单片机学习小组
直播中
张健
8年用户 1439经验值
私信 关注
诺基亚5110屏驱动过程是怎样的?
诺基亚5110屏驱动过程是怎样的?
回帖(1)
潘务单
2022-2-28 11:55:13
一、前期准备
单片机:STM32F103ZET6
开发环境:MDK5.14
库函数:标准库V3.5
二、实验效果
三、驱动原理
1002521871,验证:呵呵。
四、驱动代码
5110.h
#ifndef __NOKIA_5110_H__
#define        __NOKIA_5110_H__
#include "stm32f10x.h"
#include "gpio.h"
#include "delay.h"
#include "nokiafont.h"
#define         Nokia_CLK                 PEout(0)
#define                Nokia_DIN                 PEout(1)
#define                Nokia_DC                 PEout(2)
#define                Nokia_CE                 PEout(3)
#define                Nokia_RST                PEout(4)
extern void Nokia5110Configuration(void);
extern void Nokia_Clear(void);
extern void Nokia_Write_Chinese_String(uint8_t X, uint8_t Y, uint8_t ch_with, uint8_t num, uint8_t line, uint8_t row);
extern void Nokia_Write_English_String(uint8_t X, uint8_t Y, char *s);
#endif
5110.c
#include "nokia5110.h"
void Nokia_Write_Byte(uint8_t dat, uint8_t cmd)
        uint8_t i;
        Nokia_CE = 0;                        // 使能LCD
        if (cmd == 0)
                Nokia_DC = 0;                // 传送命令
        else
                Nokia_DC = 1;                // 传送数据
        for(i = 0; i < 8; i ++)
                if(dat & 0x80)
                        Nokia_DIN = 1;
                else
                        Nokia_DIN = 0;
                Nokia_CLK = 0;
                dat = dat << 1;
                Nokia_CLK = 1;
        Nokia_CE = 1;
        uint16_t i;
        Nokia_Write_Byte(0x0c, 0);
        Nokia_Write_Byte(0x80, 0);
        for (i = 0; i < 504; i ++)
                Nokia_Write_Byte(0, 1);
void Nokia_Set_Position(uint8_t X, uint8_t Y)
        Nokia_Write_Byte(0x40 | Y, 0);                // column
        Nokia_Write_Byte(0x80 | X, 0);      // row
void Nokia_Write_Char(uint8_t c)
        uint8_t line;
        c -= 32;
        for (line = 0; line < 6; line ++)
                Nokia_Write_Byte(font6x8[c][line], 1);
        Nokia_Set_Position(X, Y);
        while (*s)
                Nokia_Write_Char(*s);
                s ++;
Nokia_Write_Chinese_String: 在LCD上显示汉字
输入参数:X、Y    :显示汉字的起始X、Y坐标;
          ch_with :汉字点阵的宽度
          num     :显示汉字的个数;
          line    :汉字点阵数组中的起始行数
          row     :汉字显示的行间距
        uint8_t i, n;
        Nokia_Set_Position(X, Y);                             //设置初始位置
        for (i = 0; i < num;)
                for (n = 0; n < ch_with * 2; n ++)              //写一个汉字
                        if (n == ch_with)                      //写汉字的下半部分
                                if (i == 0)
                                        Nokia_Set_Position(X, Y + 1);
                                else
                                        Nokia_Set_Position((X + (ch_with + row) * i), Y + 1);
                        Nokia_Write_Byte(write_chinese[line + i][n], 1);
                i ++;
                Nokia_Set_Position((X + (ch_with + row) * i), Y);
Nokia_Draw_Bmp_Pixel      : 位图绘制函数
输入参数:X、Y    :位图绘制的起始X、Y坐标;
          *map    :位图点阵数据;
          Pix_x   :位图像素(长)
          Pix_y   :位图像素(宽)
void Nokia_Draw_Bmp_Pixel(uint8_t X,uint8_t Y,uint8_t *map,
                  uint8_t Pix_x, uint8_t Pix_y)
        uint16_t i, n;
        uint8_t row;
        if (Pix_y % 8 == 0)
                row = Pix_y / 8;      //计算位图所占行数
        else
                row = Pix_y / 8 + 1;
        for (n = 0; n < row; n ++)
                for(i = 0; i < Pix_x; i ++)
                        Nokia_Write_Byte(map[i + n * Pix_x], 1);
                Y ++;                         //换行
         GPIO_InitTypeDef    GPIO;
    //Enable APB2 Bus
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);
    //Register IO
    GPIO.GPIO_Pin   = 0x1F;
    GPIO.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO.GPIO_Mode  = GPIO_Mode_Out_PP;
    GPIO_Init(GPIOE, &GPIO);
        Nokia_RST = 0;
        DelayUs(1);
        Nokia_RST = 1;
        Nokia_CE = 0;                                        // 关闭LCD
        DelayUs(1);
        Nokia_CE = 1;                                        // 使能LCD
        DelayUs(1);
        Nokia_Write_Byte(0x21, 0);        // 使用扩展命令设置LCD模式
        Nokia_Write_Byte(0xc8, 0);        // 设置偏置电压
        Nokia_Write_Byte(0x06, 0);        // 温度校正
        Nokia_Write_Byte(0x13, 0);        // 1:48
        Nokia_Write_Byte(0x20, 0);        // 使用基本命令
        Nokia_Clear();                               // 清屏
        Nokia_Write_Byte(0x0c, 0);        // 设定显示模式,正常显示
举报
更多回帖
