嵌入式技术论坛
直播中
糖栗子
9年用户 667经验值
擅长:MEMS/传感技术
私信 关注
[问答]
请大神帮忙看看RTT nrf24l01设备驱动程序有什么地方需要修改的
第一次写os底层驱动,写的不好请多多谅解
今天写的nrf24l01 设备驱动程序 请大神给点意见
#include
#include "nrf24l01.h"
//#define NRF_DEBUG
#ifdef NRF_DEBUG
#define NRF_TRACE         rt_kprintf
#else
#define NRF_TRACE(...)
#endif /* #ifdef FLASH_DEBUG */
static struct spi_nrf_device  nrf24l01_dev;
#define nrf24l01_lock()       rt_mutex_take(&nrf24l01_dev.lock, RT_WAITING_FOREVER)
#define nrf24l01_unlock()     rt_mutex_release(&nrf24l01_dev.lock)
/* write nrf buf */
static rt_uint8_t NRF24L01_Write_Buf(rt_uint8_t reg, const void *buffer, rt_size_t size)
return rt_spi_send_then_send(nrf24l01_dev.rt_spi_device,®,1,buffer,size);
/* read nrf buf */
static rt_uint8_t NRF24L01_Read_Buf(rt_uint8_t reg,void *buffer,rt_size_t size)
return rt_spi_send_then_recv(nrf24l01_dev.rt_spi_device,®,1,buffer,size);
/* cheeek nef24l01 */
/* 0: ok  1:error*/
rt_uint8_t NRF24L01_Check(void)
rt_uint8_t buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
rt_uint8_t i;
NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,buf,5);
NRF24L01_Read_Buf(TX_ADDR,buf,5);
for(i=0;i<5;i++)
if(buf
!=0XA5)break;
if(i!=5)return 1;
return 0;
void NRF24L01_Write_Reg(rt_uint8_t reg,rt_uint8_t date)
rt_spi_send_then_send(nrf24l01_dev.rt_spi_device,®,1,&date,1);
rt_uint8_t NRF24L01_Read_Reg(rt_uint8_t reg)
rt_uint8_t date;
rt_spi_send_then_recv(nrf24l01_dev.rt_spi_device,®,1,&date,1);
return date;
extern void spi_nrf_isr(int vector)
rt_uint8_t sta;
nrf24l01_lock();
sta=NRF24L01_Read_Reg(STATUS);  //????×????????÷????
NRF_TRACE("nrf isr %2x
",sta);
NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //????TX_DS?òMAX_RT????±ê??
if(sta&MAX_TX)//????×??ó??·?????
NRF_TRACE("send max data
NRF24L01_Write_Reg(FLUSH_TX,0xff);//????TX FIFO?????÷
if(sta&TX_OK)//·????ê??
NRF_TRACE("send ok
if(sta&RX_OK)//??????????
NRF_TRACE("recv ok
NRF24L01_Read_Buf(RD_RX_PLOAD,nrf24l01_dev.date.buff,20);//????????
nrf24l01_dev.date.Wrt=20;
NRF24L01_Write_Reg(FLUSH_RX,0xff);//????RX FIFO?????÷
nrf24l01_unlock();
/* RT-Thread device interface */
static rt_err_t nrf24lxx_init(rt_device_t dev)
    return RT_EOK;
static rt_err_t nrf24lxx_open(rt_device_t dev, rt_uint16_t oflag)
    return RT_EOK;
static rt_err_t nrf24lxx_close(rt_device_t dev)
    return RT_EOK;
static rt_err_t nrf24lxx_control(rt_device_t dev, rt_uint8_t cmd, void *args)
uint8_t send_buffer[4];
RT_ASSERT(dev != RT_NULL);
SetCEN(0);
switch(cmd)
/* modue tx */
case SET_MODE_TX:
NRF_TRACE("set mode tx
NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0e);
break;
/* modue rx */
case SET_MODE_RX:
NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0f);
break;
/* EN CH */
case SET_EN_CH:
send_buffer[0]=NRF_WRITE_REG+EN_RXADDR;
rt_spi_send_then_send(nrf24l01_dev.rt_spi_device,send_buffer,1,args,1);
break;
/* rf ch */
case SET_RF_CH:
send_buffer[0]=NRF_WRITE_REG+RF_CH;
break;
case SET_RF_RETR:
