#include
#include"onewire.h"
***it L8 = P0^7; //工作LED
***it L1 = P0^0;
***it L2 = P0^1;
***it L3 = P0^2; //定义LED
***it S7 = P3^0;
***it S6 = P3^1;
***it S5 = P3^2;
***it S4 = P3^3; //定义独立按键
unsigned char state = 0; //风扇模式标志位
unsigned char stat = 0; //数码管模式显示位
unsigned char count = 0; //定时50ms计数
unsigned char countdown; //倒计时
unsigned char flag = 0; //定时标志位
unsigned char PWM = 0; //PWM
unsigned char num = 0; //脉冲计数
unsigned int T_dat; //温度
unsigned char status = 0; //显示温度标志位
unsigned char code SEG_code[18] =
{0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,
0xbf,0x7f}; //定义共阳数码管段码内容:0~F,—,.
/*==============================系统初始化==============================*/
//端口选择
void Select_HC138(unsigned char n)
switch(n)
case 0:
P2 = (P2 & 0x1f) | 0x00;
break;
case 4:
P2 = (P2 & 0x1f) | 0x80;
break;
case 5:
P2 = (P2 & 0x1f) | 0xa0;
break;
case 6:
P2 = (P2 & 0x1f) | 0xc0;
break;
case 7:
P2 = (P2 & 0x1f) | 0xe0;
break;
//初始化配置
void Init_system()
Select_HC138(5);
P0 = 0x00; //关闭蜂鸣器和继电器
Select_HC138(4);
P0 = 0xff; //关闭LED
Select_HC138(0);
/*==============================数码管显示==============================*/
//数码管延时函数
void Delay_tube(unsigned char time)
while(--time);
//数码管显示
void Show_tube(unsigned char position,unsigned char value)
Select_HC138(7);
P0 = 0xff; //选择端口前,先熄灭数码管
Select_HC138(6);
P0 = 0x01 << position;
Select_HC138(7);
P0 = value;
void Show_all()
Select_HC138(7);
Select_HC138(6);
P0 = 0xff; //选通所有数码管
//动态显示(模式)
void Display_mode()
Show_tube(0,SEG_code[16]); //显示"-"
Delay_tube(100);
Show_tube(1,SEG_code[stat]); //显示风扇模式
Delay_tube(100);
Show_tube(2,SEG_code[16]); //显示"-"
Delay_tube(100);
//第4位熄灭
Show_tube(4,SEG_code[0]); //显示0
Delay_tube(100);
Show_tube(5,SEG_code[countdown/100]); //显示倒计时的百位
Delay_tube(100);
Show_tube(6,SEG_code[(countdown/10)%10]); //显示倒计时的十位
Delay_tube(100);
Show_tube(7,SEG_code[countdown%10]); //显示倒计时的个位
Delay_tube(100);
Show_all();
//动态显示(温度)
void Display_temp()
Delay_tube(100);
Show_tube(1,SEG_code[4]); //显示风扇模式
Delay_tube(100);
Delay_tube(100);
//第4、5位熄灭
Show_tube(5,SEG_code[T_dat/10]); //显示温度的十位
Delay_tube(100);
Show_tube(6,SEG_code[T_dat%10]); //显示温度的个位
Delay_tube(100);
Show_tube(7,SEG_code[12]); //显示温度单位C
Delay_tube(100);
Show_all();
/*===============================温度读取===============================*/
//读取温度延时函数
void Delay_temp(unsigned int t)
while(t--)
Display_temp();
//读取温度
void Read_temp()
unsigned char LSB,MSB; //存放温度
Init_DS18B20(); //复位
Write_DS18B20(0xcc); //跳过ROM操作指令
Write_DS18B20(0x44); //温度转换
Delay_temp(1000); //等待温度转换,延时700ms
Write_DS18B20(0xbe); //读取RAM
LSB = Read_DS18B20(); //读取温度数据的低8位(低位先读)
MSB = Read_DS18B20(); //读取温度数据的高8位
