STM32
直播中
douyin8
13年用户 1184经验值
私信 关注
[问答]
怎样去安装RTEMS脚本呢
怎样去安装RTEMS脚本呢?其代码程序该如何去实现呢?
回帖(1)
王焕树
2021-11-5 15:49:13
  RTEMS 安装脚本
  rtems_building_v10.sh
  #!/bin/bash
  #rtems4.11在linuxmint-16-cinnamon-64bit上测试通过
  #设置
  TARGET=arm-rtemseabi4.11
  PREFIX=/opt/rtems-4.11
  BSP=stm32f4
  BASEDIR=`pwd`
  TOPDIR=my_rtems
  binutils_name=binutils-2.24.tar.bz2
  gcc_name=gcc-4.8.2.tar.bz2
  gcc_diff_name=gcc-4.8.2-rtems4.11-20131031.diff
  gdb_name=gdb-7.6.2.tar.bz2
  gdb_diff_name=gdb-7.6.2-rtems4.11-20131208.diff
  newlib_name=newlib-1.20.0.tar.gz
  newlib_diff_name=newlib-1.20.0-rtems4.11-20130325.diff
  binutils_basename=`echo $binutils_name | awk -F. ‘NF-=2’ OFS=。`
  gcc_basename=`echo $gcc_name | awk -F. ‘NF-=2’ OFS=。`
  gdb_basename=`echo $gdb_name | awk -F. ‘NF-=2’ OFS=。`
  newlib_basename=`echo $newlib_name | awk -F. ‘NF-=2’ OFS=。`
  #“按任意键继续。。。”的处理函数
  get_char()
  SAVEDSTTY=`stty -g`
  stty -echo
  stty raw
  dd if=/dev/tty bs=1 count=1 2》 /dev/null
  stty -raw
  stty echo
  stty $SAVEDSTTY
  usage()
  cat 《《EOF
  -d 下载安装并创建压缩包-》引导rtems-》配置rtems-》编译安装rtems-》编译应用程序
  -e 从本地压缩包安装-》引导rtems-》配置rtems-》编译安装rtems-》编译应用程序
  -b 引导rtems-》配置rtems-》编译安装rtems-》编译应用程序
  -c 配置rtems-》编译安装rtems-》编译应用程序
  -m 编译安装rtems-》编译应用程序
  -a 编译应用程序
  EOF
  if [ -z “$1” ]; then
  usage
  exit 1
  fi
  DOWNLOAD=no
  EXTRACT=no
  BOOTSTRAP=no
  CONFIGURE=no
  MAKERTEMS=no
  APPLICATION=no
  while getopts debcma OPT
  do
  case “$OPT” in
  d) DOWNLOAD=yes; BOOTSTRAP=yes; CONFIGURE=yes; MAKERTEMS=yes; APPLICATION=yes;;
  e) EXTRACT=yes; BOOTSTRAP=yes; CONFIGURE=yes; MAKERTEMS=yes; APPLICATION=yes;;
  b) BOOTSTRAP=yes; CONFIGURE=yes; MAKERTEMS=yes; APPLICATION=yes;;
  c) CONFIGURE=yes; MAKERTEMS=yes; APPLICATION=yes;;
  m) MAKERTEMS=yes; APPLICATION=yes;;
  a) APPLICATION=yes;;
  *) usage; exit 1;;
  esac
  done
  if [ $DOWNLOAD = ‘yes’ ] || [ $EXTRACT = ‘yes’ ]; then
  echo “创建交叉工具链安装目录”
  if [ ! -d “$PREFIX” ]; then
  sudo mkdir $PREFIX
  sudo chown $USER:$USER $PREFIX
  fi
  if [ -d “$TOPDIR” ]; then
  echo “错误:目录$TOPDIR已经存在”
  exit 1
  fi
  echo “设置环境变量”
  if [ ! -f “$HOME/.bashrc” ]; then
  touch $HOME/.bashrc
  fi
  if !(grep -q “export PATH=$PREFIX/bin:”‘$PATH’ $HOME/.bashrc); then
  echo export PATH=$PREFIX/bin:‘$PATH’ 》》 $HOME/.bashrc
  fi
  if !(grep -q “export RTEMS_MAKEFILE_PATH=$PREFIX/$TARGET/$BSP” $HOME/.bashrc); then