send_buffer[0]=NRF_WRITE_REG+SETUP_RETR;
break;
/* set tx addr */
case SET_TX_ADDR:
send_buffer[0]=NRF_WRITE_REG+TX_ADDR;
rt_spi_send_then_send(nrf24l01_dev.rt_spi_device,send_buffer,1,args,5);
send_buffer[0]=NRF_WRITE_REG+RX_ADDR_P0;
break;
/* set tx ack */
case SET_EN_ACK:
send_buffer[0]=NRF_WRITE_REG+EN_AA;
break;
/* set SET_RF_SETUP */
case SET_RF_SETUP:
send_buffer[0]=NRF_WRITE_REG+RF_SETUP;
break;
/* set rx add0 */
case SET_RX_ADDR0:
break;
/* set rx add1 */
case SET_RX_ADDR1:
send_buffer[0]=NRF_WRITE_REG+RX_ADDR_P1;
break;
/* set rx add2 */
case SET_RX_ADDR2:
send_buffer[0]=NRF_WRITE_REG+RX_ADDR_P2;
break;
/* set rx add3 */
case SET_RX_ADDR3:
send_buffer[0]=NRF_WRITE_REG+RX_ADDR_P3;
break;
/* set rx add4 */
case SET_RX_ADDR4:
send_buffer[0]=NRF_WRITE_REG+RX_ADDR_P4;
break;
/* set rx add5 */
case SET_RX_ADDR5:
send_buffer[0]=NRF_WRITE_REG+RX_ADDR_P5;
break;
/* set SET_RX_SIZE0 */
case SET_RX_SIZE0:
send_buffer[0]=NRF_WRITE_REG+RX_PW_P0;
break;
case SET_RX_SIZE1:
send_buffer[0]=NRF_WRITE_REG+RX_PW_P1;
break;
case SET_RX_SIZE2:
send_buffer[0]=NRF_WRITE_REG+RX_PW_P2;
break;
case SET_RX_SIZE3:
send_buffer[0]=NRF_WRITE_REG+RX_PW_P3;
break;
case SET_RX_SIZE4:
send_buffer[0]=NRF_WRITE_REG+RX_PW_P4;
break;
case SET_RX_SIZE5:
send_buffer[0]=NRF_WRITE_REG+RX_PW_P5;
break;
SetCEN(1);
    return RT_EOK;
static rt_size_t nrf24lxx_read(rt_device_t dev,
                                   rt_off_t pos,
                                   void* buffer,
                                   rt_size_t size)
size=nrf24l01_dev.date.Wrt;
if(nrf24l01_dev.date.Wrt>0)
rt_memcpy(buffer, buffer, size);
nrf24l01_dev.date.Wrt=0;
return size;
else
    return 0;
static rt_size_t nrf24lxx_write(rt_device_t dev,
                                    rt_off_t pos,
                                    const void* buffer,
                                    rt_size_t size)
SetCEN(0);
NRF_TRACE("start sengd date
NRF24L01_Write_Buf(WR_TX_PLOAD,buffer,size);
SetCEN(1);
    return size;
rt_err_t nrf24l01_init(const char * nrf_device_name, const char * spi_device_name)
    struct rt_spi_device * rt_spi_device;
   /* initialize mutex */
    if (rt_mutex_init(&nrf24l01_dev.lock, spi_device_name, RT_IPC_FLAG_FIFO) != RT_EOK)
        rt_kprintf("init sd lock mutex failed
        return -RT_ENOSYS;
    rt_spi_device = (struct rt_spi_device *)rt_device_find(spi_device_name);
    if(rt_spi_device == RT_NULL)
        NRF_TRACE("spi device %s not found!
", spi_device_name);
        return -RT_ENOSYS;
nrf24l01_dev.rt_spi_device = rt_spi_device;
    /* config spi */
        struct rt_spi_configuration cfg;
        cfg.data_width = 8;
        cfg.mode = RT_SPI_MODE_0 | RT_SPI_MSB; /* SPI Compatible: Mode 0 and Mode 3 */
        cfg.max_hz = 8 * 1000 * 1000; /* 8M */
        rt_spi_configure(rt_spi_device, &cfg);
/* nrf24lxx_init */
rt_uint8_t sendbuffer[5];
if(NRF24L01_Check())
rt_kprintf("nrf device not found!
