导出gerber文件是出现以下提示信息,不知道是哪里出现在问题,之前在别的电脑上导出gerber的文件是正常的,换了这台电脑就出现这个问题,也不知道是哪里的设置问题还是设计问题,求大神解答!!!
提示如下:
Results from parameter file ... DEVICE-TYPE GERBER_RS274X OUTPUT-UNITS INCHES FILM-SIZE 2400000 1600000 FORMAT 3.5 ABORT-ON-ERROR NO SCALE 1 SUPPRESS-LEAD-ZEROES YES SUPPRESS-TRAIL-ZEROES NO SUPPRESS-EQUAL YES UNDEF-APT-CONT NO================================================================ PROCESSING FILM < BOTTOM > TO FILE < D:/HRwork/HR500-AFG-411S/BOTTOM.art > ...================================================================ FILM PARAMETERS : --------------------------------------------------------- Undefined line width 5.00 Mirror code NONE Rotate angle NONE Offset x: 0.00 Offset y: 0.00 Plot nega
tive NO Suppress unconnected internal
pads NO Draw holes only NO APERTURES USED: --------------------------------------------------------- TYPE SIZE/NAME ROT MIRROR MODE --------------------------------------------------------- CIRCLE 0.00300 DARK CIRCLE 0.00394 DARK CIRCLE 0.00500 DARK CIRCLE 0.00600 DARK CIRCLE 0.00800 DARK CIRCLE 0.00900 DARK CIRCLE 0.01000 DARK CIRCLE 0.01200 DARK CIRCLE 0.01500 DARK CIRCLE 0.01600 DARK CIRCLE 0.02000 DARK CIRCLE 0.02100 DARK CIRCLE 0.02200 DARK CIRCLE 0.02400 DARK CIRCLE 0.02500 DARK CIRCLE 0.02800 DARK CIRCLE 0.03000 DARK CIRCLE 0.03200 DARK CIRCLE 0.03500 DARK CIRCLE 0.04000 DARK CIRCLE 0.04700 DARK CIRCLE 0.05000 DARK CIRCLE 0.05118 DARK CIRCLE 0.05400 DARK CIRCLE 0.06000 DARK CIRCLE 0.06300 DARK CIRCLE 0.07000 DARK CIRCLE 0.07874 DARK CIRCLE 0.08000 DARK CIRCLE 0.08661 DARK CIRCLE 0.10236 DARK CIRCLE 0.12600 DARK CIRCLE 0.12800 DARK SQUARE 0.02000 0.000 NO DARK SQUARE 0.02000 45.000 NO DARK SQUARE 0.04000 0.000 NO DARK SQUARE 0.06000 0.000 NO DARK SQUARE 0.07870 0.000 NO DARK SQUARE 0.15000 0.000 NO DARK RECTANGLE 0.02500 x 0.06000 90.000 NO DARK RECTANGLE 0.03150 x 0.03346 0.000 NO DARK RECTANGLE 0.03150 x 0.03346 45.000 NO DARK RECTANGLE 0.03150 x 0.03346 90.000 NO DARK RECTANGLE 0.04331 x 0.05118 0.000 NO DARK RECTANGLE 0.04331 x 0.05118 90.000 NO DARK RECTANGLE 0.05510 x 0.06500 0.000 NO DARK RECTANGLE 0.05510 x 0.06500 45.000 NO DARK RECTANGLE 0.07100 x 0.07900 0.000 NO DARK RECTANGLE 0.07100 x 0.07900 90.000 NO DARK RECTANGLE 0.07900 x 0.11000 90.000 NO DARK RECTANGLE 0.12200 x 0.08700 90.000 NO DARK OBLONG 0.00900 x 0.04000 90.000 NO DARK OBLONG 0.04000 x 0.00900 90.000 NO DARK OBLONG 0.05118 x 0.05906 0.000 NO DARK BOTTOM created.================================================================ PROCESSING FILM < SOLDERMASK_TOP > TO FILE < D:/HRwork/HR500-AFG-411S/SOLDERMASK_TOP.art > ...