正常进入uboot指令阶段,设置好addrip serverip,此时ping服务器发现报错FEC1 Wai
ting for PHY auto negotiation to complete......... TIMEOUT !。之前操作均是参考手册执行。
以下是uboot 环境参数打印
- baudrate=115200
- boot_fdt=try
- bootcmd=if mmc rescan; then if run loadbootscript; then run bootscript; else if test ${bootdev} = sd1; then echo update firmware.........;run update_from_sd;else echo mmc boot..........;if run loadimage; then run mmcboot; else run netboot; fi; fi; fi; else run netboot; fi;
- bootcmd_mfg=run mfgtool_args;bootz ${loadaddr} ${initrd_addr} ${fdt_addr};
- bootdelay=3
- bootdev=mmc2
- bootscript=echo Running bootscript from mmc ...; source
- console=ttymxc0
- ethact=FEC1
- ethaddr=00:E0:0C:BC:E5:60
- ethprime=FEC
- fdt_addr=0x83000000
- fdt_file=imx6ul-14x14-evk.dtb
- fdt_high=0xffffffff
- image=zImage
- initrd_addr=0x83800000
- initrd_high=0xffffffff
- ip_dyn=yes
- ipaddr=192.168.10.188
- loadaddr=0x80800000
- loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};
- loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}
- loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}
- logoflag=70
- mfgtool_args=setenv bootargs console=${console},${baudrate} rdinit=/linuxrc g_mass_storage.stall=0 g_mass_storage.removable=1 g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF g_mass_storage.iSerialNumber="" clk_ignore_unused
- mmcargs=setenv bootargs console=${console},${baudrate} calibrate=${calibrate} cma=320M root=${mmcroot}
- mmcautodetect=yes
- mmcboot=echo Booting from mmc ...; run mmcargs; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
- mmcdev=1
- mmcpart=1
- mmcroot=/dev/mmcblk1p2 rootwait rw
- netargs=setenv bootargs console=${console},${baudrate} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp
- netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${image}; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if ${get_cmd} ${fdt_addr} ${fdt_file}; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi;
- panel=TFT70AB
- script=boot.scr
- serverip=192.168.10.227
- splashimage=0x90000000
- update_emmc=mmc rescan;fatload mmc 0 ${loadaddr} /bin/${image}; fatload mmc 0 ${initrd_addr} /bin/ramdisk.img.u; fatload mmc 0 ${fdt_addr} /bin/${fdt_file}; set bootargs console=${console},${baudrate} cma=320M rdinit=/linuxrc; bootz ${loadaddr} ${initrd_addr} ${fdt_addr};
- update_from_sd=run update_emmc;
- Environment size: 2564/8188 bytes
尝试ping 服务器ip发现:
- => ping 192.168.10.227
- FEC1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
- Using FEC1 device
- ping failed; host 192.168.10.227 is not alive
- => ping serverip
- ping - send ICMP ECHO_REQUEST to network host
- Usage:
- ping pingAddress
- => ping ${serverip}
- Using FEC1 device
麻烦尽快解决以下啊。很着急啊。