return -RT_ENOSYS;
/* set nrf tx addr */
nrf24lxx_control(&nrf24l01_dev.device,SET_TX_ADDR,"FYYYY");
/* set nrf en ack */
sendbuffer[0]=0x00;
nrf24lxx_control(&nrf24l01_dev.device,SET_EN_ACK,sendbuffer);
/* set nrf en ch */
sendbuffer[0]=0x01;
nrf24lxx_control(&nrf24l01_dev.device,SET_EN_CH,sendbuffer);
/* reset send time :500us + 86us; send max count 10 */
sendbuffer[0]=0x1a;
nrf24lxx_control(&nrf24l01_dev.device,SET_RF_RETR,sendbuffer);
/* set nrf rf ch */
sendbuffer[0]=40;
nrf24lxx_control(&nrf24l01_dev.device,SET_RF_CH,sendbuffer);
sendbuffer[0]=0x0f;
nrf24lxx_control(&nrf24l01_dev.device,SET_RF_SETUP,sendbuffer);
    /* register device */
nrf24l01_dev.device.type    = RT_Device_Class_Char;
nrf24l01_dev.device.init    = nrf24lxx_init;
nrf24l01_dev.device.open    = nrf24lxx_open;
nrf24l01_dev.device.close   = nrf24lxx_close;
nrf24l01_dev.device.read    = nrf24lxx_read;
nrf24l01_dev.device.write   = nrf24lxx_write;
nrf24l01_dev.device.control = nrf24lxx_control;
    /* no private */
    nrf24l01_dev.device.user_data = RT_NULL;
    rt_device_register(&nrf24l01_dev.device, nrf_device_name,
                       RT_DEVICE_FLAG_RDWR | RT_DEVICE_FLAG_STANDALONE);
    return RT_EOK;
#ifdef RT_USING_FINSH
#include
void nrf_info(void)
rt_uint8_t sendbuffer[20];
NRF24L01_Read_Buf(TX_ADDR,sendbuffer,5);
rt_kprintf("tx_addr: 0x%2x-0x%2x-0x%2x-0x%2x-0x%2x
",sendbuffer[0],
sendbuffer[1],
sendbuffer[2],
sendbuffer[3],
sendbuffer[4]);
NRF24L01_Read_Buf(RX_ADDR_P0,sendbuffer,5);
rt_kprintf("rx_addr0: 0x%2x-0x%2x-0x%2x-0x%2x-0x%2x
",sendbuffer[0],
sendbuffer[1],
sendbuffer[2],
sendbuffer[3],
sendbuffer[4]);
rt_kprintf("RF_CH      = 0x%2x
",NRF24L01_Read_Reg(RF_CH));
rt_kprintf("EN_AA      = 0x%2x
",NRF24L01_Read_Reg(EN_AA));
rt_kprintf("EN_RXADDR  = 0x%2x
",NRF24L01_Read_Reg(EN_RXADDR));
rt_kprintf("RF_SETUP   = 0x%2x
",NRF24L01_Read_Reg(RF_SETUP));
rt_kprintf("SETUP_RETR = 0x%2x
",NRF24L01_Read_Reg(SETUP_RETR));
rt_kprintf("CONFIG     = 0x%2x
",NRF24L01_Read_Reg(CONFIG));
FINSH_FUNCTION_EXPORT(nrf_info, printf nrf_info.)
