STM32
直播中
h1654155275.5669
8年用户 1030经验值
私信 关注
[问答]
STM32F407是如何实现控制180度舵机的
STM32F407是如何实现控制180度舵机的?主要分为哪几个步骤去实现呢?
回帖(1)
萧蔼晨
2021-12-2 10:31:00
其中主要分为两部分,时钟的初始化和主函数的控制部分。
时钟的初始化:
选用TIM14时钟,F9引脚作为信号控制引脚
void TIM14_PWM_Init(u32 arr,u32 psc)
    GPIO_InitTypeDef            GPIO_InitStructure;
    TIM_TimeBaseInitTypeDef        TIM_TimeBaseStructure;
    TIM_OCInitTypeDef            TIM_OCInitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM14,ENABLE);
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF, ENABLE);
    GPIO_PinAFConfig(GPIOF,GPIO_PinSource9,GPIO_AF_TIM14);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;    ­
    GPIO_Init(GPIOF,&GPIO_InitStructure);
    TIM_TimeBaseStructure.TIM_Prescaler=psc;
    TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
    TIM_TimeBaseStructure.TIM_Period=arr;
    TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
    TIM_TimeBaseInit(TIM14,&TIM_TimeBaseStructure);
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OC1Init(TIM14, &TIM_OCInitStructure);
    TIM_OC1PreloadConfig(TIM14, TIM_OCPreload_Enable);
    TIM_ARRPreloadConfig(TIM14,ENABLE);
    TIM_Cmd(TIM14, ENABLE);
主函数控制:
使用按键进行控制,时钟频率设置为50HZ,周期20ms,
舵机属性:0.5ms--------------0;1.0ms------------45;1.5ms------------90;2.0ms-----------135;2.5ms-----------180度。
占空比控制属性:5 / 200 = 0.5ms / 20ms;对应转动0度。5代表pwmval,200为arr
int main(void)
    u8 key;
    u16 pwmval = 0;
    KEY_Init();
    delay_init(168);
    uart_init(115200);
    TIM14_PWM_Init(200-1,8400-1);     // 50hz,20ms,50 = (168M / (200 * 8400))/2 , t = 20ms = 1 / 50,
    pwmval = 5 ;
    while(1)
        key_scan(0);
        if(keydown_data==KEY0_DATA)
        pwmval = 5;
        printf("%d",pwmval);
        if(keyup_data==KEY1_DATA)
            pwmval = 10;
        if(keyup_data==KEY2_DATA)
            pwmval = 15;
        if(keyup_data==KEY3_DATA)
            pwmval = 20;
        delay_ms(5);
        TIM_SetCompare1(TIM14,pwmval);
举报
更多回帖