  echo export RTEMS_MAKEFILE_PATH=$PREFIX/$TARGET/$BSP 》》 $HOME/.bashrc
  fi
  source $HOME/.bashrc
  echo “安装依赖项”
  sudo apt-get -d update 2》&1 | tee apt-get_update.log
  if (grep -q -E ‘^E:|^Err|^W:’ apt-get_update.log); then
  if (grep -q ‘/var/lib/apt/lists/lock’ apt-get_update.log); then
  sudo rm /var/lib/apt/lists/* -vf
  sudo apt-get update
  if [ $? -ne 0 ]; then
  echo “更新源出现错误,请稍候重试1”
  exit 1
  fi
  else
  echo “更新源出现错误,请稍候重试2”
  exit 1
  fi
  fi
  sudo apt-get install -y autoconf automake autotools-dev build-essential git dpkg-dev g++ libalgorithm-diff-perl libalgorithm-diff-xs-perl libalgorithm-merge-perl libdpkg-perl libgmp-dev libgmp3-dev libgmpxx4ldbl libltdl-dev libmpc-dev libmpfr-dev libtimedate-perl libtool texinfo flex libncurses5-dev libc6-dev
  echo “安装依赖项出现错误,请稍候重试”
  exit 1
  fi
  #echo “按任意键继续。。。” && char=`get_char`
  if [ $DOWNLOAD = ‘yes’ ]; then
  echo “下载安装并创建压缩包”
  which proz 》 /dev/null 2》&1
  echo “安装多线程下载工具”
  wget -c http://dxdown1.onlinedown.net/down/prozilla-2.0.4.tar.zip
  unzip prozilla-2.0.4.tar.zip prozilla-2.0.4.tar.bz2
  tar -xf prozilla-2.0.4.tar.bz2
  cd prozilla-2.0.4
  sed -i ‘s/DL_Window:://’ src/download_win.h
  。/configure
  make
  sudo make install
  cd 。。
  fi
  echo “安装多线程下载工具出现错误,中止运行”
  exit 1
  fi
  exit 1
  fi
  mkdir $TOPDIR
  cd $TOPDIR
  down_cmd=‘proz -k=20 ’
  host1=‘http://mirrors.ustc.edu.cn/gnu’
  #host2=‘http://mirror.bjtu.edu.cn/gnu’
  $down_cmd$host1/binutils/$binutils_name
  $down_cmd$host1/gcc/$gcc_basename/$gcc_name
  $down_cmd$host1/gdb/$gdb_name
  host1=‘http://www.rtems.org/ftp/pub/rtems/SOURCES/4.11’
  $down_cmd$host1/$gcc_diff_name
  $down_cmd$host1/$gdb_diff_name
  $down_cmd$host1/$newlib_name
  $down_cmd$host1/$newlib_diff_name
  git_cmd=‘git clone git://git.rtems.org’
  $git_cmd/examples-v2.git examples-v2
  $git_cmd/rtems.git rtems
  $git_cmd/rtems-schedsim.git rtems-schedsim
  $git_cmd/rtems-testing.git rtems-testing
  $git_cmd/rtems-addon-packages.git rtems-addon-packages
  cd 。。
  echo “打包。。.”
  tar -zcf $TOPDIR-$(date +%Y%m%d-%H%M%S).tar.gz $TOPDIR
  else
  echo “从本地压缩包安装”
  rtems_pkg=`find 。 -maxdepth 1 -type f -name “$TOPDIR-????????-??????.tar.gz” | sort -r | head -1`
  if [ -z “$rtems_pkg” ]; then
  echo “错误:没有找到压缩包,中止执行”
  exit 1
  fi
  exit 1
  fi
  echo “解包。。.”
