开发OpenHarmony应用程序时进行数据请求,使用@ohos.net.http模块,每次都需要创建一个http请求任务,然后执行请求方法,最后返回结果。最终造成每个页面都有大量相同的代码,如果域名发生变更,需要每个有数据请求的页面都去更改。因此有了数据请求封装,对外只提供get和post两种方法,只需要导入封装模块,调用封装方法,返回最终结果,把异常等在封装中处理。
@ohos.net.http模块PromiseRequestUtil.ts文件@ohos.net.http模块import http from '@ohos.net.http';
@ohos.prompt模块,做消息提示import prompt from '@ohos.prompt';
RestApiUtil.ts文件,作为返回结果集/**
* @Description 返回数据工具
* @date 2022/7/18 9:41
* @Author Bai XiaoMing
* @Version 1.0
export default class RestApiUtil {
code: number;
msg: string;
newslist: Array<any>;
constructor(code: number, msg: string, newslist: Array<any>) {
this.code = code;
this.msg = msg;
this.newslist = newslist;
import log from './LogUtil';
request方法private request(url: string, method: http.RequestMethod.GET | http.RequestMethod.POST, data?: any): Promise<any> {
return new Promise((resolve) => {
let request = http.createHttp();
request.request(url, {
method,
header: {
"Content-Type": method === http.RequestMethod.GET ? "application/json" : "application/x-www-form-urlencoded;charset=UTF-8"
extraData: data
}).then((res) => {
log.printInfo(TAG, JSON.stringify(res));
let { responseCode, result } = res;
if (responseCode === 200) {
log.printInfo(TAG, result.toString());
let data = result.toString();
// 将返回结果转成封装的结果集
let resultVal: RestApi = JSON.parse(data);
resolve(resultVal);
} else {
prompt.showToast({
message: "HTTP级异常:" + res.responseCode,
duration: 2000
}).catch((err) => {
prompt.showToast({
message: "系统级异常:" + JSON.stringify(err),
duration: 2000
get和post方法get(url: string, data?: any): Promise<any> {
this.request(url, http.RequestMethod.GET, data).then((res) => {
resolve(res);
post(url: string, data?: any): Promise<any> {
this.request(url, http.RequestMethod.POST, data).then((res) => {
resolve(res);
let request = new RequestUtil();
export default request;
RequestUtil,调用get方法获取请求数据import request from '../common/utils/RequestUtil';
// 【天行数据】提供的藏头诗接口,返回数据
getPoetry = () => {
this.poetryArray = new Array<any>();
let url = 'https://api.tianapi.com/cangtoushi/index';
url += `?key=${Constant.RequestApiKey}`;
url += `&word=${this.word}`;
url += `&len=${this.len}`;
url += `&type=${this.type}`;
url += `&pat=${this.pat}`;
request.get(url).then((res) => {
// 返回结果没有进一步处理,读者有兴趣可以进一步封装
let data: RestApi = res;
if (data.code === 250) {
prompt.showToast({
message: data.msg,
duration: 2000
} else if (data.code === 200) {
this.poetryArray = data.newslist;
} else {
prompt.showToast({
message: data.msg,
duration: 2000
至此,数据请求二次封装完成。
举报
举报
举报
举报
更多回帖
