1、犯了一个错误,导致SDK忘记执行源代码更新指令,5月8号的最初版本有很多BUG,执行update.repo/repo/repo sync,更新之后编译烧录,之前的
2、接上一篇文章,永不修改,代码alpsframeworksbaseservicescorejavacomandroidserverpowerPowerManagerService.java private
private int getScreenOffTimeoutLocked(int sleepTimeout) {
int timeout = mScreenOffTimeoutSetting;
> //peng@ZY
> if (timeout < 0) {
> return mMaximumScreenOffTimeoutFromDeviceAdmin;
if (isMaximumScreenOffTimeoutFromDeviceAdminEnforcedLocked()) {
timeout = Math.min(timeout, mMaximumScreenOffTimeoutFromDeviceAdmin);
if (mUserActivityTimeoutOverrideFromWindowManager >= 0) {
timeout = (int)Math.min(timeout, mUserActivityTimeoutOverrideFromWindowManager);
if (sleepTimeout >= 0) {
timeout = Math.min(timeout, sleepTimeout);
return Math.max(timeout, mMinimumScreenOffTimeoutConfig);
在修改alpsframeworkspackagesSettingsProviderresvaluesdefaults.xml
-1
3、调试以太网 RLT8211E-VB-G-CG
&gmac {
phy-supply = <&vcc_phy>;
phy-mode = "rgmii"; //100/1000M网卡
clock_in_out = "input";
snps,reset-gpio = <&gpio4 8 0>; //根据原理图修改
snps,reset-active-low;
snps,reset-delays-us = <0 10000 50000>;
assigned-clocks = <&cru SCLK_MAC>;
assigned-clock-parents = <&ext_gmac>;
pinctrl-names = "default";
pinctrl-0 = <&rgmii_pins>;
tx_delay = <0x30>;
rx_delay = <0x10>;
max-speed = <100>;
status = "okay";
编译烧录,终端查看sys/class/net/有eth0设备,说明芯片工作正常。
执行ping 自己,没问题,ping局域网的电脑不通,电脑ping板子,ping的通,检查硬件
板子是无法ping出去,并非外面ping不通板子,检查MAC_TXCLK脚。
把C2的电容去掉就正常了,同理,如果是外网ping不通板子,那就检查RX脚。(硬件贴错导致)
4、调试RT5640音频模块
驱动配置好5640模块
sound: sound {
status = "disabled";
compatible = "simple-audio-card";
simple-audio-card,format = "i2s";
simple-audio-card,name = "rockchip,rt5640-codec";
simple-audio-card,mclk-fs = <512>;
simple-audio-card,widgets =
"Microphone", "Mic Jack",
"Headphone", "Headphone Jack",
"Speaker", "Speaker";
simple-audio-card,routing =
"Mic Jack", "MICBIAS1",
"IN2P", "Mic Jack",
"IN2N", "Mic Jack",
"Headphone Jack", "HPOL",
"Headphone Jack", "HPOR",
"Speaker", "SPOLP",
"Speaker", "SPOLN",
"Speaker", "SPORP",
"Speaker", "SPORN";
simple-audio-card,cpu {
sound-dai = <&i2s>;
simple-audio-card,codec {
sound-dai = <&rt5640>;
spdif_sound: spdif-sound {
status = "okay";
simple-audio-card,name = "rockchip,spdif";
sound-dai = <&spdif>;
sound-dai = <&spdif_out>;
spdif_out: spdif-out {
status = "okay";
compatible = "linux,spdif-dit";
#sound-dai-cells = <0>;
&i2c2 { //硬件连接的是I2C2
status = "okay";
clock-frequency = <400000>;
rt5640: rt5640@1c {
compatible = "realtek,rt5640";
reg = <0x1c>;
clocks = <&cru SCLK_I2S0_OUT>;
clock-names = "mclk";
//interrupt-parent = <&gpio6>;
//interrupts = <7 IRQ_TYPE_EDGE_FALLING>;
根据环境切换通道,要修改hardwarerockchipaudiotinyalsa_halcodec_configrt5640_config.h
5、tc358749x HDMI2MIPI转换芯片(HDMI IN功能)
&i2c3{
status = "okay";
tc358749x: tc358749x@0f {
compatible = "toshiba,tc358749x";
reg = <0x0f>;
power-gpios = <&gpio8 9 GPIO_ACTIVE_HIGH>; //根据硬件配置
stanby-gpios = <&gpio8 3 GPIO_ACTIVE_HIGH>;
reset-gpios = <&gpio8 2 GPIO_ACTIVE_HIGH>;
int-gpios = <&gpio8 0 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&hdmiin_gpios>;
status = "okay";
&pinctrl {
hdmiin {
hdmiin_gpios: hdmiin_gpios {
rockchip,pins =
<8 0 RK_FUNC_GPIO &pcfg_pull_none>,
<8 2 RK_FUNC_GPIO &pcfg_pull_none>,
<8 9 RK_FUNC_GPIO &pcfg_pull_none>,
<8 3 RK_FUNC_GPIO &pcfg_pull_none>;
配置hardwarerockchipcameraConfigcam_board_rk3288.xml
//I2C通道
phyIndex 根据硬件连接方式填写,如果是连接MIPI TX/RX 选择1,如果是MIPI TX选择0。
编译烧录,发现很多这种CamerIcIspIrq: pic err first,g_ispFrameNum == 1
测量发现MIPI信号时有时无,问了redmine说是mipi信号可能有问题。
> //peng@ZY
> if (timeout < 0) {
-1
&gmac {
tx_delay = <0x30>;
rx_delay = <0x10>;
max-speed = <100>;
status = "okay";
4、调试RT5640音频模块
驱动配置好5640模块
sound: sound {
"IN2P", "Mic Jack",
"IN2N", "Mic Jack",
"Speaker", "SPOLP",
"Speaker", "SPOLN",
"Speaker", "SPORP",
"Speaker", "SPORN";
sound-dai = <&i2s>;
status = "okay";
status = "okay";
status = "okay";
rt5640: rt5640@1c {
reg = <0x1c>;
&i2c3{
status = "okay";
reg = <0x0f>;
status = "okay";
&pinctrl {
hdmiin {
rockchip,pins =
//I2C通道
举报
