Platform: RK3288
OS: Android 6.0
Kernel: 3.10.92
Kernel层:
打开UVC的宏
CONFIG_USB_VIDEO_CLASS=y
这个宏一般默认是配好的.
编译下载插上u*** camera开机之后应该会有类似如下log:
[ 3.612836] u*** 3-1: New USB device found, idVendor=058f, idProduct=3822
[ 3.612857] u*** 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 3.612867] u*** 3-1: Product: USB 2.0 HD Camera
[ 3.614985] uvcvideo: Found UVC 1.00 device USB 2.0 HD Camera (058f:3822)
[ 3.622648] input: USB 2.0 HD Camera as /devices/ff540000.u***/u***3/3-1/3-1:1.0/input/input3
查看设备是否注册成功:
shell@rk3288:/ $ ls /dev/video*
/dev/video0
/dev/video1
/dev/video_state
video0是CIF camera, video1就是UVC Camera了.
HAL层:
系统默认只支持1颗Camera, 所以第二颗即使驱动注册成功,上层也无法识别到,
因此修改如下:
int camera_device_open(const hw_module_t* module, const char* name,
hw_device_t** device)
if (name != NULL) {
cameraid = atoi(name);
if(cameraid > gCamerasNumber) {
LOGE("camera service provided cameraid out of bounds, "
"cameraid = %d, num supported = %d",
cameraid, gCamerasNumber);
rv = -EINVAL;
goto fail;
/*Kris, Support two cameras. {*/
#if 0
if(gCamerasOpen >= CAMERAS_SUPPORTED_SIMUL_MAX) {
LOGE("maximum number(%d) of cameras already open",gCamerasOpen);
rv = -EUSERS;
goto fail;
#endif
/*Kris, Support two cameras. }*/
}这样就可以了!
注意:
RK3288目前不支持高清类型的也就是说mjpeg数据格式的UVC Camera,需要用YUYV格式的.
最快的区分方法是查看HAL层log, code会读取数据格式并打印出来.
01-01 12:03:15.420 216 578 D CameraHal: CameraHal(121): it is a uvc camera!
01-01 12:03:15.420 216 578 D CameraHal: Calling process is: com.android.camera2
01-01 12:03:15.465 216 578 D CameraHal: cameraCreate(374): Camera driver: uvcvideo Driver version: 3.10.0 CameraHal version: 1.55.2
01-01 12:03:15.465 216 578 D CameraHal: cameraCreate(381): mCamDriverSupportFmt: fmt = 1448695129,index = 0
01-01 12:03:15.465 216 578 D CameraHal: cameraCreate(419): cameraCreate(419): mCamDriverPreviewFmt(YUYV) is cameraHal and camera driver is also supported!! 01-01 12:03:15.465 216 578 D CameraHal: cameraCreate(421): mCamDriverPreviewFmt = 1448695129 01-01 12:03:15.465 216 578 D CameraHal: cameraCreate(427): cameraCreate(427): Current driver is uvcvideo, v4l2 memory is V4L2_MEMORY_MMAP
Platform: RK3288
OS: Android 6.0
Kernel: 3.10.92
Kernel层:
打开UVC的宏
这个宏一般默认是配好的.
查看设备是否注册成功:
/dev/video0
/dev/video1
/dev/video_state
HAL层:
因此修改如下:
if (name != NULL) {
rv = -EINVAL;
goto fail;
#if 0
rv = -EUSERS;
goto fail;
#endif
}这样就可以了!
注意:
举报
