1.配置串口
void USART1_Config(void)
//初始化使用的端口 A9->TX A10->Rx
//初始化GPIO
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART1_InitStructure;
//使能时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//复用推挽输出
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
//配置波特率等
USART1_InitStructure.USART_BaudRate = 115200;
USART1_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//None
USART1_InitStructure.USART_Mode = USART_Mode_Tx|USART_Mode_Rx;//
USART1_InitStructure.USART_Parity = USART_Parity_No;//No
USART1_InitStructure.USART_StopBits = USART_StopBits_1;//1
USART1_InitStructure.USART_WordLength = USART_WordLength_8b;//8b
//配置
USART_Init(USART1,&USART1_InitStructure);
// USART_DMACmd(USART1, USART_DMAReq_Tx, ENABLE);
//使能
USART_Cmd(USART1,ENABLE);
USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
USART_ITConfig(USART1,USART_IT_IDLE,ENABLE);
2.配置串口中断
void NVIC_Config(void)
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
//配置串口中断
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_Init(&NVIC_InitStructure);
//DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,ENABLE);
3.配置串口中断响应函数
/************定义联合体的意义是接收字节数>1的数,如浮点数**************/
/***********对于一帧多个字节数据可以直接使用数组来接受就OK了,不需要用联合体****/
union DataType{
unsigned char s[4];
unsigned int data;
}RxDataType;//共用内存地址思想,详见C语言
void USART1_IRQHandler(void)
GPIO_WriteBit(GPIOB,GPIO_Pin_0 ,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOB,GPIO_Pin_0)));
if(USART_GetITStatus(USART1,USART_IT_RXNE) != RESET)//是否接受到一个字节
RxDataType.s[RxCounter++] = USART1->DR;
if(USART_GetITStatus(USART1,USART_IT_IDLE) != RESET)//是否接受到一帧
USART1->SR;
USART1->DR;
RxCounter=0;
代码解释如上注释
以下为测试使用代码
串口发送代码
GPIO_WriteBit(GPIOB,GPIO_Pin_0 ,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOB,GPIO_Pin_0)));//LED闪烁辅助观察
USART1->SR;
USART1->DR;//这两句是清除状态位的,必须加上。如果提示未使用,定义一个uint8_t变量存储返回值即可
RxCounter=0;//一帧数据存储完毕,清零
STM32串口发送代码:
/***************这里我是定义外部中断使能发送的,可以直接发这段代码放在主函数while循环中也可以***/
void EXTI1_IRQHandler(void)
GPIO_WriteBit(GPIOB,GPIO_Pin_1 ,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOB,GPIO_Pin_1)));
USART_SendData(USART1,0xAA);
delay_ms(1);
USART_SendData(USART1,RxDataType.s[0]);
delay_ms(1);
USART_SendData(USART1,RxDataType.s[1]);
delay_ms(1);
USART_SendData(USART1,RxDataType.s[2]);
delay_ms(1);
USART_SendData(USART1,RxDataType.s[3]);
delay_ms(1);
USART_SendData(USART1,0xFF);
delay_ms(1);
for(c = 0;c < 4;++c)
RxDataType.s[c] = 0;
EXTI_ClearITPendingBit(EXTI_Line1);
演示效果:
默认情况下,STM32发送给电脑的数据应该是0,对应的16进制应该是
AA 00 00 00 00 FF
当电脑1111STM32,STM32接收到给电脑发送数据
接收到AA 11 00 00 00 FF后,数据变成了AA 00 00 00 00 FF,是我设置了一次发送之后即将所有位设置为0,代码见“发送代码” for(c = 0;c < 4;++c) { RxDataType.s[c] = 0; }
当电脑发送22 22给STM32之后,STM32接收到数据并回传给电脑:
当电脑发送88 88 88 88给STM32之后,STM32接收到数据并回传给
其他
上位机和下位
电脑之间发送和接收浮动、双类型的数据使用联合体统计**
1.配置串口
//初始化GPIO
//使能时钟
//配置波特率等
//配置
//使能
2.配置串口中断
//配置串口中断
3.配置串口中断响应函数
union DataType{
unsigned char s[4];
unsigned int data;
USART1->SR;
USART1->DR;
RxCounter=0;
代码解释如上注释
以下为测试使用代码
串口发送代码
USART1->SR;
STM32串口发送代码:
delay_ms(1);
delay_ms(1);
delay_ms(1);
delay_ms(1);
delay_ms(1);
delay_ms(1);
演示效果:
AA 00 00 00 00 FF
其他
上位机和下位
举报
