瑞芯微Rockchip开发者社区
直播中
贾熹
7年用户 1612经验值
私信 关注
[问答]
RK3399如何设置默认的声卡呢
  现在的板子有两块声卡,一块是5640,一块是hdmi
  所以发现直接发声有时候会发不出声音
  这个默认声卡有配置文件可以设置么?希望能设置成5640,哪位大神指点一下?
回帖(1)
李斌
2022-8-22 17:02:39
Firstly use this to define sound cards
pactl list short sinks
You will get a list as;
module-alsa-card.c        s16le 2ch 44100Hz        SUSPENDED
1        alsa_output.usb-Blue_Microphones_Yeti_Stereo_Microphone_REV8-00.analog-stereo        module-alsa-card.c        s16le 2ch 44100Hz        SUSPENDED
2        alsa_output.usb-FiiO_DigiHug_USB_Audio-01.analog-stereo        module-alsa-card.c        s16le 2ch 44100Hz        SUSPENDED
3        alsa_output.pci-0000_00_1f.3.analog-stereo        module-alsa-card.c        s16le 2ch 48000Hz        RUNNING
Then select you have to use hdmi and to set it use this command;
pactl set-default-sink 'alsa_output.pci-0000_00_1f.3.analog-stereo'
open  /etc/pulse/default.pa  and change the related lines as;
### Make some devices default
set-default-sink 3
set-default-source 3
Pls use index numbers and names as your output values.
举报
更多回帖