Init_DS18B20(); //复位,停止读取数据
T_dat = 0x0000;
T_dat = MSB;
T_dat <<= 8;
T_dat |= LSB; //整合温度
if((T_dat & 0xf800) == 0x0000) //根据T_dat高5位判断温度正负,若温度为正
T_dat >>= 4; //右移4位,取温度的整数部分
/*===============================PWM输出================================*/
//定时器0中断初始化
void Init_timer0()
TMOD = 0x11; //同时打开定时器0和定时器1
TH0 = (65535 - 100) / 256;
TL0 = (65535 - 100) % 256;
EA = 1; //打开总中断
ET0 = 1; //打开定时器0的中断
TR0 = 0; //关闭定时器0
//定时器0中断服务函数
void Service_timer0() interrupt 1
num++;
if(num == (100-PWM)) //占空比后点亮L8
Select_HC138(4);
L8 = 0;
Select_HC138(0);
if(num == 100) //一个脉冲周期结束
Select_HC138(4);
L8 = 1;
Select_HC138(0);
num = 0;
/*===============================分钟定时===============================*/
//定时器1中断初始化
void Init_timer1()
TH1 = (65535 - 50000) / 256;
TL1 = (65535 - 50000) % 256;
EA = 1; //打开总中断
ET1 = 1; //打开定时器1的中断
TR1 = 0; //关闭定时器1
//定时器1中断服务函数
void Service_timer1() interrupt 3
count++;
if(count == 20) //定时满1s
countdown--;
count = 0;
if(countdown == 0)
TR0 = 0; //PWM停止输出
TR1 = 0; //停止计时
Select_HC138(4);
P0 = 0xff; //关闭所有LED
Select_HC138(0);
/*===============================按键处理===============================*/
//去抖动延时函数
void Delay_keys() //10ms延时
unsigned char i = 108,j = 145;
do
while(--j);
}while(--i);
//按键处理
void Press_keys()
if(S4 == 0) //模式选择
Delay_keys(); //去抖动
if(S4 == 0)
switch(state)
case 0: //模式1:睡眠风
stat = 1; //数码管模式显示位
PWM = 20; //PWM为20%
state = 1;
Select_HC138(4);
L1 = 0; //点亮L1
L2 = 1;
L3 = 1;
Select_HC138(0);
break;
case 1: //模式2:自然风
stat = 2; //数码管模式显示位
PWM = 50; //PWM为50%
state = 2;
Select_HC138(4);
L2 = 0; //点亮L2
L1 = 1;
L3 = 1;
Select_HC138(0);
break;
case 2: //模式3:常风
stat = 3; //数码管模式显示位
PWM = 80; //PWM为80%
state = 0;
Select_HC138(4);
L3 = 0; //点亮L3
L1 = 1;
L2 = 1;
Select_HC138(0);
break;
while(S4 == 0)
Display_mode();
else if(S5 == 0) //设置定时时间(开关)
Delay_keys();
if(S5 == 0)
switch(flag)
case 0: //定时1min
countdown = 60;
TR0 = 1; //打开PWM输出
TR1 = 1; //打开定时器1开始定时
flag = 1;
break;
case 1: //定时2min
countdown = 120;
TR0 = 1; //打开PWM输出
flag = 2;
break;
case 2: //停止定时
countdown = 0; //倒计时清0
Select_HC138(4);
Select_HC138(0);
TR0 = 0; //PWM停止输出
TR1 = 0; //关闭定时器1停止计时
flag = 0;
break;
while(S5 == 0)
Display_mode();
else if(S6 == 0) //停止
Delay_keys();
if(S6 == 0)
TR0 = 0; //PWM停止输出
TR1 = 0; //停止计时
flag = 0;
Select_HC138(4); //关闭所有LED
P0 = 0xff;
// L8 = 1;
// L1 = 1;
// L2 = 1;
// L3 = 1;
Select_HC138(0);
while(S6 == 0)
Display_mode();
else if(S7 == 0) //查看温度
Delay_keys();
if(S7 == 0)
if(status == 0)
status = 1; //显示温度
else if(status == 1)
status = 0; //显示风扇模式
while(S7 == 0);
/*================================主函数================================*/
void main()
Init_system();
