瑞芯微Rockchip开发者社区
直播中
建立建利12
9年用户 1453经验值
擅长:可编程逻辑 嵌入式技术
私信 关注
[问答]
为什么TB-RK3399ProD开发板docker沙箱sandbox运行不起来呢
TB-RK3399ProD开发板docker的沙箱sandbox运行不起来,我感觉是内核裁剪那块,或cpu某种特性不支持,所导致。
我搜索了一下,发现很多docker的问题,有没有哪个大神也遇到这个问题,麻烦给点指导,多谢先。
docker提示错误:
failed to create endpoint nervous_galileo on network bridge: failed to add the host (vetha8e5fed) <=> sandbox (veth94cd799) pair interfaces: operation not supported
求解
回帖(5)
哔哔哔-
2022-5-5 11:23:18
默认内核,docker相关配置没打开,请用附件的config替换arch/arm64/configs/rockchip_linux_defconfig,然后重新编译
举报
建立建利12
2022-5-5 11:23:28
感谢指导,我试一下先
举报
建立建利12
2022-5-5 11:23:46
我试了编不过
CC      lib/timerqueue.o
  CC      lib/vsprintf.o
  LD      lib/built-in.o
  AR      lib/lib.a
Message from syslogd@localhost at Apr 30 12:31:57 ...
kernel:NMI watchdog: BUG: soft lockup - CPU#0 stuck for 21s! [aarch64-linux-g:46512]
Message from syslogd@localhost at Apr 30 12:32:20 ...
kernel:NMI watchdog: BUG: soft lockup - CPU#0 stuck for 23s! [kswapd0:30]
Message from syslogd@localhost at Apr 30 12:33:02 ...
kernel:NMI watchdog: BUG: soft lockup - CPU#0 stuck for 35s! [aarch64-linux-g:46512]
举报
建立建利12
2022-5-5 11:24:02
按您提供的方法,编译了内核,还是没办法运行docker
[root@toybrick ~]#
[root@toybrick ~]# docker run node
/usr/bin/docker-current: Error response from daemon: failed to create endpoint mystifying_babbage on network bridge: failed to add the host (veth4d2a279) <=> sandbox (vethde38836) pair interfaces: operation not supported.
ERRO[0164] error getting events from daemon: net/http: request canceled
[root@toybrick ~]#
举报
LL-LING宁
2022-5-5 11:24:17
我在Ubuntu上交叉编译一直不成功,请问编译成功的镜像可以分享一下吗,万分感谢
举报
更多回帖
