概述
文档主要介绍OpenHarmony 2.0如何快速移植 RK3288/RK3326/RK3399/RK3566 等芯片, 让开发者能够进一步开发和适配Rockchip平台。
各芯片系统支持状态
芯片名称 | OpenHarmony L0 | OpenHarmony L1 | OpenHarmony L2 |
RK3288 | N | N | Y |
RK3326 | N | N | Y |
RK3399 | N | N | Y |
RK3566/RK3568 | N | N | Y |
修订记录
日期 | 版本 | 作者 | 修改说明 |
2020-12-11 | V0.0.1 | Caesar Wang | 初始版本。 |
源码获取说明
获取OpenHarmony L2官网源码- repo init -u https://gitee.com/openharmony/manifest.git -b master --no-repo-verify
- repo sync -c
- repo forall -c 'git lfs pull'
获取Rockchip官方Linux SDK源码Rockchip Linux SDK 下载命令如下:
芯片 | 版本 | 下载命令 |
RK3566、RK3568 | Linux4.19 | repo init --repo-url ssh://git@www.rockchip.com.cn/repo/rk/tools/repo -u
ssh://git@www.rockchip.com.cn/linux/rockchip/platform/manifests -b linux -m
rk356x_linux_release.xml |
RK3399 | Linux4.19 | repo init --repo-url ssh://git@www.rockchip.com.cn/repo/rk/tools/repo -u
rk3399_linux4.19_release.xml |
RK3326 | Linux4.19 | repo init --repo-url ssh://git@www.rockchip.com.cn/repo/rk/tools/repo -u
rk3326_linux4.19_release.xml |
RK3288 | Linux4.19 | repo init --repo-url ssh://git@www.rockchip.com.cn/repo/rk/tools/repo -u
rk3288_linux4.19_release.xml |
编译说明OpenHarmony L2编译- bash build/prebuilts_download.sh
- ./build.sh --product-name Hi3516DV300
Rockchip Linux编译- ./build.sh lunch (选择对应的芯片)
- ./build.sh
RK3399 移植分区挂载的处理- sudo vi init.cfg
- "mount ext4 /dev/block/platform/fe330000.sdhci/by-name/oem /vendor wait rdonly barrier=1",
- "mount ext4 /dev/block/platform/fe330000.sdhci/by-name/userdata /data wait nosuid nodev noatime barrier=1,data=ordered,noauto_da_alloc"
显示问题vsync, 请git apply 打上如下patch
- patches/
- └── foundation
- └── graphic
- └── standard
- └── vsync.patch
- base commit:
- commit 3301ec6b2669ff1c7014ecbc320dcb41aab16734 (HEAD)
- Merge: 8186179 1441a80
- Author: openharmony_ci <7387629+openharmony_ci@user.noreply.gitee.com>
- Date: Thu Jul 29 08:16:36 2021 +0000
- !16 modify for musl compile
- Merge pull request !16 from huanglei/modify-for-musl-compile
Kernel适配
使用rockchip官方提供的Kernel 4.19, 再适配如下patch:
- kernel/
- └── rk3399_ohos-l2.patch
触摸的适配- console:/ $ cat /proc/bus/input/devices
- 找到对应设备,比如触摸gsl3673, u***对应的handler event
- I: Bus=0018 Vendor=0000 Product=0000 Version=0000
- N: Name4="gsl3673"
- P: Phys=
- S: Sysfs=/de.vices/platform/ff110000.i2c/i2c-1/91-0040/input/input1
- U: Uniq=
- H:7 Handlers=event1 cpufreq dmcfreq
- B: PROP=2
- B: EV=10000b
- B: KEY=0
- B: ABS=2658000 0
- console:/ $ cat /sys/class/input/event1/dev
- 13:65
- 得到从设备号是13:65
- c. 主设备号的文件 data/udev/data/看下有没有对应,没有的话,copy一份修改一下比如tp修改如下:
- console:/ # cat data/udev/data/c13:65
- I:1104248553
- E:ID_INPUT=1
- E:ID_INPUT_TOUCHSCREEN=1
调试工具- tools/
- ├── busybox
- └── strace
添加工具方便调试,hilog也可以调试