================================================================ FILM PARAMETERS : --------------------------------------------------------- Undefined line width 5.00 Mirror code NONE Rotate angle NONE Offset x: 0.00 Offset y: 0.00 Plot negative NO Suppress unconnected internal pads NO Draw holes only NO APERTURES USED: --------------------------------------------------------- TYPE SIZE/NAME ROT MIRROR MODE --------------------------------------------------------- CIRCLE 0.00300 DARK CIRCLE 0.00500 DARK CIRCLE 0.05300 DARK CIRCLE 0.05512 DARK CIRCLE 0.06000 DARK CIRCLE 0.06600 DARK CIRCLE 0.06900 DARK CIRCLE 0.08268 DARK CIRCLE 0.09055 DARK CIRCLE 0.10630 DARK CIRCLE 0.12000 DARK CIRCLE 0.13400 DARK CIRCLE 0.13780 DARK SQUARE 0.02600 0.000 NO DARK SQUARE 0.02600 45.000 NO DARK SQUARE 0.06600 0.000 NO DARK SQUARE 0.08470 0.000 NO DARK SQUARE 0.27953 0.000 NO DARK RECTANGLE 0.01970 x 0.07870 0.000 NO DARK RECTANGLE 0.02200 x 0.06300 90.000 NO DARK RECTANGLE 0.03543 x 0.03740 0.000 NO DARK RECTANGLE 0.03543 x 0.03740 45.000 NO DARK RECTANGLE 0.03543 x 0.03740 90.000 NO DARK RECTANGLE 0.04724 x 0.05512 0.000 NO DARK RECTANGLE 0.04724 x 0.05512 90.000 NO DARK RECTANGLE 0.05709 x 0.01181 0.000 NO DARK RECTANGLE 0.05906 x 0.00787 0.000 NO DARK RECTANGLE 0.05906 x 0.00787 90.000 NO DARK RECTANGLE 0.07200 x 0.09900 90.000 NO DARK RECTANGLE 0.07700 x 0.08500 0.000 NO DARK RECTANGLE 0.07835 x 0.07598 90.000 NO DARK RECTANGLE 0.09100 x 0.03100 90.000 NO DARK RECTANGLE 0.14567 x 0.06693 0.000 NO DARK RECTANGLE 0.14567 x 0.06693 90.000 NO DARK RECTANGLE 0.23622 x 0.15748 90.000 NO DARK OBLONG 0.05512 x 0.06299 0.000 NO DARK SOLDERMASK_TOP created.================================================================ PROCESSING FILM < SOLDERMASK_BOT > TO FILE < D:/HRwork/HR500-AFG-411S/SOLDERMASK_BOT.art > ...================================================================ FILM PARAMETERS : --------------------------------------------------------- Undefined line width 5.00 Mirror code NONE Rotate angle NONE Offset x: 0.00 Offset y: 0.00 Plot negative NO Suppress unconnected internal pads NO Draw holes only NO APERTURES USED: --------------------------------------------------------- TYPE SIZE/NAME ROT MIRROR MODE --------------------------------------------------------- CIRCLE 0.00300 DARK CIRCLE 0.00500 DARK CIRCLE 0.05300 DARK CIRCLE 0.05906 DARK CIRCLE 0.06000 DARK CIRCLE 0.06600 DARK CIRCLE 0.06900 DARK CIRCLE 0.08268 DARK CIRCLE 0.09055 DARK CIRCLE 0.10630 DARK CIRCLE 0.13400 DARK CIRCLE 0.13780 DARK SQUARE 0.02600 0.000 NO DARK SQUARE 0.02600 45.000 NO DARK SQUARE 0.04400 0.000 NO DARK SQUARE 0.06600 0.000 NO DARK SQUARE 0.08470 0.000 NO DARK SQUARE 0.15600 0.000 NO DARK RECTANGLE 0.02900 x 0.06400 90.000 NO DARK RECTANGLE 0.03543 x 0.03740 0.000 NO DARK RECTANGLE 0.03543 x 0.03740 45.000 NO DARK RECTANGLE 0.03543 x 0.03740 90.000 NO DARK RECTANGLE 0.04724 x 0.05512 0.000 NO DARK RECTANGLE 0.04724 x 0.05512 90.000 NO DARK RECTANGLE 0.05910 x 0.06890 0.000 NO DARK RECTANGLE 0.05910 x 0.06890 45.000 NO DARK RECTANGLE 0.07700 x 0.08500 0.000 NO DARK RECTANGLE 0.07700 x 0.08500 90.000 NO DARK RECTANGLE 0.08300 x 0.11400 90.000 NO DARK RECTANGLE 0.12800 x 0.09300 90.000 NO DARK OBLONG 0.01500 x 0.04600 90.000 NO DARK OBLONG 0.04600 x 0.01500 90.000 NO DARK OBLONG 0.05512 x 0.06299 0.000 NO DARK SOLDERMASK_BOT created.