首先建立一个简单的模型
进行一下设置
快捷键 ctrl+B ,编译
此时生成的代码:
* File: untitled.c
* Code generated for Simulink model 'untitled'.
* Model version : 1.0
* Simulink Coder version : 9.3 (R2020a) 18-Nov-2019
* C/C++ source code generated on : Sun Jul 19 21:00:16 2020
* Target selection: ert.tlc
* Embedded hardware selection: Intel->x86-64 (Windows64)
* Code generation objectives: Unspecified
* Validation result: Not run
#include "untitled.h"
#include "untitled_private.h"
/* External inputs (root inport signals with default storage) */
ExtU_untitled_T untitled_U;
/* External outputs (root outports fed by signals with default storage) */
ExtY_untitled_T untitled_Y;
/* Real-time model */
RT_MODEL_untitled_T untitled_M_;
RT_MODEL_untitled_T *const untitled_M = &untitled_M_;
/* Model step function */
void untitled_step(void)
/* Outport: '
/Out1' incorporates:
* Inport: '/In1'
* Inport: '/In2'
* Sum: '/Sum'
untitled_Y.Out1 = untitled_U.In2 + untitled_U.In1;
/* Model initialize function */
void untitled_initialize(void)
/* (no initialization code required) */
/* Model terminate function */
void untitled_terminate(void)
/* (no terminate code required) */
* File trailer for generated code.
* [EOF]
有用的:
/* Outport: '/Out1' incorporates:
* Inport: '/In1'
* Inport: '/In2'
* Sum: '/Sum'
参数修改
参数配置
输入设置为:
通过上方按钮添加向相应参数和信号
输出设置为:
参数k设置为:
注: 参数K要有初始值
参数关联
双击连线:更改为之前的,并右键设置property
k直接填就行
编译完后,最终效果:
* File: gen3.c
* Code generated for Simulink model 'gen3'.
* Model version : 1.1
* C/C++ source code generated on : Sun Jul 19 21:47:19 2020
#include "gen3.h"
#include "gen3_private.h"
/* Exported block signals */
real_T z; /* '/Gain' */
RT_MODEL_gen3_T gen3_M_;
RT_MODEL_gen3_T *const gen3_M = &gen3_M_;
void gen3_step(void)
/* Gain: '/Gain' incorporates:
* Inport: '/In1'
* Inport: '/In2'
* Sum: '/Sum'
z = (x + y) * k;
void gen3_initialize(void)
void gen3_terminate(void)
* [EOF]
首先建立一个简单的模型
进行一下设置
快捷键 ctrl+B ,编译
此时生成的代码:
* File: untitled.c
/* Outport: '
* Inport: '/In1'
* Inport: '/In2'
* Sum: '/Sum'
* [EOF]
有用的:
* Inport: '/In1'
* Inport: '/In2'
* Sum: '/Sum'
参数修改
参数配置
输入设置为:
通过上方按钮添加向相应参数和信号
输出设置为:
参数k设置为:
注: 参数K要有初始值
参数关联
k直接填就行
编译完后,最终效果:
* File: gen3.c
#include "gen3.h"
* Inport: '/In1'
* Inport: '/In2'
* Sum: '/Sum'
z = (x + y) * k;
* [EOF]
举报
