2021-10-21 13:59:10
通过串口给单片机发送指令控制电机不同的转动状态,此程序是配合普中51-单核-A4开发板写的。请按需服用。欢迎留言讨论。
/*1、串口发送00,电机停止转动,指示灯1点亮;
2、串口发送01,电机全速正转,指示灯2点亮;
3、串口发送02,电机全速反转,指示灯3点亮;
4、串口发送03,电机50%速度正转,指示灯2闪烁;
5、串口发送04,电机50%速度反转,指示灯3闪烁;
数码管代替指示灯(数码管的正向反向流动,流动速度的快慢代替指示灯)指示灯不亮不闪烁
#include //头文件 #预处理命令符 inclue预处理命令
#define uint unsigned int
#define uchar unsigned char
uchar a,b,i; //定义全局变量a的值域,以便下面函数使用
uchar SendBuf[]="The signal is normal";
//定义数组,储存返回语句
uchar code DMZ50[]={0x01,0x01,0x01,0x01,0x02,0x04,0x08,0x08,0x08,0x08,0x10,0x20}; //流水显示的段码,定义为正
uchar code DMF50[]={0x20,0x10,0x08,0x08,0x08,0x08,0x04,0x02,0x01,0x01,0x01,0x01}; //流水显示的段码,定义为反
uchar code DM0[]={0x49,0x36,0x49,0x36,0x49,0x36,0x49,0x36,0x49,0x36,0x49,0x36,0x49,0x36,0x49,0x36};
//流水显示的段码,停
uchar code DMZ[] = {0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x04,
0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x10,0x20};
uchar code DMF[] = {0x20,0x10,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,
0x04,0x02,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01};
***it WA=P2^2;
***it WB=P2^3; //74HC138译码器位选管脚(数码管用)
***it WC=P2^4;
/*蜂鸣器*/
***it BZ=P2^5;
//L298N引脚定义
***it ena = P1^0; //l298n电机驱动的相关引脚
***it in1 = P1^1;
***it in2 = P1^2;
***it in3 = P1^3;
***it in4 = P1^4;
***it enb = P1^5;
uchar MA = 0,MB = 0; //pwm控制用
uchar PWMA = 20;
uchar PWMB = 20;
uchar cmd; //串口接收的命令***uf
void delay(uint z); //声明延时函数
/*数码管*/
void showDigital()
switch(cmd)
case(0):
for(i=0;i<16;i++)
switch(i)
{ case(8):
WA = 0;WB = 0;WC = 0;break;
case(9):
WA = 1;WB = 0;WC = 0;break;
case(10):
WA = 0;WB = 1;WC = 0;break;
case(11):
WA = 1;WB = 1;WC = 0;break;
case(12):
WA = 0;WB = 0;WC = 1;break;
case(13):
WA = 1;WB = 0;WC = 1;break;
case(14):
WA = 0;WB = 1;WC = 1;break;
case(15):
WA = 1;WB = 1;WC = 1;break;
case(7):
case(6):
case(5):
case(4):
case(3):
case(2):
case(1):
case(0):
P0 = DM0;
delay(250);
break;
case(3):
for(i=0;i<12;i++)
switch(i)
case(11):
case(10):
case(9):
case(8):
case(7):
case(6):
case(5):
case(4):
case(3):
case(2):
case(1):
case(0):
P0 = DMZ50;
delay(50);
break;
case(4):
for(i=0;i<12;i++)
switch(i)
case(0):
case(1):
case(2):
case(3):
case(4):
case(5):
case(6):
case(7):
case(8):
case(9):
case(10):
case(11):
P0 = DMF50;
delay(50);
break;
case(1):
for(i=0;i<20;i++)
switch(i)
{ case(19):
case(18):
case(17):
case(16):
case(15):
case(14):
case(13):
case(12):
case(11):
case(10):
case(9):
case(8):
case(7):
case(6):
case(5):
case(4):
case(3):
case(2):
case(1):
case(0):
P0 = DMZ;
delay(25);
break;
case(2):
for(i=0;i<20;i++)
switch(i)
{ case(0):
case(1):
case(2):
case(3):
case(4):
case(5):
case(6):
case(7):
case(8):
case(9):
case(10):
case(11):
case(12):
case(13):
case(14):
case(15):
case(16):
case(17):
case(18):
case(19):
P0 = DMF;
delay(25);
break;
/*全速正转*/
void forward()
in1=1; //l298n手册,真值
in2=0;
in3=1;
in4=0;
PWMA = 20;
PWMB = 20;
/*全速反转*/
void fallback()
in1=0;
in2=1;
in3=0;
in4=1;
PWMA = 20;
PWMB = 20;
/*50占空比正转*/
void quick()
in1=1;
in2=0;
PWMA = 10;
in3=1;
in4=0;
PWMB = 10;
/*50占空比反转*/
void slow()
in1=0;
in2=1;
PWMA = 10;
in3=0;
in4=1;
PWMB = 10;
/*停*/
void stop()
in1=0;
in2=0;
in3=0;
in4=0;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=115;y>0;y--);
void SendOneByte(uchar *str) //串口发送数据
while(*str !='
