STM32
直播中
李超
7年用户 1343经验值
私信 关注
[问答]
如何去开发一种MiniFly微型四轴呢
如何去开发一种MiniFly微型四轴呢?
回帖(1)
文妮
2021-11-10 15:42:43
  adc.c /joystick.c /remoter.c 代码详解
  (1)adc.c
  adc.c 在HARDWARE分组下。
  adc.c 主要实现采集摇杆电位器电压 AD 值。
  ①
  //初始化ADC,使用DMA传输
  //通道PA0PA1PA3PA4
  void Adc_Init(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  ADC_InitTypeDef ADC_InitStructure;
  DMA_InitTypeDef DMA_InitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE);//使能GPIOAB时钟
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);//使能ADC1时钟
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);//使能DMA时钟
  //PA012 作为模拟通道输入引脚
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  //PB01 作为模拟通道输入引脚
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  //DMA 配置
  DMA_DeInit(DMA1_Channel1);
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1-》DR; //ADC1-》DR地址
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&adc_value;//内存地址
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = 5*ADC_SAMPLE_NUM;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设地址固定
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址增加
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //半字
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //循环传输
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  DMA_Cmd(DMA1_Channel1, ENABLE);
  ADC_DeInit(ADC1); //复位ADC1,将外设 ADC1 的全部寄存器重设为缺省值
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC工作模式:ADC1和ADC2工作在独立模式
  ADC_InitStructure.ADC_ScanConvMode = ENABLE; //扫描模式,用于多通道采集
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //连续转换模式
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //转换由软件而不是外部触发启动
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC数据右对齐
  ADC_InitStructure.ADC_NbrOfChannel = 5; //顺序进行规则转换的ADC通道的数目
  ADC_Init(ADC1, &ADC_InitStructure); //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
  ADC_Cmd(ADC1, ENABLE); //使能指定的ADC1
  ADC_DMACmd(ADC1, ENABLE);//使能ADC1 DMA
  RCC_ADCCLKConfig(RCC_PCLK2_Div6); //设置ADC分频因子6 72M/6=12,ADC最大时间不能超过14M
  //配置连续转换通道,55.5个采样周期
  ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5); //1个通道转换一次耗时21us 4个通道
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5); //采样个数ADC_SAMPLE_NUM
  ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_239Cycles5); //总共耗时4*21*ADC_SAMPLE_NUM(64)=5.4ms《10ms
  ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 4, ADC_SampleTime_239Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 5, ADC_SampleTime_239Cycles5);
  ADC_ResetCalibration(ADC1); //使能复位校准
  while(ADC_GetResetCalibrationStatus(ADC1)); //等待复位校准结束
  ADC_StartCalibration(ADC1); //开启AD校准
  while(ADC_GetCalibrationStatus(ADC1)); //等待校准结束
  ADC_SoftwareStartConvCmd(ADC1, ENABLE); //使能指定的ADC1的软件转换启动功能
  DMA(Direct Memory Access):直接存储器访问。
