输入框被软键盘遮挡的解决办法(Ability、Dialog都可以)
先放代码:
因为后来代码更新了,所以文章内容只是解决问题的一个思路。以代码为准!
理论上讲通过自定义Adapter,可以适配所有的情况
处理前后对比
处理前 | 处理前后 |
问题现状
安卓上面,输入框被软键盘遮挡,很简单
xml 配置
android:windowSof
tinputMode="adjustPan"
或者,java 配置
getWindow().setSoftInputMode(WindowManager.LayoutParams.SOFT_INPUT_ADJUST_PAN);
这样,软键盘弹出后,输入框就会自动上移。
鸿蒙上也有类似的设置,但是貌似没效果:
getWindow().setInputPanelDisplayType(WindowManager.LayoutConfig.INPUT_ADJUST_PAN);
解决过程
原理:
布局文件用ScrollView包起来
监听根布局大小变化,变小了,证明输入法弹出了。
滚动ScrollView,使当前焦点控件显示在软键盘上方。
核心代码:
public class MainAbilitySlice extends AbilitySlice {
private EventHandler mainHandler = new EventHandler(EventRunner.getMainEventRunner());
private MyTask myTask = null;
class MyTask implements Runnable {
private final int softHeight;
private final ScrollView root;
private final Rect decorRect;
public MyTask(int softHeight, ScrollView root, Rect decorRect) {
this.softHeight = softHeight;
this.root = root;
this.decorRect = decorRect;
@Override
public void run() {
Timber.d("onRefreshed() called with: softHeight = [ %s ]", softHeight);
Component focusView = root.findFocus();
int focusTop = focusView.getLocationOnScreen()[1];//焦点控件的左上角
root.fluentScrollByY(focusTop + focusView.getHeight() - decorRect.top - decorRect.getHeight() + 100);
@Override
public void onStart(Intent intent) {
super.onStart(intent);
super.setUIContent(ResourceTable.Layout_ability_main);
Optional
display = DisplayManager.getInstance().getDefaultDisplay(getContext());
Point pt = new Point();
display.get().getSize(pt);
int screenHeight = pt.getPointYToInt();//不包括状态栏(手机时间、wifi显示的那一部分,) 2211,状态栏是129,加起来就是2340
Timber.d("onRefreshed() called with: screenHeight = [ %s ]", screenHeight);
ScrollView root = (ScrollView) findComponentById(ResourceTable.Id_root);
root.setLayoutRefreshedListener(new Component.LayoutRefreshedListener() {
@Override
public void onRefreshed(Component component) {
//包括标题栏,但不包括状态栏。默认 大小 (0,129,1080,2340),top=129即状态栏 , height=2211。 同android的decorView
Rect decorRect = new Rect();
component.getWindowVisibleRect(decorRect);
Timber.d("onRefreshed() called with: rect = [ %s ]", decorRect);
if (decorRect.getHeight() == 0) {
//刚进入界面可能为0
return;
int softHeight = screenHeight - decorRect.getHeight();
if (softHeight > 100) {//当输入法高度大于100判定为输入法打开了
if (myTask != null) {
mainHandler.removeTask(myTask);
myTask = null;
mainHandler.postTask(myTask = new MyTask(softHeight, root, decorRect), 100);
特别说明: 滚动操作为什么要delay 100毫秒?因为点击一个输入框Component.LayoutRefreshedListener有时会反复调用多次,而且间隔时间小于10毫秒,所以会造成滚动距离不准确。用postTask之后,每次调用的时候会把之前的task remove掉,以最新的一次为准。
计算滚动距离
其中上面的大红框是decorRect(即当前Ability可视区域),下面的大黑框是输入法显示区域。其中,软键盘弹出后,输入框被软键盘挡住,图中的小红框。
所以,要滚动的距离就是图中的C=A-B。
可以优化的点:(有兴趣的朋友可以试一下,记得在评论区分享你的结果)
如果是Dialog中的输入框,当前的计算方法是否正确?
如果不用ScrollView,还有别的解决办法吗?
抽取出工具类或工具方法,代码复用。
2021-08-02优化
封装了TextFieldHelper工具类
自动上移TextField。监听软键盘显示、隐藏。
对于不同的布局处理TextField的移动有差异,所以定义了ITFHAdapter来适配。
我已经预定义了ScrollViewTFHAdapter、DirectionTFHAdapter处理根布局为ScrollView、DirectionalLayout的情况。
预定义了DlgTFHAdapter处理CommonDialog的情况(通过debug发现CommonDialog的根布局也是ScrollView,但是Dialog有一些特殊情,所以通过继承ScrollViewTFHAdapter来实现)。
