瑞芯微Rockchip开发者社区
直播中
感谢相遇
10年用户 1058经验值
擅长:嵌入式技术 制造/封装 控制/MCU
私信 关注
[问答]
移植vsftpd至OK335XS开发板无法连接arm是为什么?怎么解决?
环境:vsftpd-3.0.2, 硬件:OK335XS,虚拟机:ubuntu12.04(32位开发板自带)
(1) 修改vsf_findlibs.sh
屏蔽53、54、57行
50 # Look for libcap (capabilities)
51 if locate_library /lib/libcap.so.1; then
52   echo "/lib/libcap.so.1";
53 #elif locate_library /lib/libcap.so.2; then
54 #  echo "/lib/libcap.so.2";
55 else
56   locate_library /usr/lib/libcap.so && echo "-lcap";
57 #  locate_library /lib/libcap.so && echo "-lcap";
58   locate_library /lib64/libcap.so && echo "-lcap";
59 fi
(2) 修改Makefile
# Makefile for systems with GNU tools
#CC     =       gcc
CC      =       /usr/local/arm/cross/am335xt3/devkit/bin/arm-arago-linux-gnueabi-gcc
INSTALL =       install
IFLAGS  = -idirafter dummyinc
#CFLAGS = -g
CFLAGS  =       -O2 -fPIE -fstack-protector --param=ssp-buffer-size=4
        -Wall -W -Wshadow -Werror -Wformat-security
        -D_FORTIFY_SOURCE=2
        #-pedantic -Wconversion
LIBS    =       `./vsf_findlibs.sh`-lcap -lpam
LINK    =       -Wl,-s
LDFLAGS =       -fPIE -pie -Wl,-z,relro -Wl,-z,now
保存后退出执行make
(3)执行 arm-arago-linux-gnueabi-readelf -d vsftpd 显示需要哪些库
0x00000001 (NEEDED)                     Shared library: [libcap.so.2]
0x00000001 (NEEDED)                     Shared library: [libpam.so.0]
0x00000001 (NEEDED)                     Shared library: [libc.so.6]
0x00000001 (NEEDED)                     Shared library: [ld-linux.so.3]
拷贝共享库至/rootfs/lib,把生成的vsftpd 拷贝到跟文件系统的***in目录下,把vsftpd.conf文件拷贝到 根文件系统的/rootfs/etc目录下。
(4)修改配置文件vsftpd.conf
修改内容为:
anonymous_enable=YES
write_enable=YES
anon_upload_enable=YES
anon_mkdir_write_enable=YES
dirmessage_enable=YES
connect_from_port_20=YES
chown_uploads=YES
chown_username=ftp
xferlog_std_format=YES
#nopriv_user=ftp
async_abor_enable=YES
ascii_upload_enable=YES
ascii_download_enable=YES
ls_recurse_enable=YES
listen=YES
listen_port=21
anon_other_write_enable=YES
(5)开发板根文件系统创建必要的目录:
mkdir-p /var/ftp/pub
mkdir -p /usr/share/empty
chown root:root/var/ftp
chmod 755 /home/rootfs/var/ftp
cd /var/ftp
chmod 777 pub
(6)创建用户
/etc/group文件至少要有root:
root:*:0:
/etc/passwd文件增加ftp和nobody用户:
root::0:0:root:/:/bin/sh
ftp::14:50:FTPUser:/var/ftp:
nobody:*:99:99:Nobody:/:
(7)缺少libattr.so.1共享库,需拷贝至/lib;
(8)开发板执行vsftpd /etc/vsftpd.conf &
遇到问题:
(1)虚拟机ubuntu执行ftp 192.168.0.232显示信息:
root@ubuntu:~# ftp 192.168.0.232
Connected to 192.168.0.232.
220 (vsFTPd 3.0.2)
Name (192.168.0.232:root): ftp
331 Please specify the password.
Password:
230 Login successful.
Remote system type is UNIX.
Using binary mode to transfer files.
ftp>
ftp>
ftp>
ftp>
ftp> ls
200 PORT command successful. Consider using PASV.
500 OOPS: socket
在我输入ls命令时出现“200 PORT command successful. Consider using PASV.500 OOPS: socket”。无法连接arm了。在xshell尝试也是出现“500 OOPS: socket”,断开了。
这个问题我网上查了很多资料尝试了,但是一直没解决。希望技术支持和各位大牛帮忙指导。先谢谢了。期待你们的回复。谢谢!
回帖(4)
李秋年
2022-1-12 11:33:51
  • 可以ping通的。
举报
李宏
2022-1-12 11:33:57
看看是否开启了selinux,如果开了,关了试试
举报
黄淳
2022-1-12 11:34:05
改linux内核
举报
彭玉林
2022-1-12 11:34:09
  • 试试使用以下命令创建用户,大概率和登录用户没有权限有关
    useradd testuser  创建用户testuser
    passwd testuser  给已创建的用户testuser设置密码
举报
更多回帖