  DMA传输将数据从一个地址空间复制到另一个地址空间。当CPU初始化这个动作后,传输动作本身是由DMA控制器来实现和完成。采用DMA传输数据不仅不会让处理器的工作延迟,反而可以解放处理器去处理其他事项。 DMA传输方式无需CPU直接控制传输,也没有中断处理方式那样保留现场和恢复现场的过程,通过硬件为RAM与I/O设备开辟一条直接传送数据的通路,能使CPU得效率大为提高。 STM32最多有2个DMA控制器,DMA1有7个通道。DMA2有5个通道。每个通道专门用来管理来自于一个或多个外设对存储器访问的请求。还有一个仲裁来协调各个DMA请求的优先权。
  ②
  #define ADC_SAMPLE_NUM 10
  u16 adc_value[5*ADC_SAMPLE_NUM];//ADC采集值存放缓冲区
  //ADC均值滤波
  void ADC_Filter(u16* adc_val)
  u16 i=0;
  u32 sum[5]={0,0,0,0};
  for(;i《ADC_SAMPLE_NUM;i++)
  sum[0]+=adc_value[5*i+0];//adc_value是ADC采集出来的数据
  sum[1]+=adc_value[5*i+1];
  sum[2]+=adc_value[5*i+2];
  sum[3]+=adc_value[5*i+3];
  sum[4]+=adc_value[5*i+4];
  adc_val[0]=sum[0]/ADC_SAMPLE_NUM;
  adc_val[1]=sum[1]/ADC_SAMPLE_NUM;
  adc_val[2]=sum[2]/ADC_SAMPLE_NUM;
  adc_val[3]=sum[3]/ADC_SAMPLE_NUM;
  adc_val[4]=sum[4]/ADC_SAMPLE_NUM;
  ③
  u16 getAdcValue(u8 axis)
  u32 sum=0;
  for(u8 i=0;i《ADC_SAMPLE_NUM;i++)
  sum += adc_value[5*i+axis];
  return sum/ADC_SAMPLE_NUM;
  (2)joystick.c
  joystick.c在COMMUNICATE分组下。
  joystick.c 主要实现将 AD值转为 THRUST、YAW、PITCH、ROLL 对应百分比。
  joystick—摇杆,THRUST—油门值
  YAW—偏航角,PITCH—俯仰角,ROLL—滚转角
  ①
  /*摇杆初始化*/
  void joystickInit(void)
  if(isInit) return;
  Adc_Init();
  jsParam = &configParam.jsParam;
  isInit = true;
  ②
  /*获取摇杆ADC值*/
  void getFlyDataADCValue(joystickFlyui16_t *adcValue)
  adcValue-》thrust = getAdcValue(ADC_THRUST);
  adcValue-》roll = getAdcValue(ADC_ROLL);
  adcValue-》pitch = getAdcValue(ADC_PITCH);
  adcValue-》yaw = getAdcValue(ADC_YAW);
  ③
  /*ADC值转换成飞控数据百分比*/
  void ADCtoFlyDataPercent(joystickFlyf_t *percent)
  s16 adcValue;
  //THRUST
  adcValue = getAdcValue(ADC_THRUST) - jsParam-》thrust.mid;
  adcValue = deadband(adcValue,MID_DB_THRUST);
  if(adcValue》=0)
  percent-》thrust = (float)adcValue/(jsParam-》thrust.range_pos-MID_DB_THRUST-DB_RANGE);
  else
  percent-》thrust = (float)adcValue/(jsParam-》thrust.range_neg-MID_DB_THRUST-DB_RANGE);
  //ROLL
  adcValue = getAdcValue(ADC_ROLL) - jsParam-》roll.mid;
  adcValue = deadband(adcValue, MID_DB_ROLL);
  if(adcValue 》= 0)
  percent-》roll = (float)adcValue/(jsParam-》roll.range_pos-MID_DB_ROLL-DB_RANGE);
  else
  percent-》roll = (float)adcValue/(jsParam-》roll.range_neg-MID_DB_ROLL-DB_RANGE);
  //PITCH
  adcValue = getAdcValue(ADC_PITCH) - jsParam-》pitch.mid;
  adcValue = deadband(adcValue, MID_DB_PITCH);
  if(adcValue 》= 0)
  percent-》pitch = (float)adcValue/(jsParam-》pitch.range_pos-MID_DB_PITCH-DB_RANGE);
  else
  percent-》pitch = (float)adcValue/(jsParam-》pitch.range_neg-MID_DB_PITCH-DB_RANGE);
  //YAW
  adcValue = getAdcValue(ADC_YAW) - jsParam-》yaw.mid;
  adcValue = deadband(adcValue, MID_DB_YAW);
  if(adcValue 》= 0)
  percent-》yaw = (float)adcValue/(jsParam-》yaw.range_pos-MID_DB_YAW-DB_RANGE);
  else
