瑞芯微Rockchip开发者社区
直播中
qjqb
9年用户 1365经验值
擅长:5762
私信 关注
[经验]
RK3128开发板在android显示端做分辨率调整
Platform: Rockchip
OS: Android 7.1.2
Kernel: 3.10
最近使用480P小屏幕开发时,碰到某些第三方APP的屏幕适配有BUG,如果直接修改配置文件会导致屏幕显示异常,因些只能直接在android显示端做分辨率调整。
修改路径:kernel\drivers\video\rockchip\rk_fb.c
第一步:修改成需要的显示分辨率
int rk_fb_prase_timing_dt(struct device_node *np, struct rk_screen *screen)
struct display_timings *disp_timing;
struct display_timing *dt;
disp_timing = of_get_display_timings(np);
if (!disp_timing) {
	pr_err("parse display timing err\n");
	return -EINVAL;
dt = display_timings_get(disp_timing, disp_timing->native_mode);
/* 修改屏幕显示分辨率*/
  • dt->hactive.typ = 1280;
  • dt->vactive.typ = 720;
    rk_fb_video_mode_from_timing(dt, screen);
    return 0;
    第二步:修改显示分辨率后,会导致显示区域也被相对缩放,因此需要修改显示窗口缩放规则
static void rk_fb_update_win(struct rk_lcdc_driver *dev_drv,
struct rk_lcdc_win *win,
struct rk_fb_reg_win_data reg_win_data)
} else {
对小于720P的屏幕不做缩放处理 */
  • if (reg_win_data->reg_area_data[i].xsize >= 1280 && reg_win_data->reg_area_data[i].ysize >= 720){
      				win->area[i].xpos =
      					reg_win_data->reg_area_data[i].xpos *
      					cur_screen->mode.xres /
      					primary_screen.mode.xres;
      				win->area[i].ypos =
      					reg_win_data->reg_area_data[i].ypos *
      					cur_screen->mode.yres /
      					primary_screen.mode.yres;
      				win->area[i].xsize =
      					reg_win_data->reg_area_data[i].xsize *
      				win->area[i].ysize =
      					reg_win_data->reg_area_data[i].ysize *
      			/* recalc display size if set hdmi scaler when at ONE_DUAL mode */
      			if (inf->disp_mode == ONE_DUAL && hdmi_switch_state) {
      				if (cur_screen->xsize > 0 &&
      				    cur_screen->xsize <= cur_screen->mode.xres) {
      					win->area[i].xpos =
      						((cur_screen->mode.xres - cur_screen->xsize) >> 1) +
      						cur_screen->xsize * win->area[i].xpos / cur_screen->mode.xres;
      						win->area[i].xsize * cur_screen->xsize / cur_screen->mode.xres;
      				if (cur_screen->ysize > 0 && cur_screen->ysize <= cur_screen->mode.yres) {
      					win->area[i].ypos =
      						((cur_screen->mode.yres - cur_screen->ysize) >> 1) +
      						cur_screen->ysize * win->area[i].ypos / cur_screen->mode.yres;
      						win->area[i].ysize * cur_screen->ysize / cur_screen->mode.yres;
目前屏幕显示正常,无触摸屏,触摸屏触摸效果是否会有异常暂时未知。
原作者:wuxin131765
更多回帖