  tar -xf $rtems_pkg
  fi
  echo “编译安装交叉工具链”
  cd $BASEDIR/$TOPDIR
  tar -xf $binutils_name
  tar -xf $gcc_name
  patch -p0 《 $gcc__diff_name
  tar -xf $gdb_name
  patch -p0 《 $gdb_diff_name
  tar -xf $newlib_name
  patch -p0 《 $newlib_diff_name
  mkdir b-binutils
  cd b-binutils
  。。/$binutils_basename/configure --target=$TARGET --prefix=$PREFIX && make && make install
  cd 。。
  cd $gcc_basename
  ln -s 。。/$newlib_basename/newlib 。
  cd 。。
  mkdir b-gcc
  cd b-gcc
  。。/$gcc_basename/configure --target=$TARGET --with-gnu-as --with-gnu-ld --with-newlib --verbose --enable-threads --enable-obsolete --enable-languages=“c,c++” --prefix=$PREFIX
  make
  echo “编译安装交叉工具链出现错误,中止执行”
  exit 1
  fi
  make install
  cd 。。
  mkdir b-gdb
  cd b-gdb
  。。/$gdb_basename/configure --target=$TARGET --prefix=$PREFIX && make && make install
  cd 。。
  echo “删除多余的BSP” #注释掉的行将被保留
  delbsps=‘
  arm/c***336
  arm/c***337
  arm/edb7312
  arm/gba
  arm/gdbarmsim
  arm/gp32
  arm/gumstix
  arm/lm3s69xx
  arm/lpc24xx
  arm/lpc32xx
  arm/nds
  arm/raspberrypi
  arm/realview-pbx-a9
  arm/rtl22xx
  arm/smdk2410
  #arm/stm32f4
  arm/xilinx-zynq
  avr
  bfin
  h8300
  i386
  lm32
  m32c
  m32r
  m68k
  mips
  moxie
  nios2
  no_cpu
  powerpc
  sh
  sparc
  sparc64
  v850
  for i in $delbsps; do
  if [ -d “rtems/c/src/lib/libbsp/$i” ]; then
  rm -r rtems/c/src/lib/libbsp/$i
  fi
  if [ -d “rtems/c/src/lib/libcpu/$i” ]; then
  rm -r rtems/c/src/lib/libcpu/$i
  fi
  if [ -d “rtems/cpukit/score/cpu/$i” ]; then
  rm -r rtems/cpukit/score/cpu/$i
  fi
  ii=`echo $i | sed ‘s#/#\/#g’`
  sed -i “/$ii/d” rtems/cpukit/configure.ac
  sed -i “/$ii/d” rtems/cpukit/score/cpu/Makefile.am
  done
  echo “删除自带的示例”
  rm -r rtems/testsuites
  rm -r rtems/c/src/ada-tests
  fi #end [ $DOWNLOAD = ‘yes’ ] || [ $EXTRACT = ‘yes’ ]
  if [ $BOOTSTRAP = ‘yes’ ]; then
  echo “引导rtems”
  cd $BASEDIR/$TOPDIR/rtems
  。/bootstrap -c
  。/bootstrap -p
  。/bootstrap
  echo “引导rtems出现错误,中止执行”
  exit 1
  fi
  cd 。。
  fi #end BOOTSTRAP
  if [ $CONFIGURE = ‘yes’ ]; then
  echo “配置rtems”
  cd $BASEDIR/$TOPDIR
  if [ -d “b-$BSP” ]; then
  rm -r b-$BSP
  fi
  mkdir b-$BSP
  cd b-$BSP
  。。/rtems/configure --target=$TARGET --enable-rtem***sp=$BSP --disable-tests --enable-posix --disable-networking --prefix=$PREFIX | tee configure.log
  echo “配置rtems出现错误,中止执行1”
  exit 1
  fi
  if !(grep -q “‘make all’ will build the following BSPs” configure.log); then
  echo “配置rtems出现错误,中止执行2”
  exit 1
  fi
  echo “如果上面几行出现如下类似语句说明配置成功”
  echo “‘make all’ will build the following BSPs: stm32f107.”
  echo “other BSPs can be built with ‘make RTEMS_BSP=”bsp1 bsp2 。。.“’”
  fi #end CONFIGURE
  if [ $MAKERTEMS = ‘yes’ ]; then
  echo “编译安装rtems”
  cd $BASEDIR/$TOPDIR/b-$BSP
  make clean
  make
  echo “编译安装rtems出现错误,中止执行”
  exit 1
  fi
  make install
  fi #end MAKERTEMS
  if [ $APPLICATION = ‘yes’ ]; then
  echo “编译应用程序”
  cd $BASEDIR/$TOPDIR/examples-v2/hello/hello_world_c
  make clean
  make
  echo “编译应用程序出现错误,中止执行”
  exit 1
  fi
  echo “如果上面几行出现如下类似语句说明编译成功”
  echo “ text data bss dec hex filename”
  echo “ 76032 1908 129160 207100 328fc o-optimize/hello.exe”
  cd o-optimize
  $TARGET-objdump -x hello.exe 》 hello.out
  $TARGET-objdump -d -j .start -j .vector -j .text -j .init -j .fini -j .rodata -j .ARM.exidx -j .eh_frame -j .init_array -j .fini_array -j .jcr -j .data -j .bss -j .work -j .comment -j .ARM.attributes hello.exe 》 hello.S
  $TARGET-objcopy -O binary hello.exe -S hello.bin
  cp hello.exe hello.out hello.S hello.bin $BASEDIR
  fi #end APPLICATION
  time=$SECONDS
  hour=$[$time/3600]
  min=$[$[$time/60]%60]
  sec=$[$time%60]
  echo “执行时间:$hour小时$min分$sec秒”
举报
更多回帖