  percent-》yaw = (float)adcValue/(jsParam-》yaw.range_neg-MID_DB_YAW-DB_RANGE);
  (3)remoter.c
  remoter.c在COMMUNICATE分组下。
  remoter.c 主要实现将百分比乘以设定速度值并打包成 ATKP 包格式,然后以 10ms 周期性发送到 radiolink.c 的发送队列中,即 commanderTask。
  /*发送飞控命令任务*/
  void commanderTask(void* param)
  float max_thrust = LOW_SPEED_THRUST;
  float max_pitch = LOW_SPEED_PITCH;
  float max_roll = LOW_SPEED_ROLL;
  joystickFlyf_t percent;
  while(1)
  vTaskDelay(10);
  switch(configParam.flight.speed)
  case LOW_SPEED:
  break;
  case MID_SPEED:
  max_thrust = MID_SPEED_THRUST;
  max_pitch = MID_SPEED_PITCH;
  max_roll = MID_SPEED_ROLL;
  break;
  case HIGH_SPEED:
  max_thrust = HIGH_SPEED_THRUST;
  max_pitch = HIGH_SPEED_PITCH;
  max_roll = HIGH_SPEED_ROLL;
  break;
  ADCtoFlyDataPercent(&percent);
  //THRUST
  if(configParam.flight.ctrl == ALTHOLD_MODE || configParam.flight.ctrl == THREEHOLD_MODE)/*定高模式 和定点模式*/
  flydata.thrust = percent.thrust * ALT_THRUST;
  flydata.thrust += ALT_THRUST;
  flydata.thrust = limit(flydata.thrust, 0, 100);
  else
  flydata.thrust = percent.thrust * (max_thrust - MIN_THRUST);
  flydata.thrust += MIN_THRUST;
  flydata.thrust = limit(flydata.thrust, MIN_THRUST, max_thrust);
  //ROLL
  flydata.roll = percent.roll * max_roll;
  flydata.roll = limit(flydata.roll, -max_roll, max_roll);
  //PITCH
  flydata.pitch = percent.pitch * max_pitch;
  flydata.pitch = limit(flydata.pitch, -max_pitch, max_pitch);
  //YAW
  flydata.yaw = percent.yaw * MAX_YAW;
  flydata.yaw = limit(flydata.yaw, -MAX_YAW, MAX_YAW);
  /*发送飞控数据*/
  if(getRCLock()==false && radioinkConnectStatus()==true && getIsMFCanFly()==true)
  remoterData_t send;
  switch(configParam.flight.mode)
  case HEAD_LESS:
  send.flightMode = 1;
  break;
  case X_MODE:
  send.flightMode = 0;
  break;
  switch(configParam.flight.ctrl)
  case ALTHOLD_MODE:
  send.ctrlMode = 1;
  break;
  case MANUAL_MODE:
  send.ctrlMode = 0;
  break;
  case THREEHOLD_MODE:
  send.ctrlMode = 3;
  break;
  if(flydata.thrust《=MIN_THRUST && send.ctrlMode==0)
  send.thrust = 0;
  else
  send.thrust = flydata.thrust;
  if(getTrimFlag() == true)
  send.pitch = 0;
  send.roll = 0;
  else
  send.pitch = flydata.pitch ;
  send.roll = flydata.roll;
  send.yaw = flydata.yaw;
  send.trimPitch = configParam.trim.pitch;
  send.trimRoll = configParam.trim.roll;
  /*发送飞控数据*/
  sendRmotorData((u8*)&send, sizeof(send));
  /*发送遥感数据至匿名上位机*/
  if(radioinkConnectStatus()==true)
  atkp_t p;
  joystickFlyui16_t rcdata;
  rcdata.thrust = flydata.thrust*10 + 1000;
  rcdata.pitch = percent.pitch*500 + 1500;
  rcdata.roll = percent.roll*500 + 1500;
  rcdata.yaw = percent.yaw*500 + 1500;
  p.msgID = DOWN_RCDATA;
  p.dataLen = sizeof(rcdata);
  memcpy(p.data, &rcdata, p.dataLen);
  radiolinkSendPacket(&p);
举报
更多回帖
