你好,不是内存问题,是uu工具的问题,请按照下面的补丁修改分类:
diff --git a/arch/arm/dts/fsl-imx8mm-evk.dts b/arch/arm/dts/ fsl-imx8mm-evk.dts
索引 747abb4ed3..3a66adcaa7 100644
--- a/arch/arm/dts/fsl-imx8mm-evk.dts
+++ b/arch/arm/dts/fsl-imx8mm-evk.dts
@ @ -486,6 +486,7 @@
&u***otg1 {
status = "ok";
extcon = <&typec_ptn5110_1>;
+ dr_mode = "外设";
&u***otg2 {
DIFF --git一个/板/飞思卡尔/ imx8mm_evk / imx8mm_evk.cb /板/飞思卡尔/ imx8mm_evk / imx8mm_evk.c
索引a1b7e08c99..f6e16a4aa3 100644
---一个/板/飞思卡尔/ imx8mm_evk / imx8mm_evk.c
+++ b/板/飞思卡尔/imx8mm_evk/imx8mm_evk.c
@@ -388,7 +388,22 @@ int board_ehci_u***_phy_mode(struct udevice *dev)
return USB_INIT_DEVICE;
+#else
+int board_u***_init(int index, enum u***_init_type init)
+ printf("board_u***_init %d, type %dn", index, init);
+ imx8m_u***_power(索引,真);
+int board_u***_cleanup(int index, enum u***_init_type init)
+ printf("board_u***_cleanup %d, type %dn", index, init);
+ imx8m_u***_power(索引,假);
+int board_ehci_u***_phy_mode(struct udevice *dev)
+ printf("board_ehci_u***_phy_mode 什么都不做n");
#endif
int board_init(void)
diff --git a/configs/imx8mm_evk_defconfig b/configs/imx8mm_evk_defconfig
索引 125587560e..33fb1d0060 100644
--- a/configs/imx8mm_evk_defconfig
+++ b/configs/imx8mm_evk_defconfig
= 125587560e..33fb1d0060 ÿ
CONFIG_ARCH_IMX8M = Y
= 0x40200000 CONFIG_SYS_TEXT_BASE
CONFIG_SYS_MALLOC_F_LEN =为0x2000
-CONFIG_USB_TCPC = Y
+#CONFIG_USB_TCPC = Y
CONFIG_TARGET_IMX8MM_EVK = Y
CONFIG_SYS_EXTRA_OPTIONS = “IMX_CONFIG = ARCH /臂/马赫- IMX / spl_sd.cfg,SPL_TEXT_BASE = 0x7E1000”
CONFIG_FIT = Y
&u***otg1 {
status = "ok";
+ dr_mode = "外设";
&u***otg2 {
+#else
#endif
CONFIG_FIT = Y
举报
