在 Hi3516DV300 编译、烧录并 Hello OHOS - HarmonyOS技术社区 - 电子技术论坛 - 广受欢迎的专业电子论坛
分享 收藏 返回
[文章]
本文指导开发者在单板上运行第一个应用程序,其中包括新建应用程序、编译、烧写、运行等步骤,最终输出“Hello OHOS!”。
新建应用程序
  • 新建目录及源码
    新建applications/sample/camera/apps/src/helloworld.c目录及文件,代码如下所示,用户可以自定义修改打印内容(例如:修改OHOS为World)。当前应用程序可支持标准C及C++的代码开发。
    1. #include
    2. int main(int argc, char **argv)
    3. {
    4.     printf("n************************************************n");
    5.     printf("nttHello OHOS!n");
    6.     printf("n************************************************nn");
    7.     return 0;
    8. }
  • 新建编译组织文件
    新建applications/sample/camera/apps/BUILD.gn文件,内容如下所示:
    1. import("//build/lite/config/component/lite_component.gni")
    2. lite_component("hello-OHOS") {
    3.   features = [ ":helloworld" ]
    4. }
    5. executable("helloworld") {
    6.   output_name = "helloworld"
    7.   sources = [ "src/helloworld.c" ]
    8.   include_dirs = []
    9.   defines = []
    10.   cflags_c = []
    11.   ldflags = []
    12. }
  • 添加新组件
    修改文件build/lite/components/applications.json,添加组件hello_world_app的配置,如下所示为applications.json文件片段,"##start##"和"##end##"之间为新增配置("##start##"和"##end##"仅用来标识位置,添加完配置后删除这两行):
    1. {
    2.   "components": [
    3.     {
    4.       "component": "camera_sample_communication",
    5.       "description": "Communication related samples.",
    6.       "optional": "true",
    7.       "dirs": [
    8.         "applications/sample/camera/communication"
    9.       ],
    10.       "targets": [
    11.         "//applications/sample/camera/communication:sample"
    12.       ],
    13.       "rom": "",
    14.       "ram": "",
    15.       "output": [],
    16.       "adapted_kernel": [ "liteos_a" ],
    17.       "features": [],
    18.       "deps": {
    19.         "components": [],
    20.         "third_party": []
    21.       }
    22.     },
    23. ##start##
    24.     {
    25.       "component": "hello_world_app",
    26.       "description": "Communication related samples.",
    27.       "optional": "true",
    28.       "dirs": [
    29.         "applications/sample/camera/apps"
    30.       ],
    31.       "targets": [
    32.         "//applications/sample/camera/apps:hello-OHOS"
    33.       ],
    34.       "rom": "",
    35.       "ram": "",
    36.       "output": [],
    37.       "adapted_kernel": [ "liteos_a" ],
    38.       "features": [],
    39.       "deps": {
    40.         "components": [],
    41.         "third_party": []
    42.       }
    43.     },
    44. ##end##
    45.     {
    46.       "component": "camera_sample_app",
    47.       "description": "Camera related samples.",
    48.       "optional": "true",
    49.       "dirs": [
    50.         "applications/sample/camera/launcher",
    51.         "applications/sample/camera/cameraApp",
    52.         "applications/sample/camera/setting",
    53.         "applications/sample/camera/gallery",
    54.         "applications/sample/camera/media"
    55.       ],
  • 修改单板配置文件
    修改文件vendor/hisilicon/hispark_taurus/config.json,新增hello_world_app组件的条目,如下所示代码片段为applications子系统配置,"##start##"和"##end##"之间为新增条目("##start##"和"##end##"仅用来标识位置,添加完配置后删除这两行):