Init_timer0();
Init_timer1();
while(1)
Press_keys();
switch(status)
case 0:
Display_mode();
break;
case 1:
Read_temp();
Display_temp();
break;
#include
#include"onewire.h"
***it L1 = P0^0;
***it L2 = P0^1;
***it S7 = P3^0;
***it S6 = P3^1;
***it S5 = P3^2;
//端口选择
switch(n)
case 0:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
//初始化配置
void Init_system()
Select_HC138(5);
Select_HC138(4);
P0 = 0xff; //关闭LED
Select_HC138(0);
//数码管延时函数
while(--time);
//数码管显示
Select_HC138(7);
Select_HC138(6);
Select_HC138(7);
P0 = value;
void Show_all()
Select_HC138(7);
Select_HC138(6);
//动态显示(模式)
void Display_mode()
Delay_tube(100);
Delay_tube(100);
Delay_tube(100);
//第4位熄灭
Delay_tube(100);
Delay_tube(100);
Delay_tube(100);
Delay_tube(100);
Show_all();
//动态显示(温度)
void Display_temp()
Delay_tube(100);
Delay_tube(100);
Delay_tube(100);
//第4、5位熄灭
Delay_tube(100);
Delay_tube(100);
Delay_tube(100);
Show_all();
//读取温度延时函数
while(t--)
Display_temp();
//读取温度
void Read_temp()
T_dat = 0x0000;
T_dat = MSB;
T_dat <<= 8;
//定时器0中断初始化
void Init_timer0()
EA = 1; //打开总中断
TR0 = 0; //关闭定时器0
//定时器0中断服务函数
num++;
Select_HC138(4);
L8 = 0;
Select_HC138(0);
Select_HC138(4);
L8 = 1;
Select_HC138(0);
num = 0;
//定时器1中断初始化
void Init_timer1()
EA = 1; //打开总中断
TR1 = 0; //关闭定时器1
//定时器1中断服务函数
count++;
countdown--;
count = 0;
if(countdown == 0)
TR0 = 0; //PWM停止输出
TR1 = 0; //停止计时
Select_HC138(4);
Select_HC138(0);
//去抖动延时函数
do
while(--j);
}while(--i);
//按键处理
void Press_keys()
if(S4 == 0) //模式选择
Delay_keys(); //去抖动
if(S4 == 0)
switch(state)
case 0: //模式1:睡眠风
PWM = 20; //PWM为20%
state = 1;
Select_HC138(4);
L1 = 0; //点亮L1
L2 = 1;
L3 = 1;
Select_HC138(0);
break;
case 1: //模式2:自然风
PWM = 50; //PWM为50%
state = 2;
Select_HC138(4);
L2 = 0; //点亮L2
L1 = 1;
L3 = 1;
Select_HC138(0);
break;
case 2: //模式3:常风
PWM = 80; //PWM为80%
state = 0;
Select_HC138(4);
L3 = 0; //点亮L3
L1 = 1;
L2 = 1;
Select_HC138(0);
break;
while(S4 == 0)
Display_mode();
Delay_keys();
if(S5 == 0)
switch(flag)
case 0: //定时1min
countdown = 60;
TR0 = 1; //打开PWM输出
flag = 1;
break;
case 1: //定时2min
countdown = 120;
TR0 = 1; //打开PWM输出
flag = 2;
break;
case 2: //停止定时
Select_HC138(4);
Select_HC138(0);
TR0 = 0; //PWM停止输出
flag = 0;
break;
while(S5 == 0)
Display_mode();
Delay_keys();
if(S6 == 0)
TR0 = 0; //PWM停止输出
TR1 = 0; //停止计时
flag = 0;
P0 = 0xff;
// L8 = 1;
// L1 = 1;
// L2 = 1;
// L3 = 1;
Select_HC138(0);
while(S6 == 0)
Display_mode();
Delay_keys();
if(S7 == 0)
if(status == 0)
status = 1; //显示温度
while(S7 == 0);
void main()
Init_system();
Init_timer0();
Init_timer1();
while(1)
Press_keys();
switch(status)
case 0:
Display_mode();
break;
case 1:
Read_temp();
Display_temp();
break;
举报