#endif
请大神帮忙看看有什么地方需要注意,或者怎样修改 ,代码测试能用, 以下NRF_device是结构
struct nrf_date
    rt_uint8_t buff[30];
    rt_uint8_t Wrt;
    struct rt_device                device;
    struct nrf_date                 date;
    struct rt_mutex                 lock;
回帖(6)
建立建利12
2022-4-1 17:02:08
ISR中不要去做读写。
有读写就会去试图持有Mutex,这是错误的用法。
即使没有mutex,ISR中也不适合作这类耗费的操作。
举报
糖栗子
2022-4-1 17:02:40
有中断的设备,底层os驱动需要怎样处理,比如有数据接收,发生中断,
怎样去读数据,
读函数可以写成
                                   rt_off_t pos,
                                   void* buffer,
                                   rt_size_t size)
    rt_uint8_t sta;
    sta=NRF24L01_Read_Reg(STATUS);  //读取状态寄存器的值
    if(sta&RX_OK)//接收到数据
      NRF_TRACE("recv data
      NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中断标志
      NRF24L01_Read_Buf(RD_RX_PLOAD,buffer,20);//读取数据
      return 20;
    return 0;
举报
建立建利12
2022-4-1 17:03:02
中断里面通知线程去处理。
举报
糖栗子
2022-4-1 17:03:14
在底层中创建一个线程 处理中断信息吗
举报
糖栗子
2022-4-1 17:04:05
更新下驱动 在底层创建一个线程接收数据,大家给点意见,
#include
#define NRF_DEBUG
#ifdef NRF_DEBUG
#else
static struct spi_nrf_device  nrf24l01_device;
/* write nrf buf */
return rt_spi_send_then_send(nrf24l01_device.rt_spi_device,®,1,buffer,size);
/* read nrf buf */
return rt_spi_send_then_recv(nrf24l01_device.rt_spi_device,®,1,buffer,size);
/* 0: ok  1:error*/
rt_uint8_t i;
for(i=0;i<5;i++)
if(buf
!=0XA5)break;
if(i!=5)return 1;
return 0;
rt_spi_send_then_send(nrf24l01_device.rt_spi_device,®,1,&date,1);
rt_uint8_t date;
rt_spi_send_then_recv(nrf24l01_device.rt_spi_device,®,1,&date,1);
return date;
static rt_err_t spi_nrf_transfer(struct spi_nrf_device *dev)
rt_uint8_t sta;
if(nrf24l01_device.tx_packet.data_len>0)
rt_uint8_t size=nrf24l01_device.tx_packet.data_len;
NRF_TRACE("send data
SetCEN(0);
NRF24L01_Write_Buf(WR_TX_PLOAD,nrf24l01_device.tx_packet.buffer,size);//????????
nrf24l01_device.tx_packet.data_len=0;
SetCEN(1);
return RT_EOK;
NRF_TRACE("status=%2x
",sta);
else if(sta&TX_OK)//·????ê??
NRF_TRACE("send ok
nrf24l01_device.rx_packet.data_len=0;
else if(sta&RX_OK)//??????????
NRF_TRACE("recv ok
NRF24L01_Read_Buf(RD_RX_PLOAD,nrf24l01_device.rx_packet.buffer,20);//????????
nrf24l01_device.rx_packet.data_len=20;
return RT_EOK;
    return RT_EOK;
    return RT_EOK;
    return RT_EOK;
switch(cmd)
/* modue tx */
case SET_MODE_TX:
break;
/* modue rx */
case SET_MODE_RX:
SetCEN(1);
break;
/* EN CH */
case SET_EN_CH:
rt_spi_send_then_send(nrf24l01_device.rt_spi_device,send_buffer,1,args,1);
break;
/* rf ch */
case SET_RF_CH:
break;
case SET_RF_RETR:
break;
/* set tx addr */
case SET_TX_ADDR:
rt_spi_send_then_send(nrf24l01_device.rt_spi_device,send_buffer,1,args,5);
break;
/* set tx ack */
case SET_EN_ACK:
break;
case SET_RF_SETUP:
break;
/* set rx add0 */
case SET_RX_ADDR0:
break;
/* set rx add1 */
case SET_RX_ADDR1:
break;
/* set rx add2 */
case SET_RX_ADDR2:
break;
/* set rx add3 */
case SET_RX_ADDR3:
break;
/* set rx add4 */
case SET_RX_ADDR4:
break;
/* set rx add5 */
case SET_RX_ADDR5:
break;
case SET_RX_SIZE0:
break;
case SET_RX_SIZE1:
break;
case SET_RX_SIZE2:
break;
case SET_RX_SIZE3:
break;
case SET_RX_SIZE4:
break;
case SET_RX_SIZE5:
break;
    return RT_EOK;
                                   rt_off_t pos,
                                   void* buffer,
                                   rt_size_t size)
    if (nrf24l01_device.rx_packet.data_len>0)
       size=nrf24l01_device.rx_packet.data_len;
rt_memcpy(buffer,nrf24l01_device.rx_packet.buffer,size);
return size;
    else
       return 0;
                                    rt_off_t pos,
