瑞芯微Rockchip开发者社区
直播中
hxjq
12年用户 828经验值
私信 关注
[问答]
如何解决firefly rk3128 linux内核适配问题?
回帖(1)
徐珺
2022-3-4 14:26:41
1.使用你的方法:git pull bitbucket fireprime:fireprime提示
Already up-to-date.
2.使用你提供的附件,现象一样
3.我的目的是我的串口线,内核打印到一部分就停止了,用firefly官方固件解包的内核就串口能正常输出,一直到进入系统。
目前我的串口打印停止在下面这个位置
[    1.076138] ohci-rockchip 101e0000.u***: RK OHCI Host Controller
[    1.076193] ohci-rockchip 101e0000.u***: new USB bus registered, assigned bus number 2
[    1.076279] ohci-rockchip 101e0000.u***: irq 64, io mem 0x101e0000
[    1.137041] u*** u***2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.137076] u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.137103] u*** u***2: Product: RK OHCI Host Controller
[    1.137127] u*** u***2: Manufacturer: Linux 3.10.0 ohci_hcd
[    1.137151] u*** u***2: SerialNumber: 101e0000.u***
[    1.138099] hub 2-0:1.0: USB hub found
[    1.138161] hub 2-0:1.0: 1 port detected
[    1.138774] u***core: registered new interface driver cdc_acm
[    1.138801] cdc_acdel driver for USB modems and ISDN adapters
[    1.138920] u***core: registered new interface driver u***lp
[    1.139013] u***core: registered new interface driver cdc_wdm
[    1.139157] u***core: registered new interface driver u***-storage
[    1.139239] u***core: registered new interface driver ums-alauda
[    1.139318] u***core: registered new interface driver ums-cypress
[    1.139421] u***core: registered new interface driver ums-datafab
[    1.139501] u***core: registered new interface driver ums_eneub6250
[    1.139580] u***core: registered new interface driver ums-freecom
[    1.139661] u***core: registered new interface driver ums-isd200
[    1.139740] u***core: registered new interface driver ums-jumpshot
[    1.139819] u***core: registered new interface driver ums-karma
[    1.139897] u***core: registered new interface driver ums-onetouch
[    1.139977] u***core: registered new interface driver ums-sddr09
[    1.140055] u***core: registered new interface driver ums-sddr55
[    1.140133] u***core: registered new interface driver ums-u***at
[    1.140333] u***core: registered new interface driver u***serial
[    1.140423] u***core: registered new interface driver u***serial_generic
[    1.140492] u***serial: USB Serial support registered for generic
[    1.140575] u***core: registered new interface driver option
[    1.140643] u***serial: USB Serial support registered for GSM modem (1-port)
[    1.140861] u***core: registered new interface driver trancevibrator
[    1.140885] u***20_otg: version 3.10a 21-DEC-2012
[    1.141561] e3500040
[    1.141589] Core Release: 2.91a
[    1.141610] Setting default values for core params
[    1.141880] Using Buffer DMA mode
[    1.141904] Periodic Transfer Interrupt Enhancement - disabled
[    1.141924] Multiprocessor Interrupt Enhancement - disabled
[    1.141945] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.141964] ^^^^^^^^^^^^^^^^^Device Mode
[    1.141991] Dedicated Tx FIFOs mode
[    1.142026] pcd_init otg_dev = de1c3d40
[    1.142359] u***20_otg 10180000.u***: DWC OTG Controller
[    1.142419] u***20_otg 10180000.u***: new USB bus registered, assigned bus number 3
[    1.142483] u***20_otg 10180000.u***: irq 42, io mem 0x00000000
[    1.142611] u*** u***3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.142643] u*** u***3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.142669] u*** u***3: Product: DWC OTG Controller
[    1.142693] u*** u***3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[    1.142718] u*** u***3: SerialNumber: 10180000.u***
[    1.143656] hub 3-0:1.0: USB hub found
[    1.143716] hub 3-0:1.0: 1 port detected
[    1.144348] u***20_host: version 3.10a 21-DEC-2012
[    1.145294] u***core: registered new interface driver xpad
[    1.145413] u***core: registered new interface driver u***_acecad
[    1.145513] u***core: registered new interface driver aip
举报
更多回帖
