嵌入式技术论坛
直播中
韩刚龙
8年用户 1017经验值
私信 关注
[问答]
RTT移植到LPC1752开发板上的bug解析
硬件:LPC1752(zlg开发板) + CF卡 (多余的IO脚已经悬空)
软件:RTT0.4.0RC for LPC176x 堆地址已经改成 0x10004000 rt_system_heap_init((void*)&Image$$RW_IRAM1$$ZI$$Limit, (void*)0x10004000);
问题:跟踪发现每次都在rt_device_init_all中初始化串口1或者串口2或者串口3的Fdiv = ( pclk / 16 ) / UART0_BAUDRATE;处直接跳入fault_rvds的rt_hw_hard_fault PROC再跳入硬件异常函数。初始化函数没有问题已经脱离RTT在工程中用过,软件仿真的时候能正常通过rt_device_init_all,怀疑是和硬件那里冲突,一时找不到!下面是初始化函数和异常响应的。finsh在串口0,去掉所有串口驱动则不会进入硬件异常。
static rt_err_t rt_uart_init (rt_device_t dev)
rt_uint32_t Fdiv;
rt_uint32_t pclkdiv, pclk;
/* Init UART Hardware */
LPC_PINCON->PINSEL0 &= ~0x000000F0;
LPC_PINCON->PINSEL0 |= 0x00000050;  /* RxD0 is P0.3 and TxD0 is P0.2 */
/* By default, the PCLKSELx value is zero, thus, the PCLK for
all the peripherals is 1/4 of the SystemFrequency. */
/* Bit 6~7 is for UART0 */
pclkdiv = (LPC_SC->PCLKSEL0 >> 6) & 0x03;
switch ( pclkdiv )
  case 0x00:
  default:
pclk = SystemCoreClock/4;
break;
  case 0x01:
pclk = SystemCoreClock;
break;
  case 0x02:
pclk = SystemCoreClock/2;
break;
  case 0x03:
pclk = SystemCoreClock/8;
break;
    LPC_UART0->LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */
Fdiv = ( pclk / 16 ) / UART0_BAUDRATE; /*baud rate */
    LPC_UART0->DLM = Fdiv / 256;   <==================== 此行跳入硬件异常,屏蔽后下面一行也进入到异常
    LPC_UART0->DLL = Fdiv % 256;
LPC_UART0->LCR = 0x03; /* DLAB = 0 */
    LPC_UART0->FCR = 0x07; /* Enable and reset TX and RX FIFO. */
/* Ensure a clean start, no data in either TX or RX FIFO. */
while (( LPC_UART0->LSR & (LSR_THRE|LSR_TEMT)) != (LSR_THRE|LSR_TEMT) );
while ( LPC_UART0->LSR & LSR_RDR )
Fdiv = LPC_UART0->RBR; /* Dump data from RX FIFO */
LPC_UART0->IER = IER_RBR | IER_THRE | IER_RLS; /* Enable UART interrupt */
return RT_EOK;
psr: 0x00000000
pc: 0x00000000
lr: 0x00000000
r12: 0x00000000
r03: 0x00000000
r02: 0x00000000
r01: 0x00000000
r00: 0x00000000
hard fault on thread: (NULL)
thread pri status sp stack size max used left tick error
回帖(3)
韩刚龙
2022-4-14 14:18:02
另外CF卡驱动底层已经实现,
ReadCompactFlashSector是在指定的地址读一个扇区512Byte,则对RTT的接口是不是按下面的封装?
static rt_size_t rt_ide_read(rt_device_t dev, rt_off_t pos, void* buffer, rt_size_t size)
    unsigned long count , offset , idx ;
    unsigned char *pData ;
    pData = ( unsigned char *)buffer ;
    count  = size / 512 ;
    offset = (pos / 512) + part.offset ;
    for(idx = 0 ; idx < count ; idx++)
        ReadCompactFlashSector(size , pData) ;
    ReadCompactFlashSector(offset , pData) ;
    return count ;
举报
李敏
2022-4-14 14:18:35
0.4.x的驱动,read/write的读写单位都是按照一个块大小进行的。
至于串口的问题,不是太明白,按照道理来说,不会出现对一个寄存器赋值就触发fault的情况。除非这个寄存器的地址是错误的(1752在这块上与1768有区别吗)。
举报
王敏
2022-4-14 14:18:43
  代码请加标签。
  [code]
  [/code]
  同样的主题发一处即可。
  size单位为sector。
  如果sector_size为512,
  那么从8192字节处读取1024字节时,pos传过来的值是 8192/512=16,size传过来的值是1024/512=2。
举报
更多回帖