系统分区说明镜像的分区如下
- ├── MiniLoaderAll.bin
- ├── boot.img
- ├── misc.img
- ├── oem.img
- ├── parameter.txt
- ├── recovery.img
- ├── rootfs.img
- ├── trust.img
- ├── uboot.img
- └── userdata.img
其中rootfs.img 对应 OpenHarmony L2编译出来的system.imgoem.img对应 OpenHarmony L2编译出来的vendor.imguserdata.img对应 OpenHarmony L2编译出来的userdata.img
默认分区说明 ( 下面是 RK3399 IND 分区参考)
Number | Start (sector) | End (sector) | Size | Name |
1 | 16384 | 24575 | 4096K | uboot |
2 | 24576 | 32767 | 4096K | trust |
3 | 32768 | 40959 | 4096K | misc |
4 | 40960 | 106495 | 32M | boot |
5 | 106496 | 303104 | 32M | recovery |
6 | 172032 | 237567 | 32M | bakcup |
7 | 237568 | 368639 | 64M | oem |
8 | 368640 | 12951551 | 6144M | rootfs |
9 | 12951552 | 30535646 | 8585M | userdata |
- uboot 分区:供 uboot 编译出来的 uboot.img。
- trust 分区:供 uboot 编译出来的 trust.img。
- misc 分区:供 misc.img,给 recovery 使用。
- boot 分区:供 kernel 编译出来的 boot.img。
- recovery 分区:供 recovery 编译出的 recovery.img。
- backup 分区:预留,暂时没有用,后续跟 Android 一样作为 recovery 的 backup 使用。
- oem 分区:供 OHOS 编出来的vendor.img。挂载在 /vendor目录。
- rootfs 分区:供 OHOS 编出来的 system.img。
- userdata 分区:供 OHOS 编出来的 userdata.img,挂载在 /data 目录下。
RK3399-EVB-IND下载的固件提取码: xrry
刷机说明RK3399 挖掘机接口分布图如下:
RK3399 IND 行业板接口分布图如下:
Windows 刷机说明SDK 提供 Windows 烧写工具(工具版本需要 V2.84 或以上),工具位于工程根目录:
- tools/
- ├── windows/RKDevTool
如下图,编译生成相应的固件后,设备烧写需要进入 MASKROM 或 BootROM 烧写模式,连接好 USB 下载线后,按住按键“MASKROM”不放并按下复位键“RST”后松手,就能进入MASKROM 模式,加载编译生成固件的相应路径后,点击“执行”进行烧写,也可以按 “recovery" 按键不放并按下复位键 “RST” 后松手进入 loader 模式进行烧写,下面是 MASKROM 模式的分区偏移及烧写文件。(注意: Windows PC 需要在管理员权限运行工具才可执行)
注:烧写前,需安装最新 USB 驱动,驱动详见:
- /tools/windows/DriverAssitant_v5.11.zip
Linux 刷机说明Linux 下的烧写工具位于 tools/linux 目录下(Linux_Upgrade_Tool 工具版本需要 V1.65 或以上),请确认你的板子连接到 MASKROM/loader rocku***。比如编译生成的固件在 rockdev 目录下,升级命令如下:
- sudo ./upgrade_tool ul rockdev/MiniLoaderAll.bin
- sudo ./upgrade_tool di -p rockdev/parameter.txt
- sudo ./upgrade_tool di -u rockdev/uboot.img
- sudo ./upgrade_tool di -t rockdev/trust.img
- sudo ./upgrade_tool di -misc rockdev/misc.img
- sudo ./upgrade_tool di -b rockdev/boot.img
- sudo ./upgrade_tool di -recovery rockdev/recovery.img
- sudo ./upgrade_tool di -oem rockdev/oem.img
- sudo ./upgrade_tool di -rootfs rocdev/rootfs.img
- sudo ./upgrade_tool di -userdata rockdev/userdata.img
- sudo ./upgrade_tool rd
或升级打包后的完整固件:
- sudo ./upgrade_tool uf rockdev/update.img
或在根目录,机器在 MASKROM 状态运行如下升级:
运行效果FAQ目前发现存在的一些问题:
- Launcher显示颜色反调, 需要要求内核format更改位DRM_FORMAT_XBGR8888,
实际是weston或显示框架上的问题 - vsync问题,如上显示补丁vsync.patch,主要还是框架上的不兼容
- OS对UI或框架对显示宽需要16字节对齐,如果遇到宽不是16对齐的分辨率,就会遇到显示异常
TODO- 适配Rockchip的device目录,添加SOC内核构建的子系统
- 使用OHOS自带的kernel,来适配Rockchip平台
- HDF驱动的移植, LCD、触摸屏,WiFi等外设的适配
- Rockchip音视频多媒体,图形加速的适配
- Weston性能、功能优化的适配
