硬件平台:RK3128
Android版本:6.0
Kernel版本:3.10.92
模块名:UC-15 3G模块
一、驱动配置:
1、添加PID,VID。
修改kernel/drivers/u***/serial/op
tion.c,添加:
{ USB_DEVICE(QUALCOMM_VENDOR_ID, 0x9090)}, //UC-15
2、上电使能:
Dts中添加:
5v_power_en {
compatible = "5v_en";
3gpower,pin =<&gpio2 GPIO_A2 GPIO_ACTIVE_LOW>;
3gen,pin =<&gpio0 GPIO_D6 GPIO_ACTIVE_HIGH>;
status = "okay";//okay
然后添加misc驱动以便在开机时上电和使能模块。
3、USB和PPP配置
这一块平台默认都是打开的,没开的可以开下,如下:
Device Drivers --->
[*] USB support --->
<*> USB Modem (CDC ACM) support
<*> USB Serial Converter support --->
[*] USB Generic Serial Driver
<*> USB driver for GSM and CDMA modems
PPP配置:
Device Drivers --->
[*] Network device support --->
<*> PPP (point-to-point protocol) support
<*> PPP Deflate compression
<*> PPP support for async serial ports
<*> PPP support for sync tty ports
二、RIL库
将厂家提供的RIL源码复制到hardware/ril/ 下,需要注意,在rk3128 android6.0源码下,有hardware/ril/librilutils/proto这样一个文件夹,这个系统要用到,所以需要保留hardware/ril/librilutils/Android.mk中proto的相关内容,不然会编译不过。
三、系统配置
1、修改system/core/rootdir/init.rc,添加:
service ril-daemon /system/bin/rild -l /system/lib/libreference-ril.so
class main
socket rild stream 660 root radio
socket sap_uim_socket1 stream 660 bluetooth bluetooth
socket rild-debug stream 660 radio system
user root
group radio cache inet misc audio log
启动服务是在rockchip/common/init.rk30board.rc:
on property:ro.boot.baseband=N/A
setprop ro.radio.noril false
start ril-daemon
2、修改device/rockchip/rk312x/system.prop:
rild.libpath=/system/lib/libreference-ril.so
rild.libargs=-d /dev/ttyUSB0
3、添加权限
修改device/rockchip/common/ueventd.rockchip.rc,添加:
# for radio
/dev/ttyUSB0 0660 radio radio
/dev/ttyUSB1 0660 radio radio
/dev/ttyUSB2 0660 radio radio
/dev/ttyUSB3 0660 radio radio
/dev/ttyUSB4 0660 radio radio
四、注意事项
1、模块挂载成功后,内核会有如下log输出:
[ 5.382480] u*** 1-1.1: New USB device found, idVendor=05c6, idProduct=9090
[ 5.382520] u*** 1-1.1: New USB device strings: Mfr=3, Product=2, SerialNumber=4
[ 5.382547] u*** 1-1.1: Product: UMTS/HSPA Module
[ 5.382569] u*** 1-1.1: Manufacturer: Quectel, Incorporated
[ 5.479168] option 1-1.1:1.0: GSM modem (1-port) converter detected
[ 5.480514] u*** 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
[ 5.481647] option 1-1.1:1.1: GSM modem (1-port) converter detected
[ 5.482896] u*** 1-1.1: GSM modem (1-port) converter now attached to ttyUSB1
[ 5.484041] option 1-1.1:1.2: GSM modem (1-port) converter detected
[ 5.488255] u*** 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
[ 5.489471] option 1-1.1:1.3: GSM modem (1-port) converter detected
[ 5.507673] u*** 1-1.1: GSM modem (1-port) converter now attached to ttyUSB3
[ 5.508908] option 1-1.1:1.4: GSM modem (1-port) converter detected
[ 5.510120] u*** 1-1.1: GSM modem (1-port) converter now attached to ttyUSB4
如果没有,请检查上电和使能脚控制是否正确,PID,VID是否正确添加。
2、通过adb查看服务是否启动:
shell@rk312x:/ $ ps | grep rild
ps | grep rild
root 177 1 7200 1468 hrtimer_na 00000000 S /system/bin/rild
说明服务启动。
如果没有启动,先查看以下两个文件是否存在:
out/target/product/rk312x/system/bin/rild
out/target/product/rk312x/system/lib/libreference-ril.so
以及启动服务脚本是否运行。
原作者:板砖先生
