static void SetSysClock(void)
__IO uint32_t StartUpCounter = 0, HSEStatus = 0;
/* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/
#if defined (PLL_SOURCE_HSI)
/* At this stage the HSI is already enabled */
/* Enable Prefetch Buffer and set Flash Latency */
FLASH-》ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
/* HCLK = SYSCLK */
RCC-》CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
/* PCLK = HCLK */
RCC-》CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1;
/* PLL configuration = (HSI/2) * 12 = ~48 MHz */
RCC-》CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
RCC-》CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSI_Div2 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL12);
/* Enable PLL */
RCC-》CR |= RCC_CR_PLLON;
/* Wait till PLL is ready */
while((RCC-》CR & RCC_CR_PLLRDY) == 0)
/* Select PLL as system clock source */
RCC-》CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
RCC-》CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
/* Wait till PLL is used as system clock source */
while ((RCC-》CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
#else
#if defined (PLL_SOURCE_HSE)
/* Enable HSE */
RCC-》CR |= ((uint32_t)RCC_CR_HSEON);
#elif defined (PLL_SOURCE_HSE_BYPASS)
/* HSE oscillator bypassed with external clock */
RCC-》CR |= (uint32_t)(RCC_CR_HSEON | RCC_CR_HSEBYP);
#endif /* PLL_SOURCE_HSE */
/* Wait till HSE is ready and if Time out is reached exit */
do
HSEStatus = RCC-》CR & RCC_CR_HSERDY;
StartUpCounter++;
} while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
if ((RCC-》CR & RCC_CR_HSERDY) != RESET)
HSEStatus = (uint32_t)0x01;
else
HSEStatus = (uint32_t)0x00;
if (HSEStatus == (uint32_t)0x01)
/* HCLK = SYSCLK */
/* PCLK = HCLK */
/* PLL configuration = HSE * 6 = 48 MHz */
RCC-》CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6);
/* Enable PLL */
else
{ /* If HSE fails to start-up, the application will have wrong clock
configuration. User can add here some code to deal with this error */
#endif /* PLL_SOURCE_HSI */
/* HCLK = SYSCLK */
/* PCLK = HCLK */
/* Enable PLL */
#else
/* Enable HSE */
do
StartUpCounter++;
else
/* HCLK = SYSCLK */
/* PCLK = HCLK */
/* Enable PLL */
else
举报
