STM32
直播中
贺楠
8年用户 1026经验值
私信 关注
[问答]
请问单片机读取温度如何通过串口1在串口调试助手上显示温度?
回帖(1)
孟竹
2021-12-14 13:55:54
单片机读取温度通过串口1在串口调试助手上显示温度。
头文件
#ifndef __MLX90614_H
#define __MLX90614_H
#include "sys.h"
void SMBus_StartBit(void);
void SMBus_StopBit(void);
void SMBus_SendBit(u8);
u8 SMBus_SendByte(u8);
u8 SMBus_ReceiveBit(void);
u8 SMBus_ReceiveByte(u8);
void SMBus_Delay(u16);
void SMBus_Init(void);
u16 SMBus_ReadMemory(u8, u8);
u8 PEC_Calculation(u8*);
float SMBus_ReadTemp(void);    //获取温度值
void SMBus_DisplayTemperature(void);    //在LCD第5,6页显示温度
#endif
源文件
#include "mlx90614.h"
#define ACK         0
#define        NACK 1
#define SA                                0x00 //从机地址,单个MLX90614时地址为0x00,多个时地址默认为0x5a
#define RAM_ACCESS                0x00 //RAM access command
#define EEPROM_ACCESS        0x20 //EEPROM access command
#define RAM_TOBJ1                0x07 //To1 address in the eeprom
#define SMBUS_PORT            GPIOB
#define SMBUS_SCK                GPIO_Pin_6
#define SMBUS_SDA                GPIO_Pin_7
#define RCC_APB2Periph_SMBUS_PORT                RCC_APB2Periph_GPIOB
#define SMBUS_SCK_H()            SMBUS_PORT->BSRR = SMBUS_SCK
#define SMBUS_SCK_L()            SMBUS_PORT->BRR = SMBUS_SCK
#define SMBUS_SDA_H()            SMBUS_PORT->BSRR = SMBUS_SDA
#define SMBUS_SDA_L()            SMBUS_PORT->BRR = SMBUS_SDA
#define SMBUS_SDA_PIN()            SMBUS_PORT->IDR & SMBUS_SDA //读取引脚电平
* 函数名: SMBus_StartBit
* 功能  : 产生起始位
* Input          : None
* Output         : None
* Return         : None
    SMBUS_SDA_H();                // Set SDA line
    SMBus_Delay(5);            // Wait a few microseconds
    SMBUS_SCK_H();                // Set SCL line
    SMBus_Delay(5);            // Generate bus free time between Stop
    SMBUS_SDA_L();                // Clear SDA line
    SMBus_Delay(5);            // Hold time after (Repeated) Start
    // Condition. After this period, the first clock is generated.
    //(Thd:sta=4.0us min)
    SMBUS_SCK_L();            // Clear SCL line
* 函数名: SMBus_StopBit
* 功能: Generate STOP condition on SMBus
* Input          : None
* Output         : None
* Return         : None
    SMBus_Delay(5);            // Stop condition setup time(Tsu:sto=4.0us min)
* 函数名: SMBus_SendByte
* 功能: Send a byte on SMBus
* Input          : Tx_buffer
* Output         : None
* Return         : None
u8 SMBus_SendByte(u8 Tx_buffer)
    u8        Bit_counter;
    u8        Ack_bit;
    u8        bit_out;
    for(Bit_counter=8; Bit_counter; Bit_counter--)
        if (Tx_buffer&0x80)
            bit_out=1;   // If the current bit of Tx_buffer is 1 set bit_out
        else
            bit_out=0;  // else clear bit_out
        SMBus_SendBit(bit_out);                // Send the current bit on SDA
        Tx_buffer<<=1;                                // Get next bit for checking
    Ack_bit=SMBus_ReceiveBit();                // Get acknowledgment bit
    return        Ack_bit;
* 函数名: SMBus_SendBit
* 功能: Send a bit on SMBus 82.5kHz
* Input          : bit_out
* Output         : None
* Return         : None
void SMBus_SendBit(u8 bit_out)
    if(bit_out==0)
        SMBUS_SDA_L();
    else
        SMBUS_SDA_H();
    SMBus_Delay(2);                                        // Tsu:dat = 250ns minimum
    SMBus_Delay(6);                                        // High Level of Clock Pulse
    SMBus_Delay(3);                                        // Low Level of Clock Pulse
//        SMBUS_SDA_H();                                    // Master release SDA line ,
    return;
* Function Name  : SMBus_ReceiveBit
* Description    : Receive a bit on SMBus
* Input          : None
* Output         : None
* Return         : Ack_bit
    u8 Ack_bit;
    SMBUS_SDA_H();          //引脚靠外部电阻上拉,当作输入
        SMBus_Delay(2);                        // High Level of Clock Pulse
    SMBus_Delay(5);                        // High Level of Clock Pulse
    if (SMBUS_SDA_PIN())
        Ack_bit=1;
    else
        Ack_bit=0;
    return        Ack_bit;
* 函数名: SMBus_ReceiveByte
* 功能: Receive a byte on SMBus
* Input          : ack_nack
* Output         : None
* Return         : RX_buffer
u8 SMBus_ReceiveByte(u8 ack_nack)
    u8         RX_buffer;
    u8        Bit_Counter;
    for(Bit_Counter=8; Bit_Counter; Bit_Counter--)
        if(SMBus_ReceiveBit())                        // Get a bit from the SDA line
            RX_buffer <<= 1;                        // If the bit is HIGH save 1  in RX_buffer
            RX_buffer |=0x01;
        else
            RX_buffer <<= 1;                        // If the bit is LOW save 0 in RX_buffer
            RX_buffer &=0xfe;
    SMBus_SendBit(ack_nack);                        // Sends acknowledgment bit
    return RX_buffer;
* 函数名: SMBus_Delay
* 功能: 延时  一次循环约1us
* Input          : time
* Output         : None
* Return         : None
void SMBus_Delay(u16 time)
    u16 i, j;
    for (i=0; i<4; i++)
        for (j=0; j     }
* 函数名: SMBus_Init
* 功能: SMBus初始化
* Input          : None
* Output         : None
* Return         : None
void SMBus_Init()
    GPIO_InitTypeDef    GPIO_InitStructure;
        /* Enable SMBUS_PORT clocks */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_SMBUS_PORT, ENABLE);
