STM32
直播中
陈静
8年用户 1375经验值
私信 关注
[问答]
如何使用python库包对AprilTag进行检测呢
AprilTags是什么?AprilTags有哪些应用呢?
如何使用python库包对AprilTag进行检测呢?
回帖(1)
徐铭潞
2021-11-19 10:54:15
  1 AprilTags介绍
  AprilTag官网
  1、AprilTags类似与二维码QR codes(Quick Response Code;全称为快速响应矩阵图码)
  2、AprilTags可以应用于:
  相机标定
  目标大小估计
  测量相机到目标的距离
  3D 定位(3D positioning)
  机器人
  SLAM
  自主导航(autonomous navigation)
  如下图是一个AprilTag Tag36h11的一张图:
  我们在相机标定的时候,还会用到很多AprilTags在一起组成的标定板,如下图(图片来源):
  3、AprilTag family默认的是:Tag36h11,在AprilTags中有六个系列families:
  Tag36h11
  TagStandard41h12
  TagStandard52h13
  TagCircle21h7
  TagCircle49h12
  TagCustom48h12
  2 使用python库包apriltag对AprilTag进行检测
  2.1 python模块apriltag的安装
  pypi下载安装apriltag库包
  pip install apriltag
  2.2 python模块apriltag的测试用例
  测试用例
  import apriltag
  import cv2
  img = cv2.imread(‘apriltag_foto.jpg’.cv2.IMREAD_GRAYSCALE)
  detector = apriltag.Detector()
  result = detector.detect(img)
  返回结果如下:
  [DetectionBase(tag_family=‘tag36h11’, tag_id=2, hamming=0, goodness=0.0, decision_margin=98.58241271972656, homography=array([[ -1.41302664e-01, 1.08428082e+00, 1.67512900e+01],
  [ -8.75899366e-01, 1.50245469e-01, 1.70532040e+00],
  [ -4.89183533e-04, 2.12210247e-03, 6.02052342e-02]]), center=array([ 278.23643912, 28.32511859]), corners=array([[ 269.8939209 , 41.50381088],
  [ 269.57183838, 11.79248142],
  [ 286.1383667 , 15.84242821],
  [ 286.18066406, 43.48323059]])),
  DetectionBase(tag_family=‘tag36h11’, 。.. etc
  结果中是用collections.OrderedDict存储成字典类型的数据
  3 AprilTags二维码检测,以及绘制检测框
  1、代码
  import cv2
  import apriltag
  image = cv2.imread(‘apriltags_36h11.png’)
  gray = cv2.cvtColor(image, cv2.COLOR_BGR2GRAY)
  # 定义AprilTag检测选项,然后检测AprilTags
  print(f“[INFO] detection AprilTags 。..”)
  options = apriltag.DetectorOptions(families=“tag36h11”)
  detector = apriltag.Detector(options)
  results = detector.detect(gray)
  print(results)
  print(f“[INFO] {len(results)} total AprilTags detected”)
  for r in results:
  # extract the bounding box (x, y)-coordinates for the AprilTag
  # and convert each of the (x, y)-coordinate pairs to integers
  (ptA, ptB, ptC, ptD) = r.corners
  ptB = (int(ptB[0]), int(ptB[1]))
  ptC = (int(ptC[0]), int(ptC[1]))
  ptD = (int(ptD[0]), int(ptD[1]))
  ptA = (int(ptA[0]), int(ptA[1]))
  # 绘制检测到的AprilTag的框
  cv2.line(image, ptA, ptB, (0, 255, 0), 2, lineType=cv2.LINE_AA)
  cv2.line(image, ptB, ptC, (0, 255, 0), 2, lineType=cv2.LINE_AA)
  cv2.line(image, ptC, ptD, (0, 255, 0), 2, lineType=cv2.LINE_AA)
  cv2.line(image, ptD, ptA, (0, 255, 0), 2, lineType=cv2.LINE_AA)
  # 绘制 AprilTag 的中心坐标
  (cX, cY) = (int(r.center[0]), int(r.center[1]))
  cv2.circle(image, (cX, cY), 5, (0, 0, 255), -1)
  # draw the tag family on the image
  tagFamily = r.tag_family.decode(“utf-8”)
  cv2.putText(image, tagFamily, (ptA[0], ptA[1] - 15),
  cv2.FONT_HERSHEY_SIMPLEX, 0.5, (0, 255, 0), 2)
  print(“[INFO] tag family: {}”.format(tagFamily))
  cv2.imshow(“Image”, image)
  cv2.waitKey(0)
  2、检测结果如下图:
举报
更多回帖