================================================================ PROCESSING FILM < SILKSCREEN_TOP > TO FILE < D:/HRwork/HR500-AFG-411S/SILKSCREEN_TOP.art > ...================================================================ FILM PARAMETERS : --------------------------------------------------------- Undefined line width 5.00 Mirror code NONE Rotate angle NONE Offset x: 0.00 Offset y: 0.00 Plot negative NO Suppress unconnected internal pads NO Draw holes only NO APERTURES USED: --------------------------------------------------------- TYPE SIZE/NAME ROT MIRROR MODE --------------------------------------------------------- CIRCLE 0.00300 DARK CIRCLE 0.00394 DARK CIRCLE 0.00400 DARK CIRCLE 0.00472 DARK CIRCLE 0.00500 DARK CIRCLE 0.00591 DARK CIRCLE 0.00600 DARK CIRCLE 0.00787 DARK CIRCLE 0.00800 DARK CIRCLE 0.00984 DARK CIRCLE 0.01000 DARK CIRCLE 0.01600 DARK SILKSCREEN_TOP created.================================================================ PROCESSING FILM < SILKSCREEN_BOT > TO FILE < D:/HRwork/HR500-AFG-411S/SILKSCREEN_BOT.art > ...================================================================ FILM PARAMETERS : --------------------------------------------------------- Undefined line width 5.00 Mirror code NONE Rotate angle NONE Offset x: 0.00 Offset y: 0.00 Plot negative NO Suppress unconnected internal pads NO Draw holes only NO APERTURES USED: --------------------------------------------------------- TYPE SIZE/NAME ROT MIRROR MODE --------------------------------------------------------- CIRCLE 0.00300 DARK CIRCLE 0.00394 DARK CIRCLE 0.00400 DARK CIRCLE 0.00472 DARK CIRCLE 0.00500 DARK CIRCLE 0.00591 DARK CIRCLE 0.00600 DARK CIRCLE 0.01000 DARK CIRCLE 0.01575 DARK CIRCLE 0.01969 DARK SILKSCREEN_BOT created.================================================================ PROCESSING FILM < PASTMASK_TOP > TO FILE < D:/HRwork/HR500-AFG-411S/PASTMASK_TOP.art > ...================================================================ FILM PARAMETERS : --------------------------------------------------------- Undefined line width 5.00 Mirror code NONE Rotate angle NONE Offset x: 0.00 Offset y: 0.00 Plot negative NO Suppress unconnected internal pads NO Draw holes only NO APERTURES USED: --------------------------------------------------------- TYPE SIZE/NAME ROT MIRROR MODE --------------------------------------------------------- CIRCLE 0.00300 DARK CIRCLE 0.00500 DARK RECTANGLE 0.01600 x 0.05700 90.000 NO DARK RECTANGLE 0.01970 x 0.07870 0.000 NO DARK RECTANGLE 0.03150 x 0.03346 0.000 NO DARK RECTANGLE 0.03150 x 0.03346 45.000 NO DARK RECTANGLE 0.03150 x 0.03346 90.000 NO DARK RECTANGLE 0.04331 x 0.05118 0.000 NO DARK RECTANGLE 0.04331 x 0.05118 90.000 NO DARK RECTANGLE 0.05709 x 0.01181 0.000 NO DARK RECTANGLE 0.05906 x 0.00787 0.000 NO DARK RECTANGLE 0.05906 x 0.00787 90.000 NO DARK RECTANGLE 0.06800 x 0.09500 90.000 NO DARK RECTANGLE 0.07100 x 0.07900 0.000 NO DARK RECTANGLE 0.07441 x 0.07205 90.000 NO DARK RECTANGLE 0.08500 x 0.02500 90.000 NO DARK RECTANGLE 0.13780 x 0.05906 0.000 NO