    /*配置SMBUS_SCK、SMBUS_SDA为集电极开漏输出*/
    GPIO_InitStructure.GPIO_Pin = SMBUS_SCK | SMBUS_SDA;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(SMBUS_PORT, &GPIO_InitStructure);
    SMBUS_SCK_H();
    SMBUS_SDA_H();
* 函数名: SMBus_ReadMemory
* 功能: READ DATA FROM RAM/EEPROM
* Input          : slaveAddress, command
* Return         : Data
u16 SMBus_ReadMemory(u8 slaveAddress, u8 command)
    u16 data;                        // Data storage (DataH:DataL)
    u8 Pec;                                // PEC byte storage
    u8 DataL=0;                        // Low data byte storage
    u8 DataH=0;                        // High data byte storage
    u8 arr[6];                        // Buffer for the sent bytes
    u8 PecReg;                        // Calculated PEC byte storage
    u8 ErrorCounter;        // Defines the number of the attempts for communication with MLX90614
    ErrorCounter=0x00;                                // Initialising of ErrorCounter
        slaveAddress <<= 1;        //2-7位表示从机地址
    do
repeat:
        SMBus_StopBit();                            //If slave send NACK stop comunication
        --ErrorCounter;                                    //Pre-decrement ErrorCounter
        if(!ErrorCounter)                             //ErrorCounter=0?
            break;                                            //Yes,go out from do-while{}
        SMBus_StartBit();                                //Start condition
        if(SMBus_SendByte(slaveAddress))//Send SlaveAddress 最低位Wr=0表示接下来写命令
            goto        repeat;                            //Repeat comunication again
        if(SMBus_SendByte(command))            //Send command
        SMBus_StartBit();                                        //Repeated Start condition
        if(SMBus_SendByte(slaveAddress+1))        //Send SlaveAddress 最低位Rd=1表示接下来读数据
        DataL = SMBus_ReceiveByte(ACK);        //Read low data,master must send ACK
        DataH = SMBus_ReceiveByte(ACK); //Read high data,master must send ACK
        Pec = SMBus_ReceiveByte(NACK);        //Read PEC byte, master must send NACK
        SMBus_StopBit();                                //Stop condition
        arr[5] = slaveAddress;                //
        arr[4] = command;                        //
        arr[3] = slaveAddress+1;        //Load array arr
        arr[2] = DataL;                                //
        arr[1] = DataH;                                //
        arr[0] = 0;                                        //
        PecReg=PEC_Calculation(arr);//Calculate CRC
    while(PecReg != Pec);                //If received and calculated CRC are equal go out from do-while{}
        data = (DataH<<8) | DataL;        //data=DataH:DataL
    return data;
* 函数名: PEC_calculation
* 功能 : 数据校验
* Input          : pec[]
* Output         : None
* Return         : pec[0]-this byte contains calculated crc value
u8 PEC_Calculation(u8 pec[])
    u8         crc[6];
    u8        BitPosition=47;
    u8        shift;
    u8        i;
    u8        j;
    u8        temp;
    do
        /*Load pattern value 0x000000000107*/
        crc[5]=0;
        crc[4]=0;
        crc[3]=0;
        crc[2]=0;
        crc[1]=0x01;
        crc[0]=0x07;
        /*Set maximum bit position at 47 ( six bytes byte5...byte0,MSbit=47)*/
        BitPosition=47;
        /*Set shift position at 0*/
        shift=0;
        /*Find first "1" in the transmited message beginning from the MSByte byte5*/
        i=5;
        j=0;
        while((pec&(0x80>>j))==0 && i>0)
            BitPosition--;
            if(j<7)
                j++;
            else
                j=0x00;
                i--;
        }/*End of while */
        /*Get shift value for pattern value*/
        shift=BitPosition-8;
        /*Shift pattern value */
        while(shift)
            for(i=5; i<0xFF; i--)
                if((crc[i-1]&0x80) && (i>0))
                    temp=1;
                else
                    temp=0;
                crc<<=1;
                crc+=temp;
            }/*End of for*/
            shift--;
        }/*End of while*/
        /*Exclusive OR between pec and crc*/
        for(i=0; i<=5; i++)
            pec ^=crc;
        }/*End of for*/
    while(BitPosition>8); /*End of do-while*/
    return pec[0];
* 函数名: SMBus_ReadTemp
* 功能: 计算并返回温度值
* Return         : SMBus_ReadMemory(0x00, 0x07)*0.02-273.15
        return SMBus_ReadMemory(SA, RAM_ACCESS|RAM_TOBJ1)*0.02-273.15;
/*********************************END OF FILE*********************************/
主函数
#include "led.h"
#include "delay.h"
#include "key.h"
#include "sys.h"
#include "lcd.h"
#include "usart.h"
#include "adc.h"
int main(void)
        float a;
        delay_init();                     //延时函数初始化
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级
        uart_init(115200);                  //串口初始化为115200
        LED_Init();                             //LED端口初始化
        LCD_Init();
    SMBus_Init();
        while(1)
                a = SMBus_ReadTemp();
                printf("温度 = %f℃rn",a);
                LED0=!LED0;
                delay_ms(250);
举报
更多回帖
