瑞芯微Rockchip开发者社区
直播中
张桂兰
7年用户 1321经验值
私信 关注
[问答]
求大佬分享Android5.1 RK3288 GT9271 TP触摸代码
回帖(1)
傅双育
2022-3-4 14:25:21
1、平台信息
CPU:S905D3
TP:GT9271
2、硬件连接
GT9271 S905D3
I2C I2C4(I2C4_SDA_TP/I2C4_SCL_TP)
TP_INT GPIO7_A6_u
TP_RST GPIO7_A5_u
【初始流程】
1、设备数配置
kernel/arch/arm64/boot/dts/amlogic/xxx.dts
&i2c4 {
        status = "okay";
        ts@5d {
                compatible = "goodix,gt9xx";
                status = "okay";
                reg = <0x5d>;
                goodix,irq-gpio = <&gpio7 GPIO_A6 IRQ_TYPE_LEVEL_LOW>;
                goodix,rst-gpio = <&gpio7 GPIO_A5 GPIO_ACTIVE_LOW>;
                goodix,cfg-group0 = [
                    42 D0 02 00 05 05 75 01 01 0F 24
                    0F 64 3C 03 05 00 00 00 02 00 00
                    00 16 19 1C 14 8C 0E 0E 24 00 31
                    0D 00 00 00 83 33 1D 00 41 00 00
                    00 00 00 08 0A 00 2B 1C 3C 94 D5
                    03 08 00 00 04 93 1E 00 82 23 00
                    74 29 00 69 2F 00 5F 37 00 5F 20
                    40 60 00 F0 40 30 55 50 27 00 00
                    00 00 00 00 00 00 00 00 00 00 00
                    00 00 00 00 00 00 00 14 19 00 00
                    50 50 02 04 06 08 0A 0C 0E 10 12
                    14 16 18 1A 1C 00 00 00 00 00 00
                    00 00 00 00 00 00 00 00 00 00 1D
                    1E 1F 20 21 22 24 26 28 29 2A 1C
                    18 16 14 13 12 10 0F 0C 0A 08 06
                    04 02 00 00 00 00 00 00 00 00 00
                    00 00 00 00 00 00 00 00 9C 01
2、驱动流程梳理
// 周期处理任务
static void gtp_esd_check_func(struct work_struct *work)
    // 检查ic是否工作异常,异常时复位ic
        #ifdef GTP_CONFIG_OF // 重新上下电
                gtp_power_switch(ts->client, 0);
                msleep(20);
                gtp_power_switch(ts->client, 1);
                msleep(20);
        #endif
    gtp_reset_guitar(ts->client, 50); // 复位ic
    msleep(50);
    gtp_send_cfg(ts->client);  // 重新下发配置数据
// 中断下半部
static void goodix_ts_work_func(struct work_struct *work)
    // 读取触控信息
    // To-do
        // 触控唤醒功能,点亮屏幕
    input_report_key(ts->input_dev, KEY_POWER, 1);
    input_sync(ts->input_dev);
    input_report_key(ts->input_dev, KEY_POWER, 0);
        // 上报触控位置
        input_report_key(ts->input_dev, touch_key_array, key_value & (0x01<
    // 当提交输入设备产生的输入事件之后,需调用input_sync通知输入子系统处理设备产生的完整事件
    // 重新使能中断
    gtp_irq_enable(ts);
// 中断上半部
static irqreturn_t goodix_ts_irq_handler(int irq, void *dev_id)
    // 将任务提交到工作队列,提交后在下半部执行函数goodix_ts_work_func
    queue_work(goodix_wq, &ts->work);
static int goodix_ts_probe(struct i2c_client *client, const struct i2c_device_id *id)
    // 解析goodix,irq-gpio/goodix,rst-gpio属性
    gtp_parse_dt(&client->dev);
    // 初始化一个任务,任务处理入口:goodix_ts_work_func
    INIT_WORK(&ts->work, goodix_ts_work_func);
    ret = gtp_request_io_port(ts);
    ret = gtp_init_panel(ts);
    //创建/proc/gt9xx_config读写文件节点
    proc_create(GT91XX_CONFIG_PROC_FILE, 0666, NULL, &config_proc_ops);
    //申请中断处理回调
    ret = gtp_request_irq(ts); -> request_irq(xxx, goodix_ts_irq_handler, ...);
    /* 注册suspend/resume回调 goodix_ts_early_suspend/goodix_ts_late_resume */
    gtp_register_powermanger(ts);
static struct i2c_driver goodix_ts_driver = {
    .probe      = goodix_ts_probe,
static int __init goodix_ts_init(void)
    //创建一个专用的内核线程来执行提交到工作队列中的函数
    goodix_wq = create_singlethread_workqueue("goodix_wq");
#if GTP_ESD_PROTECT
    // 查询 IC 的工作状态,如果发现工作异常,则复位IC
    INIT_DELAYED_WORK(>p_esd_check_work, gtp_esd_check_func);
    gtp_esd_check_workqueue = create_workqueue("gtp_esd_check");
#endif
    ret = i2c_add_driver(&goodix_ts_driver);
3、启动加载日志
<4>[    3.142669] <<-GTP-INFO->> GTP driver installing...
