瑞芯微Rockchip开发者社区
直播中
王浩
7年用户 1312经验值
私信 关注
[问答]
为什么[RK3288][Android6.0]在移除uboot logo后还是会显示kernel logo呢
为什么[RK3288][Android6.0]在移除uboot logo后还是会显示kernel logo呢?怎样去解决这个问题呢?
回帖(1)
郑静东
2022-3-10 09:49:38
Platform: Rockchip
OS: Android 6.0
Kernel: 3.10.92
diff --git a/arch/arm/boot/dts/rk3288-b.dts b/arch/arm/boot/dts/rk3288-b.dts
index ad3bc1a..f000e29 100644
--- a/arch/arm/boot/dts/rk3288-b.dts
+++ b/arch/arm/boot/dts/rk3288-b.dts
@@ -353,7 +353,7 @@
&fb {
        rockchip,disp-mode = ;
-       rockchip,uboot-logo-on = <1>;
+       rockchip,uboot-logo-on = <0>;
在移除了uboot logo之后还是会显示kernel logo(kerne自带而并非rk显示logo机制),所有需要关闭.
diff --git a/arch/arm/configs/rockchip_b_defconfig b/arch/arm/configs/rockchip_b_defconfig
index 092dc3c..b699f96 100644
--- a/arch/arm/configs/rockchip_b_defconfig
+++ b/arch/arm/configs/rockchip_b_defconfig
@@ -439,7 +439,7 @@ CONFIG_RK1000_TVOUT_CVBS=y
CONFIG_RK3036_TV_ENCODER=y
CONFIG_ROCKCHIP_RGA=y
CONFIG_ROCKCHIP_RGA2=y
-CONFIG_LOGO=y
+#CONFIG_LOGO=y
CONFIG_SOUND=y
CONFIG_SND=y
# CONFIG_SND_SUPPORT_OLD_API is not set
kernel logo是根据是否开启了uboot logo display来决定是否要显示的,在函数rk_fb_register()中,
并且kernel logo的图片大小要和uboot一直,否则就无法显示。
#if !defined(CONFIG_FRAMEBUFFER_CONSOLE)
        if (dev_drv->prop == PRMRY) {
                u16 xact, yact;
                int format;
                u32 dsp_addr;
                struct fb_info *main_fbi = rk_fb->fb[0];
                main_fbi->fbops->fb_open(main_fbi, 1);
                main_fbi->var.pixclock = dev_drv->pixclock;
                if (dev_drv->iommu_enabled) {
                        if (dev_drv->mmu_dev)
                                rockchip_iovmm_set_fault_handler(dev_drv->dev,
                                                rk_fb_sysmmu_fault_handler);
                rk_fb_alloc_buffer(main_fbi);        /* only alloc memory for main fb */
                dev_drv->uboot_logo = support_uboot_display(); //是否支持uboot logo display
                if (dev_drv->uboot_logo &&
                    uboot_logo_offset && uboot_logo_base) {
                        int width, height, bits, xvir;
                        phys_addr_t start = uboot_logo_base + uboot_logo_offset;
                        unsigned int size = uboot_logo_size - uboot_logo_offset;
                        unsigned int nr_pages;
                        int ymirror = 0;
                        struct page **pages;
                        char *vaddr;
                        int i = 0;
                        if (dev_drv->ops->get_dspbuf_info)
                                dev_drv->ops->get_dspbuf_info(dev_drv, &xact,
                                        &yact, &format,        &dsp_addr, &ymirror);
                        nr_pages = size >> PAGE_SHIFT;
                        pages = kzalloc(sizeof(struct page) * nr_pages,
                                        GFP_KERNEL);
                        while (i < nr_pages) {
                                pages = phys_to_page(start);
                                start += PAGE_SIZE;
                                i++;
                        vaddr = vmap(pages, nr_pages, VM_MAP,
                                     pgprot_writecombine(PAGE_KERNEL));
                        if (!vaddr) {
                                pr_err("failed to vmap phy addr 0x%lxn",
                                       (long)(uboot_logo_base +
                                       uboot_logo_offset));
                                return -1;
                        //bmp图片解压
                        if (bmpdecoder(vaddr, main_fbi->screen_base, &width,
                                       &height, &bits)) {
                                kfree(pages);
                                vunmap(vaddr);
                                return 0;
                        kfree(pages);
                        vunmap(vaddr);
                            (width != xact || height != yact)) {
                                pr_err("can't support uboot kernel logo use different size [%dx%d] != [%dx%d]n",