DARK RECTANGLE 0.13780 x 0.05906 90.000 NO DARK RECTANGLE 0.23622 x 0.15748 90.000 NO DARK PAD SHAPE SH20Q_RNO_T 0.000 NO DARK PAD SHAPE SH20Q_LNO_T 0.000 NO DARK PAD SHAPE SH20Q_LNO_T 45.000 NO DARK PAD SHAPE SH20Q_RNO_T 90.000 NO DARK PAD SHAPE SH20Q_LNO_T 90.000 NO DARK PAD SHAPE SH20Q_LNO_T 180.000 NO DARK PAD SHAPE SH20Q_RNO_T 180.000 NO DARK PAD SHAPE SH20Q_RNO_T 225.000 NO DARK PAD SHAPE SH20Q_LNO_T 225.000 NO DARK PAD SHAPE SH20Q_LNO_T 270.000 NO DARK PAD SHAPE SH20Q_RNO_T 270.000 NO DARK PAD SHAPE SH20Q_RNO_T 315.000 NO DARK PAD SHAPE SH20Q_LNO_T 315.000 NO DARK PASTMASK_TOP created.================================================================ PROCESSING FILM < PASTMASK_BOT > TO FILE < D:/HRwork/HR500-AFG-411S/PASTMASK_BOT.art > ...================================================================ FILM PARAMETERS : --------------------------------------------------------- Undefined line width 5.00 Mirror code NONE Rotate angle NONE Offset x: 0.00 Offset y: 0.00 Plot negative NO Suppress unconnected internal pads NO Draw holes only NO APERTURES USED: --------------------------------------------------------- TYPE SIZE/NAME ROT MIRROR MODE --------------------------------------------------------- CIRCLE 0.00300 DARK CIRCLE 0.00500 DARK SQUARE 0.04000 0.000 NO DARK SQUARE 0.15000 0.000 NO DARK RECTANGLE 0.02500 x 0.06000 90.000 NO DARK RECTANGLE 0.03150 x 0.03346 0.000 NO DARK RECTANGLE 0.03150 x 0.03346 45.000 NO DARK RECTANGLE 0.03150 x 0.03346 90.000 NO DARK RECTANGLE 0.04331 x 0.05118 0.000 NO DARK RECTANGLE 0.04331 x 0.05118 90.000 NO DARK RECTANGLE 0.05510 x 0.06500 0.000 NO DARK RECTANGLE 0.05510 x 0.06500 45.000 NO DARK RECTANGLE 0.07100 x 0.07900 0.000 NO DARK RECTANGLE 0.07100 x 0.07900 90.000 NO DARK RECTANGLE 0.07900 x 0.11000 90.000 NO DARK RECTANGLE 0.12200 x 0.08700 90.000 NO DARK OBLONG 0.00900 x 0.04000 90.000 NO DARK OBLONG 0.04000 x 0.00900 90.000 NO DARK PAD SHAPE SH20Q_RNO_T 0.000 YES DARK PAD SHAPE SH20Q_LNO_T 0.000 YES DARK PAD SHAPE SH20Q_LNO_T 45.000 YES DARK PAD SHAPE SH20Q_RNO_T 45.000 YES DARK PAD SHAPE SH20Q_RNO_T 90.000 YES DARK PAD SHAPE SH20Q_LNO_T 90.000 YES DARK PAD SHAPE SH20Q_LNO_T 180.000 YES DARK PAD SHAPE SH20Q_RNO_T 180.000 YES DARK PAD SHAPE SH20Q_LNO_T 270.000 YES DARK PAD SHAPE SH20Q_RNO_T 270.000 YES DARK PASTMASK_BOT created.================================================================ PROCESSING FILM < DRILL_LAYER > TO FILE < D:/HRwork/HR500-AFG-411S/DRILL_LAYER.art > ...================================================================ FILM PARAMETERS : --------------------------------------------------------- Undefined line width 5.00 Mirror code NONE Rotate angle NONE Offset x: 0.00 Offset y: 0.00 Plot negative NO Suppress unconnected internal pads NO Draw holes only NO WARNING: 0 width line found at (747.70 -7606.64) ... using undefined line width of 5.00 WARNING: Multiple 0 width lines; all will be treated the same as the first. ... using undefined line width of 5.00 APERTURES USED: --------------------------------------------------------- TYPE SIZE/NAME ROT MIRROR MODE --------------------------------------------------------- CIRCLE 0.00300 DARK CIRCLE 0.00500 DARK CIRCLE 0.00600 DARK DRILL_LAYER created with warnings================================================================ PROCESSING FILM < TOP > TO FILE < D:/HRwork/HR500-AFG-411S/TOP.art > ...