瑞芯微Rockchip开发者社区
直播中
李俊
8年用户 1399经验值
私信 关注
[问答]
fec2disabled后第一个网口不能用怎么办
我想保留网口1,去掉网口二,但是fec2disabled后第一个网口也不能用了,请问该怎么配置? 295 &fec1 { 296     pinctrl-names = "default";
297     pinctrl-0 = <&pinctrl_enet1>;
298     phy-mode = "rmii";
299     phy-handle = <ðphy0>;
300     status = "okay";
301 };
302
303 &fec2 {
304     pinctrl-names = "default";
305     pinctrl-0 = <&pinctrl_enet2>;
306     phy-mode = "rmii";
307     phy-handle = <ðphy1>;
308     status = "disabled";
309
310     mdio {
311         #address-cells = <1>;
312         #size-cells = <0>;
313
314         ethphy0: ethernet-phy@2 {
315             compatible = "ethernet-phy-ieee802.3-c22";
316             reg = <2>;
317         };
318
319         ethphy1: ethernet-phy@1 {
320             compatible = "ethernet-phy-ieee802.3-c22";
321             reg = <1>;
322         };
323     };
324 };
848         pinctrl_enet1: enet1grp {
849             fsl,pins = <
850                 MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN  0x1b0b0
851                 MX6UL_PAD_ENET1_RX_ER__ENET1_RX_ER  0x1b0b0
852                 MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00 0x1b0b0
853                 MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x1b0b0
854                 MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN  0x1b0b0
855                 MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x1b0b0
856                 MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x1b0b0
857                 MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1  0x4001b031
858             >;
859         };
875         pinctrl_enet2: enet2grp {
876             fsl,pins = <
877                 MX6UL_PAD_GPIO1_IO07__ENET2_MDC     0x1b0b0
878                 MX6UL_PAD_GPIO1_IO06__ENET2_MDIO    0x1b0b0
879                 MX6UL_PAD_ENET2_RX_EN__ENET2_RX_EN  0x1b0b0
880                 MX6UL_PAD_ENET2_RX_ER__ENET2_RX_ER  0x1b0b0
881                 MX6UL_PAD_ENET2_RX_DATA0__ENET2_RDATA00 0x1b0b0
882                 MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01 0x1b0b0
883                 MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN  0x1b0b0
884                 MX6UL_PAD_ENET2_TX_DATA0__ENET2_TDATA00 0x1b0b0
885                 MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01 0x1b0b0
886                 MX6UL_PAD_ENET2_TX_CLK__ENET2_REF_CLK2  0x4001b031
887                 MX6UL_PAD_SNVS_TAMPER0__GPIO5_IO00  0x80000000
888             >;
889         };
问题解决了吗,我也遇到这个问题[/td]
回帖(4)
林森
2022-1-13 10:21:27
两个网口共用mdio,mdio在&fec2里,关掉就不能用了,需要改一下
举报
王莉淳
2022-1-13 10:21:40
我把mdio移到fec1里面去后,还是不能用。
举报
葛睿洁
2022-1-13 10:21:48
下边还有MDIO相关配置,也得修改,光改一处不行啊
举报
刘萍
2022-1-13 10:22:03
您设置的reg = <2>;的值不对
举报
更多回帖