                                       xact, yact, width, height);
                                return 0;
                        xvir = ALIGN(width * bits, 1 << 5) >> 5;
                        ymirror = 0;
                        local_irq_save(flags);
                        if (dev_drv->ops->wait_frame_start)
                                dev_drv->ops->wait_frame_start(dev_drv, 0);
                        if (dev_drv->ops->post_dspbuf) {
                                dev_drv->ops->post_dspbuf(dev_drv,
                                        main_fbi->fix.smem_start,
                                        rk_fb_data_fmt(0, bits),
                                        width, height, xvir,
                                        ymirror);
                                rk_fb_poll_wait_frame_complete();
                                if (dev_drv->ops->mmu_en)
                                        dev_drv->ops->mmu_en(dev_drv);
                                freed_index = 0;
                        local_irq_restore(flags);
                        return 0;
                } else if (dev_drv->uboot_logo && uboot_logo_base) {
                        u32 start = uboot_logo_base;
                        int logo_len, i = 0;
                        int y_mirror = 0;
                        char *vaddr;
                        int align = 0, xvir;
                                                      &yact, &format,
                                                      &start,
                                                      &y_mirror);
                        logo_len = rk_fb_pixel_width(format) * xact * yact >> 3;
                        if (logo_len > uboot_logo_size ||
                            logo_len > main_fbi->fix.smem_len) {
                                pr_err("logo size > uboot reserve buffer sizen");
                                return -1;
                        if (y_mirror)
                                start -= logo_len;
                        align = start % PAGE_SIZE;
                        start -= align;
                        nr_pages = PAGE_ALIGN(logo_len + align) >> PAGE_SHIFT;
                                        GFP_KERNEL);
                                start += PAGE_SIZE;
                                i++;
                        if (!vaddr) {
                                pr_err("failed to vmap phy addr 0x%xn",
                                       start);
                                return -1;
                        memcpy(main_fbi->screen_base, vaddr + align, logo_len);
                        kfree(pages);
                        vunmap(vaddr);
                        xvir = ALIGN(xact * rk_fb_pixel_width(format),
                                     1 << 5) >> 5;
                                        main_fbi->fix.smem_start +
                                        (y_mirror ? logo_len : 0),
                                        format,        xact, yact,
                                        xvir,
                                        y_mirror);
                                freed_index = 0;
                        return 0;
                } else {
                                freed_index = 0;
#if defined(CONFIG_LOGO)
                main_fbi->fbops->fb_set_par(main_fbi);
#if  defined(CONFIG_LOGO_LINUX_BMP)
                if (fb_prewine_bmp_logo(main_fbi, FB_ROTATE_UR)) {
                        fb_set_cmap(&main_fbi->cmap, main_fbi);
                        fb_show_bmp_logo(main_fbi, FB_ROTATE_UR);
#else
                if (fb_prepare_logo(main_fbi, FB_ROTATE_UR)) {
                        fb_show_logo(main_fbi, FB_ROTATE_UR);
#endif
                main_fbi->fbops->fb_pan_display(&main_fbi->var, main_fbi);
#endif
        } else {
                struct fb_info *extend_fbi = rk_fb->fb[dev_drv->fb_index_base];
                extend_fbi->var.pixclock = rk_fb->fb[0]->var.pixclock;
                extend_fbi->fbops->fb_open(extend_fbi, 1);
                rk_fb_alloc_buffer(extend_fbi);
#endif
举报
更多回帖
