Matlab论坛
直播中
study875
12年用户 1157经验值
私信 关注
isa - Determine whether input is object of given class matlab
  1. Syntax
  2. K = isa(obj, 'class_name')
  3. Description
  4. K = isa(obj, 'class_name') returnslogical 1 (true) if obj isof class (or a subclass of) class_name,and logical 0 (false) otherwise.
  5. The argument obj is a matlab objector an object of the Java programming language. The argument class_name isthe name of a MATLAB (predefined or user-defined) or a Java class.Predefined MATLAB classes include
  6. logical
  7. Logical array of true and false values
  8. char
  9. Characters array
  10. numeric
  11. Integer or floating-point array
  12. integer
  13. Signed or unsigned integer array
  14. int8
  15. 8-bit signed integer array
  16. uint8
  17. 8-bit unsigned integer array
  18. int16
  19. 16-bit signed integer array
  20. uint16
  21. 16-bit unsigned integer array
  22. int32
  23. 32-bit signed integer array
  24. uint32
  25. 32-bit unsigned integer array
  26. int64
  27. 64-bit signed integer array
  28. uint64
  29. 64-bit unsigned integer array
  30. float
  31. Single- or double-precision floating-point array
  32. single
  33. Single-precision floating-point array
  34. double
  35. Double-precision floating-point array
  36. cell
  37. Cell array
  38. struct
  39. Structure array
  40. function_handle
  41. Function handle
  42. 'class_name'
  43. MATLAB class or Java class
  44. To check for a sparse array, use issparse.To check for a complex array, use ~isreal.
  45. Examples
  46. isa(rand(3,4),'double')
  47. ans =
  48.     1
  49. The following example creates an instance of the user-defined MATLAB classnamed polynom. The isa functionidentifies the object as being of the polynom class.
  50. polynom_obj = polynom([1 0 -2 -5]);
  51. isa(polynom_obj, 'polynom')
  52. ans =
  53.      1
引用: 有没有高手给翻译下?
更多回帖
