瑞芯微Rockchip开发者社区
直播中
独当一面
11年用户 877经验值
擅长:可编程逻辑
私信 关注
[问答]
如何对RK3399 4G模块EC20进行移植并调试呢
如何对RK3399 4G模块EC20进行移植并调试呢?有哪些步骤?
回帖(1)
郑雅颖
2022-3-7 17:32:29
CPU:RK3399
系统:Android 7.1
1、通过串口打印或者adb获取模块的 pid 和 vid,顺便可以看到生成 4 个虚拟串口 /dev/ttyUSB*
[ 11.734379] u*** 1-1.1: new high-speed USB device number 3 using ehci-platform
[11.828247] u*** 1-1.1: New USB device found, idVendor=2c7c, idProduct=0125[11.828386] u*** 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0[11.828413] u*** 1-1.1: Product: Android
[11.828436] u*** 1-1.1: Manufacturer: Android
[11.835480] option 1-1.1:1.0: GSM modem (1-port) converter detected
[11.841217] u*** 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
[11.844988] option 1-1.1:1.1: GSM modem (1-port) converter detected
[11.851892] u*** 1-1.1: GSM modem (1-port) converter now attached to ttyUSB1
[11.853964] option 1-1.1:1.2: GSM modem (1-port) converter detected
[11.864677] u*** 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
[11.865658] option 1-1.1:1.3: GSM modem (1-port) converter detected
[11.871387] u*** 1-1.1: GSM modem (1-port) converter now attached to ttyUSB3
2、在代码中添加模块的 pid 和 vid,原始代码中已经包含移远的几个模块,仿照现有的添加 EC20
diff --git a/kernel/drivers/u***/serial/option.c b/kernel/drivers/u***/serial/option.c
index 1799aa0..f6c9e5d100644
--- a/kernel/drivers/u***/serial/option.c+++ b/kernel/drivers/u***/serial/option.c
@@-241,6 +241,7 @@ static void option_instat_callback(struct urb *urb);#define QUECTEL_VENDOR_ID 0x2c7c
/*These Quectel products use Quectel's vendor ID*/
+#define QUECTEL_PRODUCT_EC20 0x0125
#define QUECTEL_PRODUCT_EC21 0x0121
#define QUECTEL_PRODUCT_EC25 0x0125
#define QUECTEL_PRODUCT_BG96 0x0296@@-1200,6 +1201,8 @@ static const struct u***_device_id option_ids[] ={
{ USB_DEVICE(QUALCOMM_VENDOR_ID, YUGA_PRODUCT_CLM920_NC5),
.driver_info= (kernel_ulong_t)&yuga_clm920_nc5_blacklist },/*Quectel products using Quectel vendor ID*/
+{ USB_DEVICE(QUECTEL_VENDOR_ID, QUECTEL_PRODUCT_EC20),+ .driver_info = (kernel_ulong_t)&net_intf4_blacklist },
{ USB_DEVICE(QUECTEL_VENDOR_ID, QUECTEL_PRODUCT_EC21),
.driver_info= (kernel_ulong_t)&net_intf4_blacklist },
{ USB_DEVICE(QUECTEL_VENDOR_ID, QUECTEL_PRODUCT_EC25)
3、添加模块的 so 库,此库需要移远提供,so 支持的系统要匹配,将 so 库拷贝到下面的路径
vendor/rockchip/common/phone/lib/libreference-ril.so
4、打开 device/rockchip/common/device.mk 文件,修改 rild.libpath 路径为 rild.libpath=/system/lib64/libreference-ril.so
diff --git a/device/rockchip/common/device.mk b/device/rockchip/common/device.mk
index be2cb2c..69034a7100755
--- a/device/rockchip/common/device.mk+++ b/device/rockchip/common/device.mk
@@-699,7 +699,7@@ endif
ifeq ($(strip $(BOARD_HAVE_DONGLE)),true)
ifeq ($(strip $(TARGET_ARCH)), arm64)
PRODUCT_PROPERTY_OVERRIDES+=- rild.libpath=/system/lib64/libril-rk29-dataonly.so+ rild.libpath=/system/lib64/libreference-ril.soelsePRODUCT_PROPERTY_OVERRIDES+=
rild.libpath=/system/lib/libril-rk29-dataonly.so
因为 rk3399 是64位 CPU,所以 ifeq ($(strip $(TARGET_ARCH)), arm64) 条件成立。
但是前提都是 BOARD_HAVE_DONGLE 变量值为 true
注:本人测试,修改下面两个文件中的 rild.libpath 不起作用
device/rockchip/rk3399/system.prop
device/rockchip/rk3399/rk3399_all/system.prop
5、编译时将 so 库拷贝到上面指定目录 /system/lib64/libreference-ril.so
diff --git a/vendor/rockchip/common/phone/phone.mk b/vendor/rockchip/common/phone/phone.mk
index 946aacd..f8fc6e7100755
--- a/vendor/rockchip/common/phone/phone.mk+++ b/vendor/rockchip/common/phone/phone.mk
@@-8,7 +8,8 @@ PRODUCT_COPY_FILES +=
$(CUR_PATH)/phone/etc/ppp/ip-down:system/etc/ppp/ip-down
$(CUR_PATH)/phone/etc/ppp/ip-up:system/etc/ppp/ip-up
$(CUR_PATH)/phone/etc/ppp/call-pppd:system/etc/ppp/call-pppd - $(CUR_PATH)/phone/etc/operator_table:system/etc/operator_table+ $(CUR_PATH)/phone/etc/operator_table:system/etc/operator_table + $(CUR_PATH)/phone/lib/libreference-ril.so:system/lib64/libreference-ril.so
ifeq ($(strip $(PRODUCT_MODEM)), DTS4108C)
PRODUCT_COPY_FILES+=
6、设置 BOARD_HAVE_DONGLE 变量
diff --git a/device/rockchip/rk3399/rk3399_all.mk b/device/rockchip/rk3399/rk3399_all.mk
index 7a2d870..ce5060c100755
--- a/device/rockchip/rk3399/rk3399_all.mk+++ b/device/rockchip/rk3399/rk3399_all.mk
@@-63,7 +63,7 @@ BOARD_NFC_SUPPORT := falseBOARD_HAS_GPS := false#for 3G/4G modem dongle support-BOARD_HAVE_DONGLE := false
+BOARD_HAVE_DONGLE := trueBOARD_GRAVITY_SENSOR_SUPPORT := true
此时移植完成,只要 so 库没问题,就可以正常上网。
如果 radio log 中打印如下信息:
RIL_SAP_Init not defined or exported in /system/lib64/libril-rk29-dataonly.so
检查 rild.libpath 的路径和名称是否正确。
No /proc/cmdline exception=java.io.FileNotFoundException: /proc/cmdline (Permission denied)
举报
更多回帖
