OpenHarmony开源社区
直播中
jf_1137202360
8年用户 1362经验值
擅长:嵌入式技术
私信 关注
[经验]
【开鸿智谷NiobeU4开发板免费试用体验】基于LVGL的示波器设计
1c3bca305e6e89b03f7beb477004d252
前言
前面我们抑制了LVGL,现在我们就可以利用GUI提供的控件,进行各种可视化项目设计了。本开发板具备ADC,所以想到的是利用ADC采集模拟数据,使用LVGL的CHART控件进行波形显示,实现简易示波器的设计。
代码
make menuconfig
Driver->
Enable HDF platform adc driver
使能ADC驱动。
gn文件添加头文件
"//drivers/hdf_core/framework/support/platform/include/adc",路径
#include <math.h>
#include <stdio.h>
#include "stdint.h"
#include "los_task.h"
#include "ohos_run.h"
#include "st7735.h"
#include "lv_port_disp.h"
#include "lvgl.h"
#include "demos/lv_demos.h"
#include "adc_if.h"
static void btn_event_cb(lv_event_t * e)
lv_event_code_t code = lv_event_get_code(e);
lv_obj_t * btn = lv_event_get_target(e);
if(code == LV_EVENT_CLICKED) {
static uint8_t cnt = 0;
cnt++;
/*Get the first child of the button which is the label and change its text*/
lv_obj_t * label = lv_obj_get_child(btn, 0);
lv_label_set_text_fmt(label, "Button: %d", cnt);
void lv_log_print(const char * buf)
printf("%s\r\n",buf);
* Create a button with a label and react on click event.
  void lv_example_get_started_1(void)
  lv_obj_t * btn = lv_btn_create(lv_scr_act());     /*Add a button the current screen*/
  lv_obj_set_pos(btn, 10, 10);                            /*Set its position*/
  lv_obj_set_size(btn, 60, 25);                          /*Set its size*/
  lv_obj_add_event_cb(btn, btn_event_cb, LV_EVENT_ALL, NULL);           /*Assign a callback to the button*/
  lv_obj_t * label = lv_label_create(btn);          /*Add a label to the button*/
  lv_label_set_text(label, "Button");                     /*Set the labels text*/
  lv_obj_center(label);
void lv_tick_handle(UINT32 arg)
while(1)
LOS_Msleep(5);   /*Sleep for 5 millisecond*/
lv_tick_inc(5);
lv_timer_handler();
lv_obj_t * chart;
lv_chart_series_t * ser1;
int adc_chart_init(void)
lv_obj_set_style_bg_color(lv_scr_act(), lv_color_hex(0x343247), 0);
/*Create a chart*/
chart = lv_chart_create(lv_scr_act());
lv_chart_set_type(chart, LV_CHART_TYPE_LINE);
lv_chart_set_point_count(chart, 10);
lv_chart_set_range(chart,LV_CHART_AXIS_PRIMARY_Y, 0, 330*3);
lv_chart_set_range(chart,LV_CHART_AXIS_SECONDARY_Y, 0, 330*3);
lv_chart_set_update_mode(chart, LV_CHART_UPDATE_MODE_SHIFT);
lv_chart_set_div_line_count(chart, 4, 8);
//lv_chart_set_zoom_x(lv_obj_t * obj, uint16_t zoom_x);
//lv_chart_set_zoom_y(lv_obj_t * obj, uint16_t zoom_y);
lv_chart_set_axis_tick(chart, LV_CHART_AXIS_PRIMARY_Y, 0, 0, 1, 1, true, 1);
lv_chart_set_axis_tick(chart, LV_CHART_AXIS_PRIMARY_X, 0, 0, 2, 1, true, 1);
lv_obj_set_size(chart, 135, 130);
lv_obj_align(chart, LV_ALIGN_CENTER, 0, 0);
/*Add  data series*/
ser1 = lv_chart_add_series(chart,lv_color_hex(0xF800),LV_CHART_AXIS_PRIMARY_Y);
return 0;
int adc_chart_newdata(int index,uint32_t newdata,int refresh)
if(index == 0)
lv_chart_set_next_value(chart, ser1, newdata);
else
if(refresh)
lv_chart_refresh(chart); /*Required after direct set*/
return 0;
#define ADC_DEVICE_NUM 1
#define ADC_CHANNEL_NUM 6
void StartHdfSPITest(void)
UINT32 g_lv_time_task;
TSK_INIT_PARAM_S task = { 0 };
task.pfnTaskEntry = (TSK_ENTRY_FUNC)lv_tick_handle;
task.pcName = "lv_time_task";
task.uwStackSize = 0x1000;
task.usTaskPrio = 25 - 1;
DevHandle adcHandle;
uint32_t readVal = 0;
///adcHandle = AdcOpen(ADC_DEVICE_NUM);
///if (adcHandle == NULL) {
///    printf("open adc err\r\n");
lv_init();
lv_port_disp_init();
///lv_log_register_print_cb(lv_log_print);
LOS_TaskCreate(&g_lv_time_task, &task);
//lv_demo_stress();
//lv_example_get_started_1();
adc_chart_init();
while(1)
static int num = 0;
//if (AdcRead(adcHandle, ADC_CHANNEL_NUM, &readVal) == HDF_SUCCESS) {
readVal = lv_rand(0,0xFFF);
num++;
readVal = readVal * 330 / (1u<<12);
adc_chart_newdata(0,readVal,1);
LOS_Msleep(200);
lv_task_handler();
OHOS_APP_RUN(StartHdfSPITest);
效果
总结
上述只是进行了简单的演示,可以考虑更加完善,实现一个可用的简单示波器。 另外借助LVGL可以实现更多有意思的小项目,比如信号发生器,串口调试助手等等。二维码生成器等。
回帖(3)
回头太晚
2022-9-26 18:40:40
举报
久醉不醒
2022-9-27 11:13:25
简单实用,非常不错
举报
自我清欢
2022-9-29 11:14:06
感谢分享,干货满满
举报
更多回帖
