瑞芯微Rockchip开发者社区
直播中
遇鱼余的小白
13年用户 522经验值
私信 关注
[问答]
怎样去解决RK3288在Recovery模式下显示旋转180度的问题呢
怎样去解决RK3288在Recovery模式下显示旋转180度的问题呢?其调用过程是怎样的?
回帖(1)
姬中岩
2022-3-10 10:53:06
Platform: ROCKCHIP
OS: Android 6.0
Kernel: 3.10.92
解决方法:
device/rockchip/common/BoardConfig.mk:
#rotate screen to 0, 90, 180, 270
#0:   rotate_0
#90:  rotate_90
#180: rotate_180
#270: rotate_270
ROTATE_SCREEN := rotate_180
调用过程:
bootable/recovery/minui/Android.mk:
ifeq ($(strip $(ROTATE_SCREEN)), rotate_0)
    LOCAL_CFLAGS += -DRotateScreen_0
endif
ifeq ($(strip $(ROTATE_SCREEN)), rotate_90)
    LOCAL_CFLAGS += -DRotateScreen_90
endif
ifeq ($(strip $(ROTATE_SCREEN)), rotate_180)
    LOCAL_CFLAGS += -DRotateScreen_180
endif
ifeq ($(strip $(ROTATE_SCREEN)), rotate_270)
    LOCAL_CFLAGS += -DRotateScreen_270
endif
bootable/recovery/minui/graphics_fbdev.cpp
static GRSurface* fbdev_flip(minui_backend* backend __unused) {
#ifdef RotateScreen_90
    rk_rotate_surface_90(&gr_framebuffer[1-displayed_buffer], gr_framebuffer[1-displayed_buffer].height, gr_framebuffer[1-displayed_buffer].width);
#elif defined RotateScreen_180
    rk_rotate_surface_180(&gr_framebuffer[1-displayed_buffer]);
#elif defined RotateScreen_270
    rk_rotate_surface_270(&gr_framebuffer[1-displayed_buffer], gr_framebuffer[1-displayed_buffer].height, gr_framebuffer[1-displayed_buffer].width);
#endif
void rk_rotate_surface_180(GRSurface* surface)
    GGLuint width = surface->width;
    GGLuint height = surface->height;
    int byt = 4; // 4 byte for ARGB_8888 (2 byte for RGB_565)
    int length = width * height;
    GGLubyte* des_data = (GGLubyte *)malloc(sizeof(GGLubyte)*length*byt);
    memcpy(des_data,surface->data,sizeof(GGLubyte)*length*byt);
    memset(surface->data, 0, sizeof(GGLubyte)*length*byt);
    int i = 0;
    for (i=0; i
        surface->data[i*byt] = des_data[(length-i-1)*byt];
        surface->data[i*byt+1] = des_data[(length-i-1)*byt+1];
        surface->data[i*byt+2] = des_data[(length-i-1)*byt+2];
        surface->data[i*byt+3] = des_data[(length-i-1)*byt+3];
    free(des_data);
举报
更多回帖
