usleep(CMD_PERIOD);
	uc = iBackLight | (ucCMD << 4); // least significant nibble
	usleep(CMD_PERIOD);
} /* lcd1602_writeCommand() */
// The cursor is an underline and is separate and distinct
// from the blinking block option
	unsigned char ucCMD = 0xc; // display control
	if (file_i2c < 0)
		return 1;
	iBackLight = (bBacklight) ? BACKLIGHT : 0;
	if (bCursor)
		ucCMD |= 2;
	if (bBlink)
		ucCMD |= 1;
	lcd1602_writeCommand(ucCMD);
	return 0;
} /* lcd1602Control() */
// lcd1602_write an ASCII string (up to 16 characters at a time)
int lcd1602WriteString(char *text)
	unsigned char ucTemp[2];
	int i = 0;
	if (file_i2c < 0 || text == NULL)
		return 1;
	while (i < 16 && *text)
		ucTemp[0] = iBackLight | DATA | (*text & 0xf0);
		lcd1602_write(file_i2c, ucTemp, 1);
		ucTemp[0] |= 4; // pulse E
		ucTemp[0] &= ~4;
		ucTemp[0] = iBackLight | DATA | (*text << 4);
		ucTemp[0] &= ~4;
		usleep(CMD_PERIOD);
		text++;
		i++;
	return 0;
} /* lcd1602_writeString() */
// Erase the display memory and reset the cursor to 0,0
	if (file_i2c < 0)
		return 1;
	lcd1602_writeCommand(0x0E); // clear the screen
	return 0;
} /* lcd1602Clear() */
// Open a file handle to the I2C device
// Set the controller into 4-bit mode and clear the display
// returns 0 for success, 1 for failure
	char szFile[32];
	int rc;
	sprintf(szFile, "/dev/i2c-%d", iChannel);
	file_i2c = open(szFile, O_RDWR);
	if (file_i2c < 0)
		fprintf(stderr, "Error opening i2c device; not running as sudo?\n");
		return 1;
	rc = ioctl(file_i2c, I2C_SLAVE, iAddr);
	if (rc < 0)
		close(file_i2c);
		fprintf(stderr, "Error setting I2C device address\n");
		return 1;
	iBackLight = BACKLIGHT;		// turn on backlight
	lcd1602_writeCommand(0x02); // Set 4-bit mode of the LCD controller
	lcd1602_writeCommand(0x28); // 2 lines, 5x8 dot matrix
	lcd1602_writeCommand(0x0c); // display on, cursor off
	lcd1602_writeCommand(0x06); // inc cursor to right when writing and don't scroll
	lcd1602_writeCommand(0x80); // set cursor to row 1, column 1
	lcd1602Clear();				// clear the memory
	return 0;
} /* lcd1602Init() */
// Set the LCD cursor position
	unsigned char cCmd;
	if (file_i2c < 0 || x < 0 || x > 15 || y < 0 || y > 1)
		return 1;
	cCmd = (y == 0) ? 0x80 : 0xc0;
	cCmd |= x;
	lcd1602_writeCommand(cCmd);
	return 0;
} /* lcd1602SetCursor() */
	iPulsePeriod = val;
} /* lcd1602SetPulsePeriod() */
	iBackLight = 0;				// turn off backlight
	lcd1602_writeCommand(0x08); // turn off display, cursor and blink
	close(file_i2c);
	file_i2c = -1;
} /* lcd1602Shutdown() */
上面的程序,经过一些小的修改,方便在其他地方调用。
另外,还需要获得IP的程序,经过了解,得到如下的代码:
// 获取本机ip  eth_inf网卡名称 调用方法get_local_ip("wlan0");
int get_local_ip(const char *eth_inf)
