瑞芯微Rockchip开发者社区
直播中
他在笑
9年用户 723经验值
擅长:可编程逻辑 电源/新能源 制造/封装
私信 关注
[问答]
调试imx307效果的时候预览图像始终有些轻微抖动怎么解决?
回帖(1)
李淳鑫
2022-3-3 14:16:47
                    1. 在调试imx307 效果的时候,预览图像的时候始终有些轻微抖动,后面发现是camera是时钟不对。
imx307要求是时钟是37.125M,设置的时钟也是37.125M,而平台分出来是时钟确只有35.5M,没有37.125M,需要打补丁。
PLL_NPLL分频cif clk out 37.125M补丁如下:
diff --git a/kernel/arch/arm/boot/dts/rk3288.dtsi b/kernel/arch/arm/boot/dts/rk3288.dtsi
index 38cda53..ffaf5c3 100755
--- a/kernel/arch/arm/boot/dts/rk3288.dtsi
+++ b/kernel/arch/arm/boot/dts/rk3288.dtsi
@@ -1195,6 +1195,10 @@
                compatible = "rockchip,rk3288-isp", "rockchip,isp";
                reg = <0x0 0xff910000 0x0 0x4000>;
                interrupts = ;
+               //start for camera IMX307 mclk "sclk_vip_out" set 37.125M by lpz add
+               assigned-clocks = <&cru PLL_NPLL>, <&cru SCLK_VIP_SRC>, <&cru SCLK_VIP_OUT>;
+               assigned-clock-rates = <594000000>, <594000000>, <37125000>;
+               //end for camera IMX307 mclk "sclk_vip_out" set 37.125M by lpz add
                power-domains = <&power RK3288_PD_VIO>;
                clocks =
                        <&cru ACLK_ISP>, <&cru HCLK_ISP>, <&cru SCLK_ISP>,
diff --git a/kernel/drivers/clk/rockchip/clk-rk3288.c b/kernel/drivers/clk/rockchip/clk-rk3288.c
index b0168c7..4763030 100755
--- a/kernel/drivers/clk/rockchip/clk-rk3288.c
+++ b/kernel/drivers/clk/rockchip/clk-rk3288.c
@@ -469,7 +469,10 @@ static struct rockchip_clk_branch rk3288_clk_branches[] __initdata = {
                        RK3288_CLKSEL_CON(42), 14, 2, MFLAGS, 8, 5, DFLAGS,
                        RK3288_CLKGATE_CON(13), 15, GFLAGS),
-       COMPOSITE_NODIV(0, "vip_src", mux_pll_src_cpll_gpll_p, 0,
+       //COMPOSITE_NODIV(0, "vip_src", mux_pll_src_cpll_gpll_p, 0,
+       COMPOSITE_NODIV(SCLK_VIP_SRC, "vip_src", mux_pll_src_cpll_gpll_p, 0,
                        RK3288_CLKSEL_CON(26), 8, 1, MFLAGS,
                        RK3288_CLKGATE_CON(3), 7, GFLAGS),
        COMPOSITE_NOGATE(SCLK_VIP_OUT, "sclk_vip_out", mux_vip_out_p, 0,
diff --git a/kernel/drivers/media/video/rk_camsys/camsys_cif.c b/kernel/drivers/media/video/rk_camsys/camsys_cif.c
old mode 100644
new mode 100755
index fce0784..a597ea6
--- a/kernel/drivers/media/video/rk_camsys/camsys_cif.c
+++ b/kernel/drivers/media/video/rk_camsys/camsys_cif.c
@@ -148,7 +148,9 @@ static int camsys_cif_clkout_cb(void *ptr, unsigned int on, unsigned int clkin)
        spin_lock(&clk->lock);
        if (on && (clk->out_on != on)) {
                clk_prepare_enable(clk->cif_clk_out);
-               clk_set_rate(clk->cif_clk_out, clkin);
+               //clk_set_rate(clk->cif_clk_out, clkin);
                clk->out_on = on;
                camsys_trace(1,  "%s clock out(rate: %dHz) turn on",
diff --git a/kernel/drivers/media/video/rk_camsys/camsys_marvin.c b/kernel/drivers/media/video/rk_camsys/camsys_marvin.c
old mode 100644
new mode 100755
index bef1dc1..cfe2974
--- a/kernel/drivers/media/video/rk_camsys/camsys_marvin.c
+++ b/kernel/drivers/media/video/rk_camsys/camsys_marvin.c
@@ -683,7 +683,9 @@ static int camsys_mrv_clkout_cb(void *ptr, unsigned int on, unsigned int inclk)
        mutex_lock(&clk->lock);
-               clk_set_rate(clk->cif_clk_out, inclk);
+               //clk_set_rate(clk->cif_clk_out, inclk);
                clk->out_on = on;
diff --git a/kernel/include/dt-bindings/clock/rk3288-cru.h b/kernel/include/dt-bindings/clock/rk3288-cru.h
old mode 100644
new mode 100755
index 6cb872f..c4d55f0
--- a/kernel/include/dt-bindings/clock/rk3288-cru.h
+++ b/kernel/include/dt-bindings/clock/rk3288-cru.h
@@ -91,6 +91,7 @@
#define SCLK_VIP_OUT           127
#define SCLK_DDRCLK            128
#define SCLK_I2S_SRC           129
+#define SCLK_VIP_SRC   135
#define SCLK_MAC_PLL           150
#define SCLK_MAC               151
(END)
打上补丁后imx307的mclk 37.125M正常了,预览界面也不会有抖动了,显示效果也得到了改善;
可以通过adb 查看clk是否正确:
cat ./sys/kernel/debug/clk/clk_summary |grep vip
          vip_src                         1            1   594000000          0 0
             sclk_vip_out                 1            3    37125000          0 0
2. 但又出现了新的问题,打上补丁后,导致100M以太网无法使用了。我们用100M以太网是由rk3288提供分频50M,
以太网50M是由PLL_NPLL分出来了,PLL_NPLL默认是500M,是可以正常分出50M的。
但是打上cif clk 37.125M补丁后,NPLL改成594M后,无法分出50M了,导致100M以太网无法使用了。
问题找到了,但两个问题是冲突的,二者只能取其一,母时钟还是不能乱动的,一动其他孩子可能就要断奶了。
只能找其他方法了,把整个时钟树列出来发现GPLL默认时钟就是594M,于是我们可以选着GPLL作为sclk_vip_out的母时钟,
既能分出37.125M,又不用改母时钟频率,这样camera IMX307和以太网都可以正常使用了,
补丁如下:
index ffaf5c3..a025a91 100755
@@ -1196,7 +1196,7 @@
                interrupts = ;
-               assigned-clocks = <&cru PLL_NPLL>, <&cru SCLK_VIP_SRC>, <&cru SCLK_VIP_OUT>;
+               assigned-clocks = <&cru PLL_GPLL>, <&cru SCLK_VIP_SRC>, <&cru SCLK_VIP_OUT>;
举报
更多回帖
