瑞芯微Rockchip开发者社区
登录
直播中
风来吴山
8年用户
1387经验值
擅长:电源/新能源
私信
[问答]
a40i_c核心板使用原始的镜像文件启动后出错如何解决
开启该帖子的消息推送
核心板
系统镜像文件
自己设计的底板,用的a40i_c的核心板,使用原始的镜像文件,启动后提示如下错误,请问是什么问题,该如何解决?
[ 21.010089] gpu cooling callback set freq limit 384
[ 23.040048] ------------[ cut here ]------------
[ 23.045122] WARNING: at net/sched/sch_generic.c:255 dev_watchdog+0x1b0/0x238()
[ 23.053277] NETDEV WATCHDOG: eth0 (sun4i-emac): transmit queue 0
ti
med out
[ 23.060955] Modules linked in: mali(O) gt9xxnew_ts
[ 23.066226] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W O 3.10.65 #96
[ 23.074191] [
] (unwind_backtrace+0x0/0xe8) from [
] (show_stack+0x20/0x24)
[ 23.083688] [
] (show_stack+0x20/0x24) from [
] (dump_stack+0x20/0x28)
[ 23.092706] [
] (dump_stack+0x20/0x28) from [
] (warn_slowpath_common+0x5c/0x7c)
[ 23.102682] [
] (warn_slowpath_common+0x5c/0x7c) from [
] (warn_slowpath_fmt+0x40/0x48)
[ 23.113340] [
] (warn_slowpath_fmt+0x40/0x48) from [
] (dev_watchdog+0x1b0/0x238)
[ 23.123485] [
] (dev_watchdog+0x1b0/0x238) from [
] (call_timer_fn+0x60/0x154)
[ 23.133293] [
] (call_timer_fn+0x60/0x154) from [
] (run_timer_softirq+0x1d0/0x248)
[ 23.143619] [
] (run_timer_softirq+0x1d0/0x248) from [
] (__do_softirq+0x100/0x27c)
[ 23.153954] [
] (__do_softirq+0x100/0x27c) from [
] (do_softirq+0x54/0x60)
[ 23.163474] [
] (do_softirq+0x54/0x60) from [
] (irq_exit+0x84/0xcc)
[ 23.172300] [
] (irq_exit+0x84/0xcc) from [
] (handle_IRQ+0x7c/0xa0)
[ 23.181119] [
] (handle_IRQ+0x7c/0xa0) from [
] (gic_handle_irq+0x4c/0x6c)
[ 23.190523] [
] (gic_handle_irq+0x4c/0x6c) from [
] (__irq_svc+0x40/0x70)
[ 23.199660] Exception stack(0xc0a3fec0 to 0xc0a3ff08)
[ 23.205440] fec0: c0a3ff08 00000005 5d4a8157 00000005 c197b238 c0b518b8 00000000 c0be5e7c
[ 23.214549] fee0: 5d41642b 00000005 00000000 c0a3ff3c 00000008 c0a3ff08 c0067fa8 c0477134
[ 23.223686] ff00: 000b0013 ffffffff
[ 23.227534] [
] (__irq_svc+0x40/0x70) from [
] (cpuidle_enter_state+0x60/0xe8)
[ 23.237386] [
] (cpuidle_enter_state+0x60/0xe8) from [
] (cpuidle_idle_call+0x114/0x234)
[ 23.248142] [
] (cpuidle_idle_call+0x114/0x234) from [
] (arch_cpu_idle+0x18/0x48)
[ 23.258363] [
] (arch_cpu_idle+0x18/0x48) from [
] (cpu_startup_entry+0x128/0x208)
[ 23.268641] [
] (cpu_startup_entry+0x128/0x208) from [
] (rest_init+0xa0/0xbc)
[ 23.278538] [
] (rest_init+0xa0/0xbc) from [
] (start_kernel+0x2b4/0x308)
[ 23.287847] ---[ end trace 983cab6710d32da9 ]---
PS:在网上搜索过解决“NETDEV WATCHDOG: eth0: transmit timed out”的方法:
/boot/grub/menu.lst文件,在启动的核心kernel那行最后加上
acpi=off noapic
不知道是我编译的不对还是怎么,重新生成镜像后还是会出现一样的问题
核心板是好的,的确是phy芯片与
开发板
有区别,我们底板用的是YT8521SH的rgmii,请问有关于修改内核驱动的相关教程吗?刚接触这方面,不太熟悉
回帖
(2)
刘萍
2022-1-4 11:04:02
您的核心板在我们的底板上用,使用同一版镜像,会存在这种问题吗?如果没有,说明核心板是好的,您需要看一下您硬件设计的和我们底板哪些地方不同。从打印信息看是网口报出来的信息,您烧写我们最新的用户资料2020.12.18的镜像试一下。
举报
马昱
2022-1-4 11:04:13
您联系一下和您对接的销售,让她给您提供一下百兆千兆双网口扩展的方法,里边有关于这部分的描述。
举报
更多回帖
rotate(-90deg);
回复
相关问答
核心板
系统镜像文件
自己设计的底板,用的
a40i_c
的
核心板
,使用
原始
的
镜像文件
启动
后
提示错误怎么解决?
2022-01-13
972
请问
A40i
支持从TF卡
启动
吗?需要怎么设置?
2022-01-04
1773
用
A40i
设计的
核心板
和底板可以通过修改.fex
文件
来生成
镜像
吗
2021-12-31
814
请教大神
A40i
的
核心板
移植ubuntu系统的参考方法有吗
2022-01-04
1694
为什么
A40i
上电
后
HDMI显示没有任何输出呢
2022-01-04
1739
如何操作才能直接向
核心板
烧录
镜像
2022-01-04
1684
A40i
核心板
上电DEBUG串口没有输出有何影响
2022-01-04
1473
请问FETA
40i-C
核心板
PMIC输出的VCC_3V3能提供多大电流?
2022-01-05
917
请问FETA
40i-C
核心板
2022-01-13
1149
启动
DevEco Studio本地模拟器提示
镜像文件
缺失怎么解决
2022-04-07
1211
登录/注册
20万+
工程师都在用,
免费
PCB检查工具
无需安装、支持浏览器和手机在线查看、实时共享
查看
点击登录
登录更多精彩功能!
首页
论坛版块
小组
免费开发板试用
ebook
直播
搜索
登录
