WCH沁恒单片机
直播中
刘丽
7年用户 1273经验值
私信 关注
[问答]
用CC2640和CH582M通过蓝牙通信,蓝牙总是断开是什么原因?
用CC2640和CH582M通过蓝牙通信,蓝牙总是断开。串口提示如下:
[11:30:04.316]收←◆Advertising..
[11:30:05.790]收←◆Conn 1 - Int 50
Connected..
[11:30:06.077]收←◆Pairing started:0
[11:30:06.589]收←◆Update 1 - Int a
[11:30:07.216]收←◆Pairing success
Bond save success
隔一段时间后,串口就会打印上面的信息。
我想知道蓝牙断开的原因是什么?怎么获取蓝牙断开的原因?
回帖(1)
龚羿峰
2022-7-29 09:27:27
#define SBP_PERIODIC_EVT_PERIOD              1600
// How often to perform read rssi event
#define SBP_READ_RSSI_EVT_PERIOD             6400
// Parameter update delay
//#define SBP_PARAM_UPDATE_DELAY               100
#define SBP_PARAM_UPDATE_DELAY               0
// What is the advertising interval when device is discoverable (units of 625us, 80=50ms)
#define DEFAULT_ADVERTISING_INTERVAL         160
// Limited discoverable mode advertises for 30.72s, and then stops
// General discoverable mode advertises indefinitely
#define DEFAULT_DISCOVERABLE_MODE            GAP_ADTYPE_FLAGS_GENERAL
// Minimum connection interval (units of 1.25ms, 6=7.5ms)
//#define DEFAULT_DESIRED_MIN_CONN_INTERVAL    6
#define DEFAULT_DESIRED_MIN_CONN_INTERVAL    10
// Maximum connection interval (units of 1.25ms, 100=125ms)
//#define DEFAULT_DESIRED_MAX_CONN_INTERVAL    100
// Slave latency to use parameter update
#define DEFAULT_DESIRED_SLAVE_LATENCY        0
// Supervision timeout value (units of 10ms, 100=1s)
#define DEFAULT_DESIRED_CONN_TIMEOUT         10
举报
更多回帖
