瑞芯微Rockchip开发者社区
直播中
王军
8年用户 1858经验值
私信 关注
[问答]
如何对4G模块的驱动进行配置呢
4G模块调试基本上分为哪几部分呢?
如何对4G模块的驱动进行配置呢?
回帖(1)
高欢
2022-3-3 15:07:34
SoC:RK3288
4G chip:EC20
Platform:Android 5.1
厂家已经提供了相应的文档,这里也只是记录下流程.4G模块调试基本上分为三部分:
驱动、RIL、android配置文件
一 驱动配置
1.1 选择 USB Driver Configure
Device Drivers  --->
  • USB support  --->
                    <*> USB Serial Converter support
  • USB Generic Serail Driver
  • USB Driver for GSM and CMDA modems
    1.2 add EC20 's Vendor ID and Product ID
    add EC20 's Vendor ID and Product ID in option_ids[] of drivers/u***/serial/option.c
    USB_DEVICE(0x05c6, 0x9215);
    1.3 USB Driver Configure
    Device Drivers  --->
  • USB support  --->
                    <*> USB Modem (CDC ACM) suppor
    1.4 PPP Configure
    Device Drivers  --->
  • Network device support  --->
                    <*> PPP (point-to-point protocol) support
                    <*> PPP support for async serial ports
                    <*> PPP support for sync tty ports
                    <*> PPP Deflate compression
    二 RIL库
    RIL库由厂家提供,将该拨号库拷贝到/system/lib/目录下,若厂家提供了ril源码,可将其拷贝到hardware/ril/reference-ril下。
    注:需要使用RIL库来配置build.prop
    三 配置
    修改init.rc的内容,添加以下:
    service ril-daemon /system/bin/rild -l /system/lib/libreference-ril.so
        class main
        socket rild stream 660 root radio
        socket rild-debug stream 666 radio system
        user root
        group radio cache inet misc audio sdcard_rw log
    修改hardware/ril/rild/rild.c中:
    OpenLib:
        #endif
          //switchUser();这里的switchUser()是必须要注释掉的,否则无法正常拨号上网
    然后重新编译android。(init.rc的修改需要在device/rockchip/rk3288/init.rc中修改,否则重新编译可能又被rockchip的配置所覆盖)。
    按照文档做完上述工作后,发现4G依然不能用,通过adb shell中输入以下命令:
    logcat -b radio
    //出现以下错误提示
    D/RIL_RK_DATA_V3.5(  169): Found a device, get id
    D/use-Rlog/RLOG-RIL_RK_DATA_V3.5(  169): device path: /sys/devices/ff540000.u***/u***3/3-1/3-1.4/3-1.4:1.0/ttyUSB0/tty/ttyUSB0
    D/RIL_RK_DATA_V3.5(  169): USB device path: /sys/devices/ff540000.u***/u***3/3-1/3-1.4
    D/RIL_RK_DATA_V3.5(  169): TTY Device Vendor path: /sys/devices/ff540000.u***/u***3/3-1/3-1.4/idVendor
    D/RIL_RK_DATA_V3.5(  169): TTY Device Product path: /sys/devices/ff540000.u***/u***3/3-1/3-1.4/idProduct
    D/RIL_RK_DATA_V3.5(  169): tty Device id is: 05C6/9215
    D/RIL_RK_DATA_V3.5(  169): Searching modem table...
    D/use-Rlog/RLOG-RIL_RK_DATA_V3.5(  169): [matchModem]: match model count=0
    E/use-Rlog/RLOG-RIL_RK_DATA_V3.5(  169): E: Not support modem!!!!
    这是因为RK3288的Android 5.1 SDK提供了ril相关配置,各个厂家的不同,还需要更改其适配自己的4G模块。
    4G模块生成了/dev/ttyUSB0~4共5个串口,AT指令端口为/dev/ttyUSB0;而RK3288默认的配置为:
    rild.libpath=/system/lib/libril-rk29-dataonly.so
    rild.libargs=-d /dev/ttyACM0
    因此将其修改为:
    rild.libpath=/system/lib/libreference-ril.so
    rild.libargs=-d /dev/ttyUSB0
    源码中可在/device/rockchip/rk3288/rk3288_box/system.prop中修改,以后每次编译就能正常使用了。
    最后需要在init.rc中添加:
    chmod 777 /dev/ttyUSB0
    chmod 777 /dev/ttyUSB1
    chmod 777 /dev/ttyUSB2
    chmod 777 /dev/ttyUSB3
    chmod 777 /dev/ttyUSB4
    重新编译源码后烧录固件,亲测中国联通4G LTE能正常上网。
举报
更多回帖