    1.       {
    2.         "subsystem": "applications",
    3.         "components": [
    4.           { "component": "camera_sample_app", "features":[] },
    5.           { "component": "camera_sample_ai", "features":[] },
    6. ##start##
    7.           { "component": "hello_world_app", "features":[] },
    8. ##end##
    9.           { "component": "camera_screensaver_app", "features":[] }
    10.         ]
    11.       },
编译
如果Linux编译环境通过Docker方式安装,具体编译过程请参见Docker方式获取编译环境的编译操作。如果Linux编译环境通过软件包方式安装,请进入源码根目录,执行如下命令进行编译:
  1. hb set(设置编译路径)
  2. .(选择当前路径)
  3. 选择ipcamera_hispark_taurus@hisilicon并回车
  4. hb build -f(执行编译)
图 1  设置图例
结果文件生成在out/hispark_taurus/ipcamera_hispark_taurus目录下。
须知:Hi3516DV300单板的U-boot文件获取路径:device/hisilicon/hispark_taurus/sdk_liteos/uboot/out/boot/u-boot-hi3516dv300.bin
烧录Hi3516开发板的代码烧录支持USB烧录、网口烧录和串口烧录三种方式。此处仅以网口烧录为例进行说明。
  • 请连接好电脑和待烧录开发板,以Hi3516DV300为例,需要同时连接串口、网口和电源,具体可参考Hi3516开发板介绍。
  • 打开电脑的设备管理器,查看并记录对应的串口号。
    说明:如果对应的串口异常,请根据Hi3516/Hi3518系列开发板串口驱动安装指导安装USB转串口的驱动程序。
  • 打开DevEco Device Tool,在Projects中,点击Settings打开工程配置界面。
  • 在“Partition Configuration”页签,设置待烧录文件信息,默认情况下,DevEco Device Tool已针对Hi3516系列开发板进行适配,无需单独修改。
  • 在“hi3516dv300”页签,设置烧录选项,包括upload_port、upload_partitions和upload_protocol。
    • upload_port:选择步骤2中查询的串口号。
    • upload_protocol:选择烧录协议,固定选择“hiburn-net”。
    • upload_partitions:选择待烧录的文件,默认情况下会同时烧录fastboot、kernel、rootfs和userfs。
  • 检查和设置连接开发板后的网络适配器的IP地址信息,设置方法请参考设置Hi3516网口烧录的IP地址信息。
  • 设置网口烧录的IP地址信息,设置如下选项:
    • upload_net_server_ip:选择6中设置的IP地址信息。例如192.168.1.2
    • upload_net_client_mask:设置开发板的子网掩码,工具会自动根据选择的upload_net_server_ip进行设置。例如255.255.255.0
    • upload_net_client_gw:设置开发板的网关,工具会自动根据选择的upload_net_server_ip进行设置。例如192.168.1.1
    • upload_net_client_ip:设置开发板的IP地址,工具会自动根据选择的upload_net_server_ip进行设置。例如192.168.1.3
  • 所有的配置都修改完成后,在工程配置页签的顶部,点击Save进行保存。
  • 打开工程文件,点击图标,打开DevEco Device Tool界面,在“PROJECT TASKS”中,点击hi3516dv300下的Upload按钮,启动烧录。
  • 启动烧录后,显示如下提示信息时,请重启开发板(下电再上电)。
  • 重新上电后,启动烧录,界面提示如下信息时,表示烧录成功。
镜像运行
  • 连接串口。
    须知:若无法连接串口,请参考常见问题进行排查。
    图 2  连接串口图
    • 单击Monitor打开串口。
    • 连续输入回车直到串口显示"hisilicon"。
    • 单板初次启动或修改启动参数,请进入步骤2,否则进入步骤3。
  • (单板初次启动必选)修改U-boot的bootcmd及bootargs内容:该步骤为固化操作,若不修改参数只需执行一次。每次复位单板均会自动进入系统。
    须知:U-boot引导程序默认会有2秒的等待时间,用户可使用回车打断等待并显示"hisilicon",通过reset命令可再次启动系统。
    表 1  U-boot修改命令
    执行命令
    命令解释
    setenv bootcmd "mmc read 0x0 0x80000000 0x800 0x4800; go 0x80000000";
    读取FLASH起始地址为0x800(单位为512B,即1MB),大小为0x4800(单位为512B,即9MB)的内容到0x80000000的内存地址,该大小(9MB)与IDE中所填写OHOS_Image.bin文件大小必须相同
    setenv bootargs "console=ttyAMA0,115200n8 root=emmc fstype=vfat rootaddr=10M rootsize=20M rw";
    表示设置启动参数,输出模式为串口输出,波特率为115200,数据位8,rootfs挂载于emmc器件,文件系统类型为vfat,
    “rootaddr=10M rootsize=20M rw”处对应填入rootfs.img的烧写起始位置与长度,此处与IDE中新增rootfs.img文件时所填大小必须相同
    saveenv
    表示保存当前配置。
    reset
    表示复位单板。
    须知:**“go 0x80000000”**为可选指令,默认配置已将该指令固化在启动参数中,单板复位后可自动启动。若想切换为手动启动,可在U-boot启动倒数阶段使用"回车"打断自动启动。
  • 输入**“reset”**指令并回车,重启单板,启动成功如下图,输入回车串口显示OHOS字样。
    图 3  系统启动图
执行应用程序根目录下,在命令行输入指令“./bin/helloworld”执行写入的demo程序,显示成功结果如下图所示。
图 4  启动并成功执行应用程序图
更多回帖