<4>[    3.142774] <<-GTP-INFO->> GTP Driver Version: V2.2<2014/01/14>
<4>[    3.142782] <<-GTP-INFO->> GTP Driver Built@18:18:52, Apr 20 2021
<4>[    3.142787] <<-GTP-INFO->> GTP I2C Address: 0x14
<7>[    3.142798] of_get_named_gpio_flags exited with status 230
<7>[    3.142804] of_get_named_gpio_flags exited with status 229
<4>[    3.142808] irq_pin = 230
<4>[    3.142837] <<-GTP-INFO->> Guitar reset
<6>[    3.243381] [WLAN_RFKILL]: wifi turn on power. 156
<4>[    3.263061] gtp_i2c_test start
<4>[    3.263611] <<-GTP-INFO->> IC Version: 9271_1070
<4>[    3.263619] jon_debug:lcd_panel_id:50
<4>[    3.263624] jon_debug:reset
<4>[    3.263628] <<-GTP-INFO->> Guitar reset
<6>[    3.366378] EHCI: rk_ehci_hcd_enable, enable host controller
<4>[    3.450020] wifi_platform_bus_enumerate device present 1
<4>[    3.450028] ======== Card detection to detect SDIO card! ========
<6>[    3.450034] mmc1:mmc host rescan start!
<4>[    3.450041] ============= hong dw_mci_set_sdio_status gpio4_c1 val_io=1
<4>[    3.469695] jon_debug:gtp_init_panel,1467
<4>[    3.469702] jon_debug:gtp_init_panel,1506
<4>[    3.470094] <<-GTP-INFO->> CTP_CONFIG_GROUP1 used, config length: 186
<4>[    3.470481] <<-GTP-INFO->> Driver send config.
<4>[    3.477724] <<-GTP-INFO->> X_MAX: 800, Y_MAX: 1280, TRIGGER: 0x01
<4>[    3.489385] <<-GTP-INFO->> create proc entry gt9xx_config success
<6>[    3.489471] input: Goodix-TS as /devices/virtual/input/input1
<4>[    3.489596] <<-GTP-ERROR->> Request IRQ failed!ERRNO:0.
<4>[    3.489609] <<-GTP-INFO->> GTP works in polling mode.
【调试记录】
1、查看中断统计
root@rk3288_box:/ # cat /proc/interrupts | grep i2c-4
96:    2029804          0          0          0       GIC  i2c-4
root@rk3288_box:/ # cat /proc/interrupts | grep gt
198:          1          0          0          0      GPIO  gt9xx
2、查看触摸芯片配置
root@rk3288_box:/ # cat /proc/gt9xx_config
==== GT9XX config init value====
0x42 0x20 0x03 0x00 0x05 0x05 0x35 0x20
0x22 0x08 0x2D 0x0F 0x73 0x5F 0x03 0x05
举报
更多回帖