    int sd;
    sd = socket(AF_INET, SOCK_DGRAM, 0);
    if (-1 == sd)
        printf("socket error: %s\n", strerror(errno));
        return -1;
    strncpy(ifr.ifr_name, eth_inf, IFNAMSIZ);
    ifr.ifr_name[IFNAMSIZ - 1] = 0;
    // if error: No such device
    if (ioctl(sd, SIOCGIFADDR, &ifr) < 0)
        printf("ioctl error: %s\n", strerror(errno));
        close(sd);
        return -1;
    printf("interfac: %s, ip: %s\n", eth_inf, inet_ntoa(((struct sockaddr_in*)&ifr.ifr_addr)->sin_addr));
    close(sd);
    return 0;
有了上面的程序,就可以直接编写主程序lcd1602_demo.c了:
#include <unistd.h>
#include <stdio.h>
#include <string.h>
#include <stdint.h>
#include <stdlib.h>
#include <errno.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <netdb.h>
#include <net/if.h>
#include <arpa/inet.h>
#include <sys/types.h>
#include <sys/time.h>
#include "include/lcd1602.h"
struct ifreq ifr;
    int sd;
    if (-1 == sd)
        return -1;
        close(sd);
        return -1;
    close(sd);
    return 0;
int main(int argc, char *argv[])
	int rc;
	char str[17] = {0};
	char ip[16] = {0};
	sprintf(ip, "%s", inet_ntoa(((struct sockaddr_in*)&ifr.ifr_addr)->sin_addr));
	rc = lcd1602Init(0, 0x3f);
	if (rc)
		printf("Initialization LCD1602 failed; aborting...\n");
		return 0;
	} else {
		printf("Initialization LCD1602 ok!\n");
	// welcome
	lcd1602SetCursor(0, 0);
	sprintf(str, "%-16s", "Hello World!");
	lcd1602WriteString(str);
	lcd1602SetCursor(0, 1);
	sprintf(str, "%-16s", "I'm Purple Pi!");
	sleep(3);
	// ip
	sprintf(str, "%-16s", "My IP addr is:");
	sprintf(str, "%-16s", ip);
	sleep(5);
	// quit
	sprintf(str, "%-16s", "ENTER to quit");
	lcd1602WriteString("ENTER to quit");
	// blonk
	lcd1602Control(1, 0, 1); // backlight on, underline off, blink block on
	printf("ENTER to quit...\n");
	getchar();
	// shutdown
	lcd1602Shutdown();
	return 0;
} /* main() */
上述代码的逻辑,从上往下走,比较简单:
  1. 获取wlan0的ip地址;因为使用了无线联网
  2. 使用I2C0,地址0x3f,初始化LCD1602
  3. 输出Hello World信息
  4. 输出IP信息
  5. 输出回车退出信息
  6. 闪烁光标
要编译上面的LCD1602驱动库程序,还需要编写一个Makefile:
CFLAGS=-c -Wall -O2
LIBS = -lm -lpthread
all: liblcd1602.a
liblcd1602.a: lcd1602.o
	$(AR) -rc liblcd1602.a lcd1602.o ;\
	cp liblcd1602.a ./lib ;\
	cp lcd1602.h ./include
lcd1602.o: lcd1602.c
	$(CC) $(CFLAGS) lcd1602.c
clean:
	rm *.o liblcd1602.a
首先交叉编译库文件和demo程序,然后在上传到开发板:
mkdir lib include
make CC=arm-unknown-linux-gnueabihf-gcc AR=arm-unknown-linux-gnueabihf-ar
arm-unknown-linux-gnueabihf-gcc lcd1602_demo.c -lm -llcd1602 -lpthread -L./lib -o lcd1602_demo
ls -lh lcd1602_demo
scp lcd1602_demo root@192.168.1.30:/root/
编译上传完成后,到开发板上执行:【注意cd切换到/root/再执行】
LCD1602就能显示出IP地址了。
虽然只能显示16*2的字符,但是作为一些简短信息的显示,还是非常方便的。
LCD1602
更多回帖