                                    const void* buffer,
                                    rt_size_t size)
NRF_TRACE("write nrf size %d
",size);
    if (nrf24l01_device.tx_packet.data_len==0)
       nrf24l01_device.tx_packet.data_len =size;
rt_memcpy(nrf24l01_device.tx_packet.buffer,buffer,size);
       rt_event_send(&nrf24l01_device.data_event, 1);
return size;
    else
return 0;
/********************************* RT-Thread rt_device interface end **************************************/
static void nrf_data_thread_entry(void *parameter)
    rt_uint32_t e;
    rt_err_t result;
NRF_TRACE("spi thread is ok
    while (1)
        /* receive first event */
        if (rt_event_recv(&nrf24l01_device.data_event,
                          1,
                          RT_EVENT_FLAG_AND | RT_EVENT_FLAG_CLEAR,
                          RT_WAITING_FOREVER,
                          &e) != RT_EOK)
            continue;
        spi_nrf_transfer(&nrf24l01_device);
rt_memset(&nrf24l01_device, 0, sizeof(struct spi_nrf_device));
    nrf24l01_device.rt_spi_device = (struct rt_spi_device *)rt_device_find(spi_device_name);
    if(nrf24l01_device.rt_spi_device == RT_NULL)
        return -RT_ENOSYS;
    /* config spi */
        cfg.data_width = 8;
        rt_spi_configure(nrf24l01_device.rt_spi_device, &cfg);
rt_event_init(&nrf24l01_device.data_event, "nrf", RT_IPC_FLAG_FIFO);
/* nrf24lxx_init */
return -RT_ENOSYS;
nrf24lxx_control(&nrf24l01_device.device,SET_RX_ADDR0,"FYYYY");
sendbuffer[0]=20;
nrf24lxx_control(&nrf24l01_device.device,SET_RX_SIZE0,sendbuffer);
sendbuffer[0]=0x00;
nrf24lxx_control(&nrf24l01_device.device,SET_EN_ACK,sendbuffer);
/* set nrf en ch */
sendbuffer[0]=0x01;
nrf24lxx_control(&nrf24l01_device.device,SET_EN_CH,sendbuffer);
sendbuffer[0]=0x1a;
nrf24lxx_control(&nrf24l01_device.device,SET_RF_RETR,sendbuffer);
/* set nrf rf ch */
sendbuffer[0]=40;
nrf24lxx_control(&nrf24l01_device.device,SET_RF_CH,sendbuffer);
sendbuffer[0]=0x0f;
nrf24lxx_control(&nrf24l01_device.device,SET_RF_SETUP,sendbuffer);
nrf24l01_device.device.type    = RT_Device_Class_Char;
nrf24l01_device.device.init    = nrf24lxx_init;
nrf24l01_device.device.open    = nrf24lxx_open;
nrf24l01_device.device.close   = nrf24lxx_close;
nrf24l01_device.device.read    = nrf24lxx_read;
nrf24l01_device.device.write   = nrf24lxx_write;
nrf24l01_device.device.control = nrf24lxx_control;
    /* no private */
    nrf24l01_device.device.user_data = RT_NULL;
/*  nrf thread init */
rt_thread_t tid;
tid = rt_thread_create("nrf",
nrf_data_thread_entry,
RT_NULL,
256,
RT_THREAD_PRIORITY_MAX - 2,
20);
if (tid != RT_NULL)
rt_thread_startup(tid);
spi_nrf_hw_init();
    rt_device_register(&nrf24l01_device.device, nrf_device_name,
    return RT_EOK;
    /* enter interrupt */
    rt_interrupt_enter();
    NRF_TRACE("spi_nrf_isr
    /* leave interrupt */
    rt_interrupt_leave();
#include
void nrf_info(void)
",sendbuffer[0],
sendbuffer[1],
sendbuffer[2],
sendbuffer[3],
sendbuffer[4]);
",sendbuffer[0],
sendbuffer[1],
sendbuffer[2],
sendbuffer[3],
sendbuffer[4]);
rt_kprintf("RF_CH      = 0x%2d
#endif
struct nrf_data_packet
    rt_uint8_t data_len;
  rt_uint8_t buffer[NRF_SIZE];
struct rt_event            data_event;
    struct nrf_data_packet tx_packet;
    struct nrf_data_packet     rx_packet;
举报
CDCNKA
2022-4-1 17:04:49
这个代码在ISR中可以读取中断寄存器,然后根据超时,发送成功,接收成功发出不同的event,同时接收还需要读出接收到的数据。
用户线程根据不同的event去处理,例如三个event 0x01 0x02 0x04 ,分别代表前3种事件,0x08代表有数据需要发送事件,这样就用户线程只需要永远等待事件,然后根据不同事件去处理即可。
举报
更多回帖
