瑞芯微Rockchip开发者社区
登录
直播中
茶缸子
13年用户
538经验值
私信
[问答]
fec2disabled后第一个网口不能用了该怎么配置
开启该帖子的消息推送
网口
MDIO
配置
我想保留网口1,去掉网口二,但是fec2disabled后第一个网口也不能用了,请问该怎么配置? 295 &fec1 { 296 pinctrl-names = "default";
297 pinctrl-0 = <&pinctrl_enet1>;
298 phy-mode = "rmii";
299 phy-handle = <ðphy0>;
300 status = "okay";
301 };
302
303 &fec2 {
304 pinctrl-names = "default";
305 pinctrl-0 = <&pinctrl_enet2>;
306 phy-mode = "rmii";
307 phy-handle = <ðphy1>;
308 status = "disabled";
309
310 mdio {
311 #address-cells = <1>;
312 #size-cells = <0>;
313
314 ethphy0: ethernet-phy@2 {
315 compa
ti
ble = "ethernet-phy-ieee802.3-c22";
316 reg = <2>;
317 };
318
319 ethphy1: ethernet-phy@1 {
320 compatible = "ethernet-phy-ieee802.3-c22";
321 reg = <1>;
322 };
323 };
324 };
848 pinctrl_enet1: enet1grp {
849 fsl,pins = <
850 MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN 0x1b0b0
851 MX6UL_PAD_ENET1_RX_ER__ENET1_RX_ER 0x1b0b0
852 MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00 0x1b0b0
853 MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x1b0b0
854 MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN 0x1b0b0
855 MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x1b0b0
856 MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x1b0b0
857 MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 0x4001b031
858 >;
859 };
875 pinctrl_enet2: enet2grp {
876 fsl,pins = <
877 MX6UL_PAD_GPIO1_IO07__ENET2_MDC 0x1b0b0
878 MX6UL_PAD_GPIO1_IO06__ENET2_MDIO 0x1b0b0
879 MX6UL_PAD_ENET2_RX_EN__ENET2_RX_EN 0x1b0b0
880 MX6UL_PAD_ENET2_RX_ER__ENET2_RX_ER 0x1b0b0
881 MX6UL_PAD_ENET2_RX_DATA0__ENET2_RDATA00 0x1b0b0
882 MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01 0x1b0b0
883 MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN 0x1b0b0
884 MX6UL_PAD_ENET2_TX_DATA0__ENET2_TDATA00 0x1b0b0
885 MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01 0x1b0b0
886 MX6UL_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 0x4001b031
887 MX6UL_PAD_SNVS_TAMPER0__GPIO5_IO00 0x80000000
888 >;
889 };
回帖
(4)
陈辉
2022-1-10 11:52:14
两个网口共用mdio,mdio在&fec2里,关掉就不能用了,需要改一下
举报
望艳妮
2022-1-10 11:52:29
下边还有MDIO相关配置,也得修改,光改一处不行啊
举报
郭武莱
2022-1-10 11:52:45
问题解决了吗,我也遇到这个问题
问题解决了吗,我也遇到这个问题
举报
刘丽艳
2022-1-10 11:52:52
您设置的reg = <2>;的值不对
您设置的reg = <2>;的值不对
举报
更多回帖
rotate(-90deg);
回复
相关问答
网口
MDIO
配置
fec2disabled
后
第一个
网
口
不能用
怎么办
2022-01-13
1374
rtt-studio的debug进入
后
不能
在mian的
第一个
程序运行如何解决?
2023-02-21
635
如何修改
网
口
通信模式,改为四路差分信号通信模式?
2022-01-07
1068
RK3568两
个
网
口
都
不能
Ping通的原因是什么
2022-07-13
5286
AM1808
网
口
问题
2018-05-15
2556
使用OSSchedLock()关闭调度器
后
,延时函数为什么
不能用了
2020-03-23
3130
GL850G接鼠标与键盘有时候
不能用
2019-01-12
4959
RK3568两
个
网
口
都
不能
Ping通请问下这是什么原因呢?
2023-01-10
1372
STM32写PWM四路输出St_link突然就
不能用了
是为什么?
2022-01-19
1856
SPI接口
网
口
的问题
2023-05-14
6958
登录/注册
20万+
工程师都在用,
免费
PCB检查工具
无需安装、支持浏览器和手机在线查看、实时共享
查看
点击登录
登录更多精彩功能!
首页
论坛版块
小组
免费开发板试用
ebook
直播
搜索
登录
