U盘FAT32;kernel镜像原厂
信息如下:
U-Boot 2018.03 (Feb 25 2019 - 03:16:08 +0000)
SoC: LS1012A Rev2.0 (0x87040120)
Clock Configuration:
CPU0(A53):1000 MHz
Bus: 250 MHz DDR: 1000 MT/s
Reset Configuration Word (RCW):
00000000: 0800000a 00000000 00000000 00000000
00000010: 35080000 c000000c 40000000 00001800
00000020: 00000000 00000000 00000000 00014572
00000030: 00000000 1082a120 00000096 00000000
I2C: ready
DRAM: 446 MiB
ds2460 write secret ok
Using SERDES1 Protocol: 13576 (0x3508)
PPA Firmware: Version LSDK-18.06-Forlinx
SEC Firmware: 'loadables' present in config
loadables: 'trustedOS@1'
WARNING: Calling __hwconfig without a buffer and before environment is ready
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from SPI Flash... SF: Detected w25q128bv with page size 256 Bytes, erase size 4 KiB, total 16 MiB
OK
In: serial
Out: serial
Err: serial
Model: OK1012-C
Board: OK1012-C
SATA link 0 timeout.
AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
flags: 64bit ncq pm clo only pmp fbss pio slum part ccc apst
Found 0 device(s).
SCSI: Net: PFE class pe firmware
PFE tmu pe firmware
pfe_configure_serdes 0
eth0: pfe_eth0, eth1: pfe_eth1
Hit any key to stop autoboot: 0
Stopping PFE...
starting USB...
USB0: Register 200017f NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning u*** for storage devices... 0 Storage Device(s) found
Device 0: device type unknown
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
Found U-Boot script /boot/ls1012ardb_boot.scr
867 bytes read in 15 ms (55.7 KiB/s)
## Executing script at 80000000
** Unable to read file /boot/uEnv.txt **
21590528 bytes read in 1108 ms (18.6 MiB/s)
12481 bytes read in 16 ms (761.7 KiB/s)
## Flattened Device Tree blob at 90000000
Booting using the fdt blob at 0x90000000
Using Device Tree in place at 0000000090000000, end 00000000900060c0
WARNING: fdt_fixup_stdout: could not read serial0 alias: FDT_ERR_NOTFOUND
PCIe0: pcie@3400000 Root Complex: x1 gen1
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.47 (root@ubuntu) (gcc version 7.3.0 (Ubuntu/Linaro 7.3.0-27ubuntu1~18.04)) #9 SMP PREEMPT Thu Aug 27 18:09:53 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: LS1012A RDB Board
[ 0.000000] earlycon: uart8250 at MMIO 0x00000000021c0500 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 16 MiB at 0x000000009ac00000
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x000000009bdfffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x9bde5d00-0x9bde74bf]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x000000009bdfffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009bdfffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009bdfffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] percpu: Embedded 24 pages/cpu @ffff80001bdc6000 s59992 r8192 d30120 u98304
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 112392
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: console=ttyS0,115200 earlycon=uart8250,mmio,0x21c0500 root=PARTUUID=ae7ba4b2-02 rw rootwait
[ 0.000000] PID hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.000000] Memory: 389304K/456704K available (13052K kernel code, 1436K rwdata, 5304K rodata, 1216K init, 985K bss, 51016K reserved, 16384K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB)
[ 0.000000] .text : 0xffff000008080000 - 0xffff000008d40000 ( 13056 KB)
[ 0.000000] .rodata : 0xffff000008d40000 - 0xffff000009280000 ( 5376 KB)
[ 0.000000] .init : 0xffff000009280000 - 0xffff0000093b0000 ( 1216 KB)
[ 0.000000] .data : 0xffff0000093b0000 - 0xffff000009517200 ( 1437 KB)
[ 0.000000] .bss : 0xffff000009517200 - 0xffff00000960d7d0 ( 986 KB)
[ 0.000000] fixed : 0xffff7dfffe7f9000 - 0xffff7dfffec00000 ( 4124 KB)
[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 GB maximum)
[ 0.000000] 0xffff7e0000000000 - 0xffff7e00006f8000 ( 6 MB actual)
[ 0.000000] memory : 0xffff800000000000 - 0xffff80001be00000 ( 446 MB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 25.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x5c40939b5, max_idle_ns: 440795202646 ns
[ 0.000004] sched_clock: 56 bits at 25MHz, resolution 40ns, wraps every 4398046511100ns
[ 0.008449] Console: colour dummy device 80x25
[ 0.012987] Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000)
[ 0.023430] pid_max: default: 32768 minimum: 301
[ 0.028168] Security Framework initialized
[ 0.032642] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.039832] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.046780] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.053459] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.076649] ASID allocator initialised with 32768 entries
[ 0.082173] Hierarchical SRCU implementation.
[ 0.094959] EFI services will not be available.
[ 0.107550] smp: Bringing up secondary CPUs ...
[ 0.112126] smp: Brought up 1 node, 1 CPU
[ 0.116168] SMP: Total of 1 processors activated.
[ 0.120915] CPU features: detected feature: 32-bit EL0 Support
[ 0.126797] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.136951] CPU: All CPU(s) started at EL2
[ 0.141088] alternatives: patching kernel code
[ 0.146256] devtmpfs: initialized
[ 0.151678] random: get_random_u32 called from bucket_table_alloc+0x108/0x258 with crng_init=0
[ 0.164804] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.174679] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.181459] xor: measuring software checksum speed
[ 0.226411] 8regs : 1918.000 MB/sec
[ 0.270680] 8regs_prefetch: 1710.000 MB/sec
[ 0.315297] 32regs : 2359.000 MB/sec
[ 0.359555] 32regs_prefetch: 1983.000 MB/sec
[ 0.364210] xor: using function: 32regs (2359.000 MB/sec)
[ 0.369660] pinctrl core: initialized pinctrl subsystem
[ 0.376808] DMI not present or invalid.
[ 0.382206] NET: Registered protocol family 16
[ 0.389538] cpuidle: using governor menu
[ 0.395719] vdso: 2 pages (1 code @ ffff000008d46000, 1 data @ ffff0000093b5000)
[ 0.403558] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.411598] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.418744] Serial: AMBA PL011 UART driver
[ 0.426122] Machine: LS1012A RDB Board
[ 0.430765] SoC family: QorIQ LS1012A
[ 0.434510] SoC ID: svr:0x87040120, Revision: 2.0
[ 0.506031] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.593084] raid6: int64x1 gen() 399 MB/s
[ 0.665550] raid6: int64x1 xor() 372 MB/s
[ 0.738014] raid6: int64x2 gen() 596 MB/s
[ 0.810426] raid6: int64x2 xor() 510 MB/s
[ 0.882862] raid6: int64x4 gen() 907 MB/s
[ 0.955298] raid6: int64x4 xor() 639 MB/s
U盘FAT32;kernel镜像原厂
信息如下:
CPU0(A53):1000 MHz
I2C: ready
DRAM: 446 MiB
OK
In: serial
Out: serial
Err: serial
Model: OK1012-C
Board: OK1012-C
Found 0 device(s).
PFE tmu pe firmware
Stopping PFE...
starting USB...
USB XHCI 1.00
Scanning mmc 1:1...
Starting kernel ...
举报