================================================================ FILM PARAMETERS : --------------------------------------------------------- Undefined line width 5.00 Mirror code NONE Rotate angle NONE Offset x: 0.00 Offset y: 0.00 Plot negative NO Suppress unconnected internal pads NO Draw holes only NO WARNING: Film contains objects with associated DRCs (3). In the design editor view this film and enable visibility for the associated DRC layer. Verify the DRCs are approved exceptions to your rules. APERTURES USED: --------------------------------------------------------- TYPE SIZE/NAME ROT MIRROR MODE --------------------------------------------------------- CIRCLE 0.00300 DARK CIRCLE 0.00394 DARK CIRCLE 0.00500 DARK CIRCLE 0.00600 DARK CIRCLE 0.00700 DARK CIRCLE 0.00800 DARK CIRCLE 0.00900 DARK CIRCLE 0.01000 DARK CIRCLE 0.01200 DARK CIRCLE 0.01500 DARK CIRCLE 0.01600 DARK CIRCLE 0.02000 DARK CIRCLE 0.02200 DARK CIRCLE 0.02400 DARK CIRCLE 0.02500 DARK CIRCLE 0.02800 DARK CIRCLE 0.03000 DARK CIRCLE 0.03500 DARK CIRCLE 0.04000 DARK CIRCLE 0.04700 DARK CIRCLE 0.05000 DARK CIRCLE 0.05118 DARK CIRCLE 0.05400 DARK CIRCLE 0.06000 DARK CIRCLE 0.06300 DARK CIRCLE 0.07874 DARK CIRCLE 0.08000 DARK CIRCLE 0.08661 DARK CIRCLE 0.10236 DARK CIRCLE 0.12000 DARK CIRCLE 0.12600 DARK CIRCLE 0.12800 DARK SQUARE 0.02000 0.000 NO DARK SQUARE 0.02000 45.000 NO DARK SQUARE 0.06000 0.000 NO DARK SQUARE 0.07870 0.000 NO DARK SQUARE 0.27559 0.000 NO DARK RECTANGLE 0.01600 x 0.05700 90.000 NO DARK RECTANGLE 0.01970 x 0.07870 0.000 NO DARK RECTANGLE 0.03150 x 0.03346 0.000 NO DARK RECTANGLE 0.03150 x 0.03346 45.000 NO DARK RECTANGLE 0.03150 x 0.03346 90.000 NO DARK RECTANGLE 0.04331 x 0.05118 0.000 NO DARK RECTANGLE 0.04331 x 0.05118 90.000 NO DARK RECTANGLE 0.05709 x 0.01181 0.000 NO DARK RECTANGLE 0.05906 x 0.00787 0.000 NO DARK RECTANGLE 0.05906 x 0.00787 90.000 NO DARK RECTANGLE 0.06800 x 0.09500 90.000 NO DARK RECTANGLE 0.07100 x 0.07900 0.000 NO DARK RECTANGLE 0.07441 x 0.07205 90.000 NO DARK RECTANGLE 0.08500 x 0.02500 90.000 NO DARK RECTANGLE 0.13780 x 0.05906 0.000 NO DARK RECTANGLE 0.13780 x 0.05906 90.000 NO DARK RECTANGLE 0.23622 x 0.15748 90.000 NO DARK OBLONG 0.05118 x 0.05906 0.000 NO DARK TOP created with warnings------------------------------------------------------ SUMMARY: BOTTOM created. SOLDERMASK_TOP created. SOLDERMASK_BOT created. SILKSCREEN_TOP created. SILKSCREEN_BOT created. PASTMASK_TOP created. PASTMASK_BOT created. DRILL_LAYER created with warnings TOP created with warnings ARTWORK had warnings file:///C:UsersADMINI~1AppDataLocalTempSGPicFaceTpBq10820�0DC60FE.png
